Question about Acer Aspire 5100 Notebook
Due to sugary spill, 4 keys not working on keyboard
I spilled sugared coffee on my keyboard, now 4 keys not working. Will replacing the keyboard solve my problem?
    Guru:
  • 859 Answers
Simply stated, yes.
If you plan to do that, in the meantime you could also run the keyboard under a warm shower for a new minutes and then hang it out to dry in the sun. I'm not kidding. It will probably, that is probably, work just fine after that so long as all the water has dried and drained out and its not an IBM mechanical keyboard.
Regards,
Worldvet
Posted on May 24, 2008
  • Glenn Rogers
    Glenn Rogers May 25, 2008
    Please do not forget to remove it from your notebook first if you are going to clean the keyboard with warm water.
    Regards,
    Worldvet
How to fix keyboard problems after a coffee spill?
Replace the keyboard. Look up on ebay for a replacement.
Sep 14, 2014 | Toshiba Computers & Internet
Tip
Spilled liquid on Keyboard!
1. Purchase plastic keyboard cover. 2. Keep coffee etc. anywhere not near keyboard.
For spill, unplug keyboard. If non sugar liquid, invert keyboard, shake or tap gently. Wipe with lent free absorbent cloth while still inverted. If soda or coffee with sugar, pour 1/4 cup of clear clean (distilled the best) water onto keyboard (yes), Then invert. Let dry a minimum of several hours still inverted. I cheat with a hairdryer on low 6-12 inches. After keyboard is completely dry (and cool). Plug in after turning computer off, restart, test all keys, including shift, option etc. If keys miss or don't work buy new keyboard and cover! Aloha, Cliff
on Sep 27, 2014 | Apple 24" iMac Desktop
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
The keys do not work. My 2 year old spilled coffee on my laptop. Some keys worked but most on the left side keys didn't. I tried to clean the keys with a cotton swab and alcohol. Now none of the...
Best solution now is to find a replacement keyboard. They are very easy to replace. Also, could use an external keyboard. Not ideal but it works.
As for cleaning, if the coffee had sugar and cream there is not much you can do.
There is one option I hesitate to suggest. Take the keyboard off, run it under warm water and let it dry for a few days before putting it back. May or may not work.
May 25, 2011 | Toshiba Computers & Internet
If I hold down shift and press cvnm or e it doesnt type anything.
Replace the DEFECTIVE keyboard. Somebody may have spilled pop or coffee-with-sugar onto those keys.
Apr 01, 2011 | Sony VAIO VGP-WKB1 Keyboard
Some of te buttons on my keyboard are not working. It started wit it not working occaisnly but now does not work at all.
Did you recently spill something (coffee with sugar, soda-pop) into the computer?
As it dries out, the sugar starts to conduct electricity.
It's time to take your computer to a qualified technician, to replace the keyboard, because there is no way to "clean" the keyboard.
May 30, 2010 | Dell Studio XPS 16 Notebook
Some of the keys work and a few just dont ....I am not sure if the keys are broken....stuck or if my laptop has been dropped or something.It's just not working right
Did someone (not you, of course) spill something (sugar in coffee, tea, cocoa, soft-drink, beer) onto the keyboard? If so, as the liquid dries, the sugar dries up, and gums-up the works.
Get a qualified technician to replace the keyboard.
Apr 10, 2010 | Toshiba Satellite A135-S2276 Notebook
Coffee spilled on adding machine
The sugar is the problem, To solve it you must disassemble the keyboard wast it out with hot water let everything dry then reassemble. an awful lot of work for a inexpensive calc.
DickyO
Sep 21, 2009 | Sharp EL-1801P Calculator
Spilled coffee on keyboard some keys work some don't {hp pavilion 8125nr
This happens to me all the time :)
Try washing the keyboard in the dish washer. Usually, if there was not too much sugar involved it can be saved this way. Just make sure it's fully dried before you plug it back in.
Jul 27, 2009 | HP (P1336-69001) Motherboard
I spilled coffee over keyboard and now the keyboard is not working properly is there a way i can fix this i have left it for 24 hours and it seems worse
No, keyboards are too cheap to justify opening up a keyboard and attempting to clean it, especially if you drink your coffee with sugar, the sugar works at the etchings, and when you attempt to clean the traces, you wipe them away rendering the keyboard useless.
Jul 22, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
254 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
