Question about Fedders A6U14W7A Air Conditioner
My Fedders room A/C model a6u14wta is making weird noises at high setting. What could be the cause of it? I posted a video of the problem http://www.youtube.com/watch?v=nmekh1dsqJU . Noise only comes on at high setting.
    Habit-Forming:
  • 156 Answers
Could be your bearing are going bad on your indoor fan but you only hear the sound when you turn it. Could also be something hanging behind it and it only hits the fan when you turn it on high and it pulls it into the fan blades.
Posted on Sep 28, 2010
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
SAMSUNG DLP HL-R4667
It sounds like a bad color wheel (see photo) which will give a fan like or high pitched sound.
Very common on these sets and can be a do it yourself repair.
You Tube has complete video instructions for replacement for most of these models.
The wheel turns at over 12,000 rpm (very small part) and the bearings in the motor fail causing a fan like or whine noise.
If it fails all the way and shatters (it can) set will not even make it on---set is monitoring the wheel and if not at right speed or stops almost instant shutdown will happen.
see the photo and let me know if questions--replaced a lot of them and your description is classic.
Mar 19, 2012 | Samsung DLP HL-P5663W 56" TV
Just brought home a fedders aep09d2b*b portable air conditioner. bought it used. it worked well there but when I plugged it in at home it is making a lot of fan noise - more noise the higher the fan...
If it was running fine before and you moved it and it's making noise, it sounds like something fell against the fan blades. The reason it sounds worse when you turn it up is that the fan is running fast. Grab a flashlight and check to see what might have fallen.
May 12, 2010 | Fedders A6P09D2B Portable Dual Hose Room...
Fedders dehumidifier making high pitched noise
The fam motor bearings are dry and need oil..wd-40 with the long spray nozzle maybe the best way to get oil on the bearings... some motors are sealed and it is very dificult the get them quiet again...spray right where the shaft comes out of the motor and then lean the unit back so the oil runs into the motor and let it set for awhile..then try it...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Apr 20, 2010 | Fedders A7DH65B2A Dehumidifier
Hi, Meens here In my Acer Aspire 5920 Vista home preimum getting weird sound frm inbuild microphone after swtich on n the sounds stops after plugging headfons :(
The usual cause of microphone noise is caused by audio settings where the microphone gain may be turned up to high causing it to pick up noise from the computer or built in speakes. This can cause noise ranging from an odd hum to a high pitched squeal.
Check your sound setting first
Jul 12, 2009 | Acer Aspire One PC Notebook
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Fedders A6U14W7A Air Conditioner Logo
81 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
