Question about KitchenAid KERC607 Electric Kitchen Range
It is beeping every 30 min. The error message on display says F0E0. Any ideas?
    Sergeant:
  • 270 Answers
This is a link to your manual:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209754287.pdf
Here are your error codes:
http://www.repairclinic.com/0078.asp#KitchenAid
good luck and don't forget to vote!!!
Posted on Sep 28, 2010
Dr error message
Hello Herb Reinhart - If the range previously displayed DR and now showing F11, it typically indicates that the unit has detected a shorted keypad. Since you have already try resetting the unit by unplugging it and issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
F0E0 error code in Whirlpool self cleaning oven......what does it mean?
Analog to digital failure.
Disconnect panel for 30 seconds
If error re-appears...then replace control
Hope this helps...
Jul 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My EEE PC1015 PE keeps giving error message "Reboot & Select proper boot device of Insert Boot Media in selected Boot device & Press a Key." Also, beeps continuously for approx. 1-2 min then stops...
in situations like this you just must download the correct manual and reinstall the OS,if you have no disk choose a different OS some are virtually cost-free
Aug 29, 2010 | ASUS Eee PC 1000H Laptop
Whirlpool Accubake F2EO
F2E0 is shorted key pad. You will need to replace keypad if the power shut down and reset does not work.
Mar 09, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Feb 13, 2009 | Whirlpool Washing Machines
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Error message on print screen of 114 08
The book says nothing about this error except turn off machine for 30 seconds and try again. If this dosen't work try unplugging machine, removing the batteries and then restart. CAUTION THIS WILL CLEAR ALL MEMORY!
DicktO
Jul 29, 2008 | IBM Wheelwriter 30 Typewriter
E6 Beeps/vibrates every 30 mins
it just reminds u about any missed calls or unread messages.
Jun 05, 2008 | Motorola Mobility ROKR E6 Smartphone
Electrolux 1087 E90
call frigidaire for factory service or have the dealer replace it
May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Oven won't stay on and give an F error message
Disconnect the power. Disconnect the sensor harness from the control. Measure the sensor resistance (white leads). The resistance should be 1080 ohms at room temp. If the sensor is open the resistance is usually over 2900 and you get an F3 message. If the sensor is shorted the resistance is usually less than 950 ohms and you get an F4 error message. Also look for damaged harness terminals if not a bad sensor.
Aug 31, 2007 | Ovens
KitchenAid KERC607 Electric Kitchen Range Logo
260 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
