Question about Canon EF 75-300mm f/4-5.6 IS USM Lens
Can i get a replacement front glass, scratched.
Canon DR-2050C Scanner gets verticle line down image
I have the same issue with mine and there are 2 image sensors on this scanner. 1 in the back that you will see when you open the front that has a meteal shield covering the top half, and one in the fold out front that faces the inside. These are the "glass" sections everyone is refering to. Problem is, they are plexiglass, not glass and mine has a tiny scratch in the lens that is causing the line. This could be your problem. find the lens and use a LED flashlight to inspect your lens for scratches. If its scratched like mine, the entire module has to be replaced to fix it. The canon part number is MH7-7038 and they range from $125-$160 if you replace it yourself. The one in the front is easy to do, but the back one is a little tricky. Hope this helps. E. Alexander, Field Tech, Cummins-Allison
Oct 26, 2009 | Canon DR-2050C Path-Through Scanner
I have a 3 inch scratch on my plasma tv that happened in a move. I think it is a glass screen. Is there any way to cover or fill this scratch. It isn't very deep but it bugs me that I can see it.
You must determine whether or not the scratch is on a protective fromt screen or the panel itself. I don't know your specific model, but some of the LGs have a front glass behind which is the actual panel. If that is the case with yours, you can replace the front glass. If it is only the panel, then there is no way to repair other than replacing the panel which is VERY expensive.
If you wish to try something, go to a local auto parts store and purchase a windshield repair kit. This will contain an optically transparent epoxy that can fill in the scratch and make it at least less noticable similar to filling a scratch or crack on a windshield.
Dan
Mar 06, 2009 | LG 30FZ4D TV
Small scratches on my plasma ,
There are 2 possibilities that may work. I can't state for sure as I don't know the make and model.
1) Some sets have a protective front "glass" that resides in front of the actual panel. That protective sheet can be replaced.
2) If it is the panel itself, the repalcement cost will likely be more than replacing the entire set. You can try using a windshield repair kit to fill in the scratch. Since the material contained in that kit is optically the same as glass, the scratch should be filled in and not be quite as obvious. This may not make the scratch completely disappear, but it should help.
Good luck,
Dan
Jan 22, 2009 | Televison & Video
Scratch
hello, if there is a scratch on your reflective outer glass panel screen, it can be replaced if you are handy with tools or diy i happen to have the screen removal manual for this tv model th42pz700u you dont have to dissasemble the tv just the outer front housing remove the back panel and theres some screws that hold the front casing on those come of and the front refelctive glass can be removed without any trouble or dissasembly of the internals just the front casing
you may need to find a selling as is plasma tv with a broken internal screen usually they are this way that outer screen dosent break easily so unless you want to pay 489 for this reflective glass part i would try and find a 'for parts or repair 42 inch pany' they will fit if they are the same size make sure the outer screen is not broken or scratched. hope this help
Nov 29, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
Rca-r56wh76y851 tv front glass
Is a protector plastic?...If yes, Sure, you can replaced. I recommended open the front cover and use tape meter. Go to glass store and ask for plastic glass....You can use this plastic. If are you talking about lenticular screen, this is expense new (over $385) .Try to find a close TV shop and ask for used replacement.....That's work !!!
Aug 10, 2008 | RCA P52926 52" Rear Projection Television
HHP IT3800 don't read well, when the front red glass is scratched
Get a polishing solution, like for CD and DVD's and clean the glass, that should impove dramatica.lly the performance
Jun 05, 2008 | HHP IT3800 Handheld
SCRATCHED TV SCREEN
try contacting www.tvscreenprotectors.com
They deal with damaged tv screens
Apr 11, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Scratches on Plasma TV Screen
My daughter scratched my TV Plasma with a Pen - It now has scratches. What can I use to get rid of these scratches.
Mar 26, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Canon EF 75-300mm f/4-5.6 IS USM Lens Logo
46 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
