Question about LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo) Burner
Just bought and installed LG internal/GH22 uploaded the super multi drive disc for windows. I'm using XP home edition windows media player say " no CD or DVD burner" Help! Tommy
  • 1 more comment
  • churchorgans Sep 28, 2010
    Hi...I finally got to the system tools and uninstalled CD/dvd...re-started 3 times and still no CD burner detected on windows media player
    Tommy
    so sorry...where is the "BIOS" and "SATA" It is internal and just plugged it into the old sockits
    Tommy
  • churchorgans Sep 29, 2010
    Hi...I shut everything down and removed the new LG and there are no switches on it's back by the plugs
    Tommy
  • 10,594 Answers
Assuming this is the only cd drive you have, just go to the device manager and remove/uninstall anything under "DVD/CD Rom Drives" then restart. It should get picked up and recognized properly. It took a couple of restarts to work. For reference, if only have the LG GH22NP20 installed, what appears in device manager are 2 items... (1)HL-DT-ST DVD-RAM GH22NP20 SCSI CdRom Device... (2) KU1051Q EAG855E SCSI CdRom Device... In case you have multiple cd drives, this should help.
Posted on Sep 28, 2010
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Sep 28, 2010
    OK, go to the BIOS and activate the relevant SATA socket to which it connected DVD
    writer. At reload windows detected a new device and all is well; No driver is
    needed.
    OK, so this dvd writer has IDE connector instead of Sata connector.
    Bios is intiial software that gets load when you turn On computer.
    Check at rear of dvd writer, you will see master, slave section pins, plug little connector on master setting and try again so your computer recognize it and if computer already has another dvd rom then plug little connector at slave position.
    Shahid Electronics Sep 29, 2010
    Please click this link to read out jumper settings for master/ slave drive that I'm talking about.
Purchased and installed LG GH22 Super Multi DVD Rewriter. It reads/burns data CDs perfectly and burn/plays back music CDs. However, video files come out with choppy picture and badly distorted audio. Have...
get the dvd rewriter to record at its slowest speed.you do this through the software,which im not familiar with sorry.also usr quality media eg verbartim or tdk
Mar 27, 2011 | LG Electronics 16x DVD and 48x CD-ROM...
I'm trying to install an LG GH22 22x Internal Super Multi DVD Rewriter drive on my computer, because the old CD drive it was bought to replace quit working. However, I can't get this one to even start...
there is no driver necessary , check out that you have provided the proper jumper settings and connect the data bus correctly , press it tightly . that will solve your problem . if you are using more than 1 device on your bus then the jumper settings are quite necessary.
Jul 04, 2010 | LG GSA-2166D DVD RW Dual Layer Burner
LG GH22 LS50 (Sata Dvd Writer) Will not write dvd discs
What software do u use to write DVDs on both PCs...
if they are different then that may be the issue....
dont spoil the DVDs....
try DVD RW disks...that way you can erase them later...
i too have the same DVD writer, not had any issue in either XP or Win7....i have dual boot and have made many movie DVDs using both OS...i use Nero and Power2Go of LG(the install disk that came with the LG DVD writer has this great software...."LG Power tool")
try this tool...it should work...
the inbuilt DVD creator in Win7 has some issues with DVD creation....due to non compatibility of graphics card and display drivers (WDDM)....+ you may not have the correct codec required to burn DVDs.....
get the FFDSHOW codec from google.... and install it...shutdown and restart and then try...
let me have a feedback pls...
reg
May 04, 2010 | LG GH22LS50 DVD-RAM Burner
No sound with my LG Portable Super Multi Drive
It will not work properly. If you contact their support they will just try to get you to pay for an upgrade of the software. Take it back to the store and get something else.
Mar 06, 2010 | LG Electronics 16x DVD and 48x CD-ROM...
Need Driver for LG GH22 22x DVD Drive
Remove the new drive -- and look VERY closely on the back.
You'll find a "two-by-four" grid of gold pins, probably with a black "jumper" between a pair of pins.
Look closely at the labels above each pair of pins:
* MA(ster)
* SL(ave)
* C(able)S(elect)
Move the jumper from its current position to one of the other pins.
Reinstall the drive, and reconnect the power and data cables.
Check that the other-end of the data-cable is snugly connected to the motherboard.
Windows should now "detect new hardware", the next time you start-up.
Dec 28, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
I just had an internal super multi dvd rewriter GH22 by LG installed, but don't know how to use it. where can I get some instructions ? Why won't it play my music cd's?
in order to play music, it has to be pluged into directly into your sound car iva a special 4 pin conector (only one drive can be pluged in at a time). copying files is easy, just drag them into the drive folder just like copying stuf to a flash drive. but instead of pushing the eject button, right click in the folder ans select eject. this will start the copy procedure. to copy music use the rip tab in windows media player. for copying dvds you will need a third party program. i recomend VLC media player, it's available free from download.com
Aug 14, 2009 | LG GH22NP20 22x Internal DVDRW Retail Kit...
LG GSA-E60L doesn't work...
Disc drive has nothing with drivers it works in almost any operating system...check the power and data cables
Feb 03, 2009 | LG SecurDisc 20x External Double-Layer DVD...
LG GH22 dvd writer - not reading
I had the same problem with the GH22 Internal drive on vista. Assuming this is the only cd drive you have, just go to the device manager and remove/uninstall anything under "DVD/CD Rom Drives" then restart. It should get picked up and recognized properly. It took a couple of restarts to work. For refrence, I only have the LG GH22NP20 installed, what appears in device manager are 2 items... (1)HL-DT-ST DVD-RAM GH22NP20 SCSI CdRom Device... (2) KU1051Q EAG855E SCSI CdRom Device... Incase you have multiple cd drives, this should help tell em appart. Enjoy. IDK399
Jan 20, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
Cd driver
you do not need a driver cd for installing the driver for cd/dvd drive if you are using windows xp or any of its higher version as all the hardwares are auto detectable in these operating systems....go to device manager and scan for hardware changes
Dec 29, 2007 | LG Electronics 16x DVD and 48x CD-ROM...
LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo) Burner Logo
111 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
