Question about Denon AVR-1906 Receiver
The power on my denon av-1570 amp keeps on cutting out and the power light is red and flashing. I've looked at the troubleshooting section of the manual and it recommends I turn it off for a period letting it cool and check the speaker wires to make sure they are not touching each other. I have done this and it still cuts out. Any idea what I should do?
  • jace84 Jul 24, 2008
    It is the same amplifier ic (flashing red l.e.d.) problem..... im not too clued up on this sorta stuff. Don't mean to sound stupid but is that repairable?
    Problem Solver:
  • 13 Answers
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
  • Denon Master
  • 1,550 Answers
Your audio amplifier ICs are damaged.
Posted on May 25, 2008
When I power my Denon AVR-3311ci on, it only comes on for a second then shuts off completely. No blinking red light and nothing on the display. I can hear a relay on the power board clicking. Any ideas?...
There's an electrical problem! The unit shuts off to protect itself. the relay sound is normal and is part of the power supply - good quality amps have them. I suggest taking it to your local repair shop.
Feb 17, 2015 | Denon AVR-3313CI
Denon AVR-1312 turns on displays for a second switches off and the red light starts to flash
you most likely have a shortedchannel in the amp that would need to be repaired
Jul 31, 2014 | Denon AVR1312 51 Channels Receiver
I have a Denon 2113 which turns on displays for a second switches off and the red light starts to flash. what could be the problem? Kindly assist...
Not sure if your power circuit board is fried. The red light flashing means that your unit is going into protective mode so that it won't damage other components inside the amp. Best to disconnect all cables and just have the power cable plugged in. See if this still happens. If it doesn't, attached each device one at a time to find out which cable is doing this. If you still have the same issue, the amp needs a service.
Dec 09, 2013 | Denon AVR-2113CI
Power keeps cutting off. stays on for 3 seconds
Could be either a problem with the amp or a bad voltage regulator. Hard to tell without checking some things inside.
Jul 30, 2013 | Denon AVR-689 7.1 Channel Home Theater AV...
Denon 1312 makes clicking sound will not turn on
If the front display does not light up at all when the press the power button, it is usually either the main power fuse or the power transformer. If the fuse is blowing, that usually means a short in the amp section.
Dec 26, 2012 | Denon Avr-1312 Home Theater Av A/v...
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
AVR-789 powers down with red flashing light
This is an indication that there is an overload problem in the output section of the amplifier. The overload could be thermal or electrical The overload circuit has built-in protection to help keep the amp from burning itself out. disconnect all speakers and cables from the unit and power it up. If the problem still exists, it is internal and will need to be repaired bya professional technician. If the problem goes away, check for shorted, crossed wires to your external speakers. Try different wires and speakers.
Hope this helps.
Feb 10, 2011 | Denon AVR-787
If i turn the power on , it switch off by it self and the power light flicker red
The set powers off because there is a cut off by the error amp which controls the main relay to switch off for safety from burning out any circuits. It could be failure of the output drive/ the short in the speakers or failure of the error amp section. It is tricky to find out the actual fault because you will have to keep testing by elimination, disconnect power output section, preamp section, and check if this releases the power switching.. Helpful? Good day
Jul 08, 2010 | Denon 3991095008 Rc1068 Remote...
Power cuts off suddenly, the power light flashes red quickly. i checked all wires are secure, none frayed or touching metal.. any ideas what 2 check or what could be source of problem?
You have a power supply problem as one of the +15v or -15v Regulators are bad. This is easy replaced at your local denon service shop.
Jan 10, 2010 | Denon AVR-1909 Receiver
Denon AVR-1906 Receiver Logo
664 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
