Question about Polaroid TDA-03211C 32 in. LCD HDTV
My Polorioud flat screen just stoped working, the screen is black... the sound and dvd player still work and the channells still change, and you can kind of see the picture if the right amount of ligth hits the TV... i think the light must have blown out... can it be replaced... and if so? how, im pretty sure i can do it myself if given proper direction.. Please help! D. Vance
  • 11,361 Answers
It can be the 24vdc power supply section is bad or the backlight inverter board is bad, you need to troubleshoot it. Please read below:
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Sep 29, 2010
How do I fix?
Sounds to be a firmware corruption. Update its firmware with latest version than it have now. Gopakumar Gopalan Google
May 09, 2014 | Polaroid Televison & Video
I have a Protron LCD 26" TV model#LT26CIPI...The tv was working great turned it off on night and in the morning turned it back on to sound but no picture just a Black screen...when you change channels
Since its a LCD take a flashlight and have the room as dark as possible and with the light look to see if a very very faint image of the picture can be seen or not---many of these sets use a "back light" for the brightness and if that's not on.......
Dec 11, 2012 | Protron PD-DVR100 DVD Recorder
My vizio1080p full HDTV is black i caN change channels and the sound works it is just a black screen
Consider having a shop look at it as only boards are sold for this set and guessing and installing them can get expensive.
Aug 26, 2012 | Televison & Video
LN826510 works fine w/ DVD. Air channels where
Your antenna is inadequate.
You need to upgrade to a better antenna.
Jun 12, 2010 | Televison & Video
When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
Take the back panel off and look for a smd fuse with an F on it. Middle panel in the upper left corner, it is about the size of a tip of a pen. We used a copper wire to make a jumper. Works great now!!! We also noticed that there we some loose pieces and we pushed them back in and now the buttons on the side of the TV work.
May 17, 2009 | RCA L37WD12 37 in. LCD HDTV
Screen only work with reverse camera! booo!
It sound like you need to ground your parking brake wire.
Mar 23, 2008 | Jensen VM9510 Car DVD Player
Audio..Black Screen?
Either the backlight tube or the board that drives is broken, probably the tube - it's a cold cathode fluorescent, usually along the top or bottom of the screen. It may be fixable, but probably only worth it
if you DIY and can get replacement cheap enough. They can be a real pain to get to, usually cheaper to get a new player.
Dec 13, 2007 | Polaroid PDV-0700 Portable DVD Player
Sound with no picture
the problem is in the backlight try to measure the supply.and replace the inverter.
Dec 05, 2007 | Toshiba LCDTV/DVD Player 19HLV87
Black Box
i had the same problem with my rca truflat.. i read from a posting of a similar problem with a different tv brand to switch your closed caption options 'off' or set it to a 'cc' option instead of the 't' options.. (this was done through the on-screen menu..) i gave it a try and it worked for my tv.. hope it works for you..
Aug 16, 2006 | RCA 20F610TD TruFlat TV/DVD
No picture but sound
How did the cable person hook up the cable? Was it thru an rf connector and you need to put the tv on A channel . Or are there video and audio cables from the cable box to the tv? We need to have more info please. Thanks
Jun 12, 2006 | Philips 42PF9630A 42 in. Plasma Television
Polaroid TDA-03211C 32 in. LCD HDTV Logo
53 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
