Question about Speed Queen AWS52NW Top Load Washer
Draining water from inside through center.
It's a SPEED QUEEN commercial heavy duty extra. Started to leaking water in much quantity through the agitator, I think through the seal kit. It's old washer, at least +8 years old.
My question is if it' s the problem, is it cheap to fix and not extensive nor special tools.
Please, answer me truly. Thanks
  • Anonymous Jun 01, 2008
    Yes i have the same problem Model KAW351. Tried removing agitator unable to. Is there a release mechanism that you must activate.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    It sounds like a tub seal and it's generally not an expensive job, but it can be labor intensive if you've never repaired one of these before. Replacing the tub seal requires the removal of the exterior cabinet, the agitator, wash tub rim, suspension springs, inner wash basket and the outer wash tub. The only special tool needed is a wrench that you use to remove the spanner nut on the inner wash basket, I believe. In addition, sometimes the agitator sticks on the older washers and can become difficult to remove. I cannot predict how this will be on your washer, but they can become damaged and also require replacement. You asked me to be truthful, so it's up to you in deciding if it's worth effort. If you post back with your model number I can get an idea of the washer's age and how it is assembled. It may be easier than we think. I'm giving you the worse case scenario, because I just don't know yet.
    Novelist:
  • 177 Answers
The tub seal kit is $85 USD, You will also need a drive bell kit$23 USD, you should replace the upper bearing $?, for a complete rebuilt I would also replace the brake pads all three, and the belt, maybe the pump if it doesnt come off easily. Plus what you break taking it apart, so we are looking @ least $150.
Yes you can do it yourself, you dont need the tub wrench if you can borrow a deep socket, its the drive bell seal tool you really need.
Please let me know if you have additional questions. the serial number will tell you the age first two digits are year next two are month, starts with and R, built in Ripon WI.
Posted on Aug 22, 2008
The water flowing into my speed queen is vert slow
The to ensure that the water valves at the inlets are fully open. If they are, then shut them off and remove the hoses from the supply to the washer. There is usually a small metal screen-type filter in the connection at the back of the washer for each hose. These may be clogging up. They can be carefully removed, cleaned, and reinstalled.
Sep 08, 2016 | Speed Queen AWS52NW Top Load Washer
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Good day, can you please help, I want to know what can be the problem. Our speed queen heavy duty washing machine leaks water when spining. The water leak is at the top of the outer tub where the clips...
The basics would be make sure it's clean, the outer and inter ring of this area holds and builds up dirt and debris over time, causing a bad seal, also has to spin and be balanced properly or it will leak a little. ...
Feb 26, 2015 | Speed Queen Washing Machines
Motor rund but drum dont spinon speed queen heavy duty washer
Fluid Drive clutch greasy or worn,
Pump blocked or drive belt too loose
Feb 23, 2010 | Speed Queen AWS75NW Top Load Washer
Vibration
With the age of the machine, although Speed Queen's are built like a tank, the suspension systems are one of the most worked systems on a clothes washer,so, that being said, I would check all related parts of the suspension system, springs,pivot,etc,.these parts do get tired, think of the amount of loads of clothes that you have run through the washer over those 15 years.
Good Luck !
Feb 14, 2010 | Washing Machines
I have a Mcgraw-Edison speed queen Heavy Duty dryer. We used it last night and it worked fine except there was alot of condensation inside the dryer with a little water coming out the door. Now this...
You may have a venting problem. Check outside to make sure vent is blowing good. It is possible that the motor may have went bad with all of the problems associated with a clogged vent.
Dec 02, 2009 | Speed Queen AES28AWF Electric Dryer
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Speed Queen AWS52NW Top Load Washer Logo
320 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
