Question about Husky Wet Tile/Stone Saw with with Laser and Stand
I HAVE THD950 TILE SAW AND THE MOTOR BURNED UP, WHERE I Can find it.
I have a QEP 7" tile saw. When I plug it in and press the switch, it hums-blade does not spin. (Note: not ready to cut tile yet, so no water in the bottom) Does anyone have any ideas on what's wrong?
Sounds like a shorted motor,or a dead spot on the armature. Try rotating the blade manually with no power first, then plug it in to see if it starts up. Don't let it hum for more than a second at a time, or it's sure to burn up the motor our trip the breaker.
Feb 12, 2016 | Qep Saws
D24000 wet tile saw smells of burning. What could this be?
mmm.. motor problem,armature or field coil burned or bearing burn motor housing
Jun 03, 2012 | Dewalt D24000S Heavy-Duty 10-inch Wet Tile...
Tile saw wont start. It's brand new. Is there some sort of safety device.
The first thing you should check is the GFCI switch on the power cord. All tile saws have one because of the water involved with cutting tile. It should have a test and reset button on it, press the reset button to get power to the saw motor. Some bigger saws also have a reset button on the motor itself for overload issues. Check for that if the GFCI reset doesn't work.
Jun 02, 2012 | Saws
My MK370 tile saw has a burning smell and it is making a slight banging noise every 7-9 seconds. The saw is cutting tile fine otherwise.
The problem could be bad brushes. Otherwise, you are probably burning the windings inside your motor. The slight banding noise could be an issue with the bearings in the motor itself. In which case you will soon be replacing the motor, so... we'll hope the brushes prove bad.
Assuming the motor has brushes, there will be 2 semi-large buttons on the motor (one on each side). They are screws. Remove them and beneath each one is a "brush". They should be long, hard, crack free, and smooth on the bottom where they touch the rotor. If not, then replace them. Almost all motors used for tools have brushes and some motors require disassembly of the motor itself to replace the brushes, but in your case, it should be an easy job. I can see one of the buttons on the Amazon picture.
:o)
Jun 03, 2011 | Mk Diamond 159943 MK370K 114Horsepower...
Huskey tile saw thd950l motor how much would it cost motor #c5d41884?
Take a look on amazon for sure. Amazon com Husky tile saw. If cant find just a motor, for sure there is someone to answer that question (someone who sells husky saws...). I hope this was helpful. cheers
Apr 12, 2011 | Husky Wet Tile/Stone Saw with with Laser...
Was going to buy " the beast" but have seen a lot
"In my opinion" I would stay away from the Ridgid tile saw. We had one come into our shop for repair of a burned out motor and could not get parts for it. The saw, at that time, wasn't made by Ridgid, it only carried the Ridgid name. I'm not familiar with the Dewalt tile saw enough to give you an opinion on it. If I were in the market for a tile saw, I'd get one by MK Diamond, they specialize in tile, stone, etc. cutting and make the best tile cutters I've used and worked on. They're priced towards the high end but are of contractor or industrial quality so will last a long time. If they do need repairs they're easy to get parts for that are fairly priced.
Jan 31, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
Need repair parts, salesman said to contact Husky directly for model THD950, parts have lifetime warranty, need web site name
Husky Support model THD950
This product is manufactured by Chervon North America, Inc. under a trademark license from Husky.
Husky tile saws, digital levels and mortar mixer come with a One-Year Limited Warranty. Chervon will replace parts, without charge, due to any defects in materials or workmanship, within the set warranty. For replacement parts, please contact Consumer Services at 1-866-664-8759 or you can purchase replacement parts online at www.huskysupport.com. Please note that for parts covered under warranty, you will need to have a copy of your receipt or have registered your tile saw online.
What is not covered under warranty?
This warranty applies only to the original purchaser at retail and may not be transferred. This warranty only covers defects arising under normal usage and does not cover any malfunction, failure or defect resulting from misuse, abuse, neglect, alteration, modification or repair by a third party. The warranty does not cover wear and tear parts such as the blade or carbon brushes.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jan 08, 2011 | Garden
I need the output shaft of this motor. It has the
You can order the parts you need from this website
http://www.mkdiamonddirect.com/category.sc;jsessionid=B8C66F8A4D5E422E3B401A634FBA7476.qscstrfrnt01?categoryId=99
Hope this is what you need
Mar 31, 2009 | Mk Diamond MK - 1070 Tile Saw
Husky Wet Tile/Stone Saw with with Laser and Stand Logo
290 people viewed this question
Top Husky Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Husky Measuring Tool and Sensor Expert? Answer questions, earn points and help others
