Question about Hardware & Accessories
We have a timer in our switch panel and lost the instructions how to set it. It has a knob with the time on it (day and night). You can push it to turn it on. How do we set it to come on automatically?
You can see several types of timers here to identify your make and model
http://waterheatertimer.org/Programmable.html
If timer does not rotate around on its own, then it might not be working as a timer any more, but the manual override still works as on-off button.
Usually dial timers have tiny pins that move up and down. Look closely at the dial, and then experiment by pushing all the pins one direction.
Below the dial on newer timers is a selector button. On-Auto-Off or On-Off-Timer. To operate timer, set selector to Auto or Timer.
Posted on Sep 29, 2010
Setting clock on GE electric stove
Range Setting the Clock and Timer Non-Electronic Clocks: To set the clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
Digital Clocks: To set the clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
Electronic Clocks: To set the clock touch the Clock pad. Touch the number pads. Touch the number pads. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
Nov 06, 2016 | GE Kitchen Ranges
I want to set the timer to go out pm, and on am. I find the instructions very confusiing
http://waterheatertimer.org/How-to-set-timers.html
Actually the timer dial can be either day or night, but usually the dark background with white numbers is 6 pm to 6am (night time)
While the white background with dark numbers is 6 am to 6 pm (daytime)
Gene
Sep 17, 2014 | Hardware & Accessories
I bought the heavy duty appliance timer SA110, 15 amps for my hotwater solar heater. I followed the instuctions and the timer never worked. I bought this timer for the pump the pumps the water from the...
It sounds like you have the timer set correctly.
Manual says to set Master switch to ON position to make settings
Timer has lifetime warranty
Open following link to identify timer and download manual:
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
This timer is rated 120Volt 1800W incandescent 1/2 HP
If your pump rating plate shows excess of 1/2 HP, then this timer is not heavy enough.
Timer comes with lifetime warranty against workmanship, which is far superior than any other timer I've seen on the market, and I test and research timers each day.
Manual says to set Master switch to ON position to make settings.
After settings are made, manual says to move Master switch to Timer for timed functions, as you have done
Next thing to look for: if timer dial rotates as time passes, and keeps correct time.
The timer dial is a clock. The segments located around dial are pushed down or pushed up to control on-off operation.
As the dial rotates, the segments push a switch that turns Load on-off.
If you want timer ON for 2 hours, then you push down 8 consecutive segments.
If you want timer ON for 8 hours, then you push down 32 consecutive segments.
Plug ordinary lamp into timer, and turn lamp ON, and then manually rotate timer dial to see if lamp turns on-off. This will give you a baseline for timer operation, and then you can assess if the motor has suddenly malfunctioned, or breaker is tripped, etc.
Intermatic makes a heavy-duty plug-in timer, and the ratings are identical to your Sylvania SA110
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb31r.aspx
Apr 16, 2011 | Sylvania SA110 15 Amp Heavy Duty Appliance...
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
I have a noma outdoor timer N1506 I lost the instructions how to program it could you email me telling me how it is done thanks JIm
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} 1- Plug in the timer.
2- Set the time of the day (on the hour, example. 2. Pm) using the top TIME button. For pm there will be a dot to the lower right of the 6.
3- Once the time is set push the MODE button, this will replace the 6pm with a flashing P.
4- Push the TIME button again to set the time you want the timer to come on. (Remember for 6pm there will be a dot to the lower right of the 6.
5- Push the MODE button once the desired time is set, an E will appear.
6- Push the TIME button again to select the time you want the timer to go off (example 10.pm).
7- Push the MODE Button again. The time of day 2. (Pm) will be displayed. If the timer loses power just repeat the above steps.
Dec 04, 2009 | Kitchen Appliances - Others
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
Can't figure out how to set Intermatic timer 111c up to nightlight
Hello. I can help you with this times.
Step one - insert the pins at the times you want the night light to come on and go off. The green pins will turn on the night light and the red pins will turn it off. If you just want one on time and one off time just use one pin of each color.
After you have the pins inserted, set the correct time on the timer and plug it into an outlet that is always on [not one that is controlled by a wall switch].
The override switch will turn the device off if it is on, but just one time. As the next time it turns on it will once again be controlled by the times.
If ou want the night light to come on and off in the evening and again in the morninng, use two green pins and two red pins. Push in a green pin at each time where you want the night light to come on and push in a red pin at each time you want it to go off.
Get back if you need additional clarification.
Jun 02, 2009 | Intermatic & Lighted Dial Timer
How do you operate lamp timers
Yay!!! I found out the solution, and I tried it, and it DOES work!
I got these instructions from Intermatic Technical Services. I e-mailed them with my problem and they finally got back to me.
Follow them exactly and you will have no problems!
1) Pull up all trippers.
2) Push down the tripper at the time you want the light to turn on
3) Push down the tripper at the time you want the light to turn off
4) Push down all trippers for the duration of your on time
5) Set the current time of day with the time of day arrow
6) Plug in your lamp and make sure the lamp's switch is in the on position
7) Set the slide switch at the top to the timer position
If this does not help, please contact technical service by phone at 815-675-7000, option 1 then option 2.
Dec 18, 2008 | Hardware & Accessories
Hardware & Accessories Logo
342 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
