Question about Refrigerators
Water leaking inside refrgerator . - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 28, 2010
Water is leaking from my freezer into the refrgerator compartment. I assume the defrost drain is plugged. Where is the defrost drain located, how do I access it and what should I do once I access it?
The drain is located behind the back plate of freezer, under the coil their,use caution the fins on that coil are sharp and will cut you.
The best way to unclog it is a heated end of a wire hanger inserted repeadly till small hole developes then it can be flushed w/warm water.
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Refrigerators
FRS23R4CW2 Water does not fill ice maker...slow water does come out of water disp. we replaced whole ice maker...guess what... still not getting water to ice maker!! Help!
It's very likely that your problem is at the connection where the water line from the refrgerator connects to your home water pipe. Sometimes if you just turn that little valve all the way in and then back out it will solve your problem.Hope this helps.
Jun 04, 2011 | Frigidaire FRS23R4A Side by Side...
Freezer leaking watwr and refrgeration getting warm
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 24, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Refrgerator and freezer stop working. inside freezer the back has iced up which is not usual.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 02, 2011 | Refrigerators
Our true fridge is heating up inside even when we turn the dial all the way up to its coldest setting. i have also cleaned the coils and there seems to be no signs of a leak in the refrigerant lines. what...
could need a regas (fresh refrgerant) but my gess is the compresor is on its way out as well, how old is it
this is not a ceep fix you know, as if its more than say 6 years old it would be cheeper to just buy a new one,,,
Feb 21, 2010 | Refrigerators
I am getting water in my refrigerator. On my shelves and in my crisper draws. I can't see where water could be leaking from above at the ceiling of the refrigorator.
The drain is plugged by ice from your freezer and when it defrosts the water runs in your refrgerator part.
Checkout this tip it tells you how to fix your problem.
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
Heatman101
Jan 24, 2010 | Refrigerators
Kenmore refrigerator leaking
It could be the connection at the water control valve. If you can observe it, see if the water is coming from the connection or running down from above. There could be an ice jam where the water goes into the ice maker, and the water is falling out the back of the machine.
Apr 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Feb 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water inside the refrigerator
check the drain almosr definately blocked with bits of food or ice.
Jul 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
GE ADORA Refrgerator :
The water line from the house to the frig works, however the water in the frig just stop working one day. Any suggestions?
Feb 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
