Question about Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist Watch
Have older Tag Heuer Ti5 Kirium titanium watch that needs a new band. Can you help me?
SOURCE: Tag Heuer Formula 1 Mens watch
This is not a cheap watch....You should send it to a qualified watchmaker or the manufacturer. This watch has to have a pressure test to insure it's water tight. This may require replacement of some or all of the gaskets in the case.I would never recommend that this is something that you should try to do yourself.You would be amazed at the money I make do to improper replacement of JUST the battery.
Donald McPherson, Certified Watchmaker AWCI
www.finewatchmaking.com
WWW.AWCI.Com
Posted on Oct 25, 2007
  • 2501 Answers
SOURCE: My alarm does not sound on my Tag Heuer Kirium F1?
Have you a copy of the manual?
If you have, then you will see that it can be turned off (last page), is this likely to be the case?
If you need a copy, go to their web site "tagheuer.com", select "watches", then "tag heuer formula 1", then "man", followed by "Tag Heuer F1 chronometer" and finally you will see on the right a menu, select "user manual".
This seems to be a generic manual that cover both the chronometer and alarm version of the watch.
If these are not the correct instructions for your watch, opposite the "user manual" menu is a search box, put your watch model in this and there should be a user manual with it.
If not look at a similar watch for a generic manual.
Posted on Jan 27, 2010
mcdevito75
  • 1970 Answers
SOURCE: Where can I find a replacement band for my tag
mcdevito75 here, BEST BET, Look for a small watch repair shop in your area for a replacement band, or you may want an orginal band to maintain authenticity, a band straight from Tag Heur can be ordered.
Posted on Jul 10, 2010
escapement
  • 2334 Answers
SOURCE: How to adjust the steel band on my Tag Heuer
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
gemineye61
  • 831 Answers
SOURCE: need a replica watch strap for my tag heuer watch
Best place that I have found:
http://www.watchbands.com/category.aspx,,categoryID,,25
Posted on Aug 18, 2010
40/8108,how to set up this watch?
Here is a link to a manual that shows how to set up the watch:
TAG Heuer Kirium F1.pdf
Jun 05, 2014 | Tag Heuer Kirium Formula 1 Chronograph...
Tag Heuer Chronograph Problem
These are a top brand and any dealer should be willing to give you advice for free, drop in to a jeweller that sells them, and ask.
Dec 15, 2013 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
Where do I purchase extra links for my kirium band?
Contact Tag Heur Customer Service at 866-260-0460. They are open 9 AM - 6 PM Eastern Standard Time Monday to Friday
Oct 28, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
My dog ate the band on my aquaswiss swissport purple watch. where can io order a new one?????
You can call Tag Heuer and order a new band or you can try online sources such as ebay who sometimes sell them at a lower price.
Oct 19, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
What size band do i need for a kirium watch (rubber)
Distance between lugs (the place where the band gets attached to the watch) is the size of band. Get ruler and measure it. Rate me plz.
Mar 03, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
Jan 27, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
How do I get a steal band for my Aquaswiss Trex watch?
look for a tag store near by. if u cant find one most jewelry stores with a shop (not in a mall) can either do it there or send it out. sometime the band can be fixed
Oct 07, 2009 | Tag Heuer Kirium (CL1212.BA0705)...
What are the two digital displays on the top of the Tag Kirum F! for??
Use this link and read the info:
http://www.google.com/imgres?imgurl=http://image.vialuxe.com/Newsimages/1965_LRG.jpg&imgrefurl=http://www.vialuxe.com/News/Tag-Heuer-Tag-Tag-Heuer-Watches-TAG-Heuer-Kirium-Formula-1-Watch/315,870&h=260&w=315&sz=20&tbnid=mdhtEFEWdkvSlM:&tbnh=97&tbnw=117&prev=/images%3Fq%3Dtag%2Bheuer%2Bkirium%2BF1&usg=__PEFomHqQ5EXL6ulbCMX7La4FbWQ=&ei=pMuBSsytA4KsjAfZ3LmECg&sa=X&oi=image_result&resnum=7&ct=image
All that is one link.
Rate me, please.
Aug 11, 2009 | Tag Heuer Kirium Formula 1 Chronograph...
Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Aug 27, 2008 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist Watch Logo
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
