Question about GE Monogram® ZBD6880NSS Stainless Steel Dishwasher
Water stays in the bottom,how do I clean? Dave T
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 28, 2010
I HAVE A FRIGIDAIRE, Mo#FRT18IL6JB3, WATER IS COMING INTO THE BOTTOM OF FRIDGE AND NT TO THE DRAIN PAN, I CLEANED THE DRAIN HOSE AND IT STILL IS NOT DRAINING, Thanks Dave
Your make up water solenoid valve is leaking by its seat and needs to be replaced. You should be able to find the replacement on searspartsdirect.com.
Sep 28, 2014 | Frigidaire Refrigerators
Water is staying in the bottom
Water staying in bottom is not a problem unless the dishwasher base is full of it and covers the wash arm.
This means the drain cycle is not working or dishwasher is shutting off before drain cycle.
Try to clean the filters at the base and check drain in kitchen sink side is clear.
Need the model number in case you want more specific instructions.
Dec 06, 2010 | Maytag Dishwashers
Dishwasher not cleaning
Hi Dave,
Your sump may have enough debris in it to restrict some of the water flow, if you feel like you want to clean it out here is a link to some instructions I put together. If you end up doing it I would appreciate feed back good or bad on the instructions so I can help others.
Thanks!
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 24, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
LG dishwasher leaks from bottom of door
three things may cause this first the float that monitors the water level is stuck This float is in the bottom of the dishwasher below the bottom rack you will need to remove the cover (looks oval in shape) and check to see no food particals are in the area. If clean, Then the possibility of a bad door gasket is good can be purchased at an appliance parts house take the serial and model number with you for correct replacement part, and lastly check to see if the timer is operating properly by running it through a cycle and timing it.
Good luck hope this helped
dave
Feb 08, 2010 | Dishwashers
Water stays in the bottom of dishwasher after cylcling
If the water is clean and only about an inch deep or less, this is normal and almost every dishwasher keeps some water in the bottom to prevent the seals / gaskets from drying out.
If the water is not clean and there is an odor, please report back here and we can take the next step. Is so, please note approximately how full of left over water the dishwasher is. OK?
Aug 03, 2009 | Dishwashers
Top jets not working
I had the same problem on my LG washer, Check the plastic fitting that takes the water to the top section is securely pushed into its socket at the bottom of the inside of the dishwasher. It was the problem with mine and it pops out every so often. I've thought of gluing it in but Im worried It'll prevent access for more serious repairs.
Dave.
Jan 07, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Kenmore Elite front loader washer will not drain or spin out water error code F2.
Sounds like your pump is clogged. Take off the lower front panel via 3 ws on the bottom. Get a buch of towels, thiers gonna be water. Right in center front thier will be a white twist knob, about 3 inche in diamter. Unscrew it, this is when the water is gonna come out. If there is a secondary wall, pull it straight out with a pair of pliers. Clean out the pump, also check the little hole to the right leading into the impeller, make sure its clean. Finally put it back togther and try it out, thanks Dave www.washermd.com
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Some water stays in dishwasher (beau mark portable dishwasher
The manual says that's normal: "A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated."
Dec 14, 2008 | Dishwashers
Water wont leave the machine in rinse or spin cycle
Sounds like you have a broken lid switch, most likely part # 3949247,,#11 on diagram. Dave www.washermd.com
Dec 08, 2008 | Kenmore 22422 Top Load Washer
Error E15 - MAchine not draining
drain is same wehatever the program. filter is likely blocked. access is not that easy. take off panel at bottom rear. filter is in pipe from bottom of tub to pump. undo this pipe, take out filter. you may have water everywhere so be carefull
Nov 10, 2006 | Hotpoint Ultima WD72 Front Load...
GE Monogram® ZBD6880NSS Stainless Steel Dishwasher Logo
251 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
