Question about Lexmark Optra T610 Laser Printer
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
  • Lexmark
    Lexmark Sep 29, 2010
    The error indicates a failure in either the Hsync signal or with the mirror motor unit of the printhead. This usually requires a service call. What you can do: Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge devices or power strips even if the printer has worked on this device before. These devices can cause low amperage and may cause the printer to give false errors. Otherwise, if problem continues, contact Lexmark technical support (if printer is under warranty) or your local authorized service provider for assistance.
  • 2,296 Answers
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Posted on Nov 16, 2010
How to fix Lexmark T632 924 service Fuser error
924 is an open thermister error. The thermistor controls when power is actually applied to the heating lamp on the fuser. I used to have this problem with other Lexmark models and was able to replace the thermister itself. The thermister is located on the top cover of the fuser. If you have a real Radio Shack near you they should have them. I believe that the temperature should be around 400F.
May 08, 2015 | Lexmark T632 Laser Printer
How to replace mirror motor assembly lexmark t632 or printhead
I would suggest you contact a certified Lexmark trained technician to replace the printhead or you may contact Lexmark Technical Support.
Oct 12, 2011 | Lexmark T632 Laser Printer
Is there a guide or video that shows how to replace the printhead on a Lexmark T632 printer?
there is no print head on a T632
Either you change the drum, or the maintenance kit whisch supplies the method to change the different elements
Feb 09, 2011 | Lexmark T632 Laser Printer
I have an error message that says 924 service Fuser Error What does that mean?
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T632, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser yourself which costs around $350, so I think you would be better off getting a new printer unless you find a second hand fuser on Ebay.
Sep 03, 2010 | Lexmark T632 Laser Printer
934 service Printhead error
head may be damaged, try reinstalling software first before you try to send the head repaired locally. may have to buy a new head if its dot matrix.
Jun 24, 2009 | Lexmark T632 Laser Printer
Lexmark T630 has a 933 error. I have replaced the
933 - Mirror Motor - Locks/Lost Hsync* (*Horizontal Sync) Have you gone through this exercise yet: These errors usually indicate a failure in the HYSNC signal to the printhead. Check the continuity of the cables connected to J5 and J4 on the system board. If incorrect, replace the defective cable. The voltage at J4-1 measures approximately +5 V dc. If incorrect, replace the system board. The voltage at J5-7 measures approximately +24 V dc. If incorrect, replace the system board. If correct, replace the printhead assembly. Don
Apr 30, 2009 | Lexmark T632 Laser Printer
Optra t610 error 935/933/934
replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
Jan 03, 2009 | Lexmark Optra T610 Laser Printer
I have a Lexmark T632 that is used very often. Constantly printing over 1000 pages daily and I always get the error message Print head Error 934 - Lost Lock condition but once I shut down the printer and...
These error codes indicate a problem with the mirror motor circuit in
the printhead assembly or the mirror motor cable to the system board
cable or system board assembly. Check the continuity of the mirror
motor cable connected to J5 on the system board. If incorrect,
replace the cable. The voltage at J5-7 measures approximately
the FRUs in the following order:
• System board
• Printhead assembly
Dec 10, 2008 | Lexmark T632 Laser Printer
Print head replacement lexmark t632
You will have to remove the top cover, both side covers and the rear door and redrive to get to it. Once these covers are removed you will need to remove three screws to release the printhead and disconnect a couple of cables.
I usually have to clip a couple of zip ties and use needle nosed pliers to get the cables out.
It is do-able if you are patient.
Nov 24, 2008 | Lexmark T632 Laser Printer
Lexmark Optra T610 Laser Printer Logo
1,133 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
