Question about Craftsman Garden
Where can I find pic of linkage hookup for tecumseh 10 hp engine it is on a craftsman riding mower the engine model # is 143.991002
  • 68 Answers
SOURCE: I need to find a repair manual for a craftsman riding lawn mower
SearsPartsDirect.com should have your answers
Posted on Apr 26, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
AUTODOC01
  • 216 Answers
SOURCE: Wiring diagram for 10 hp tecumseh motor.
no worries go to searsparts.com type in your model # and follow the prompts you can then print it out for free ?
Posted on Aug 28, 2009
Testimonial: "You made everything simple greeeeat.A++++++.Thanks Alot"
  • 124 Answers
SOURCE: have a craftsman 18.0hp riding lawn mower. Has a
Most likely it is the governor spring but you could have a stiff throttle shaft or a needle that is not closing properly allowing the carb to flow too much fuel into the engine.
Posted on Sep 20, 2009
SOURCE: How much oil does my craftsman riding mower hold? ...
4.5 pints with filter or 4 pints without
Posted on Sep 26, 2010
I installed a 632690 carburetor on my older sears 10 hp riding mower. The mower starts but I can't adjust the speed. I need a diagram on how to connect the linkage
interesting
Tecumseh 632690 - Carburetor
if still original
the sear should have a Tecumseh 11 hp motor
the pictures are the original governor and carby set ups for a sears 10 hp
Oct 18, 2016 | Sears Garden
I need a diagram for the carburator linkage on a tecumseh engin model no.143.945506
good luck... but your number says craftsman all over it. have about go to sears and type in that model number... your Tecumseh number would be like an LV160 or something similar
Sep 08, 2014 | Garden
Carberator linkage
You can find information about the B & S engines in their web site.
Jul 13, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a 10 hs tecumseh motor on a riding mower i need an explode view of carb and linkage when start-up engine it goes wide open
Hi and welcome to FixYa, I am Kelly. I understand you have a 10 HP Tecumseh engine. There are service manuals available on line for your engine but without your engine model number it is difficult to pass you the correct one: Here is the link for the service manuals:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals
Somewhere in the list is your manual.
This is my best guess without your engine model number:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_OHH50-65_OHHSK50-130_OHV11-OHV17_OVM120_OVRM40-675_OVRM120_OVXLC120_OVXL120_OVXL125_695244A.pdf
^-Make sure you read about Adjustments in section 1 also.
Running wide open causes:
1. Broken throttle control plate spring
2. Governor spring problem
3. Internal Governor flyweight has departed the governor gear.
4. Throttle plate (butterfly) attached to the throttle shaft in the carb throat has come off the throttle shaft.
5. Broken / missing linkage
6. Someone loosened the governor shaft bolt at the base of the governor arm and allowed the governor to get out of adjstment.
Thanks for choosing FixYa,
Kelly
Aug 12, 2011 | Tecumseh Garden
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Aug 27, 2009 | Garden
Carburetor linkages for riding lawn mower
Go to a tecumseh website and get a breakdown of the parts list and that should help a bit. Good luck.
Mar 24, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
80 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
