Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
After about 15 to 30 minutes, engine starts pinging (for a few seconds) then dies
    Scholar:
  • 150 Answers
Not familiar with tecumseh lawn boy. Lawn boys I worked on were 2 stroke, if this is the case the crank seal is sucking air after engine warms up. New seal would fix. If you can't do it you're self may not be economically worth it.
Posted on Sep 29, 2010
What causes my 2002 avalanche to die after it runs for a few seconds
Loss of fuel pressure, loss of spark is likely. What you need to do is have the fault codes in the memory of the engine control computer. You will need an OBD2 fault code reader, it hooks to the diagnostic link port under the dash in front of the driver.
Jan 13, 2017 | 2002 Chevrolet Avalanche
IT WILL STaRT , RUN FOR 1 MINute AND SHUT OFF BUT WAS rUNNING WITH COVER OFF BUT NOW HAS STOPPED THAT IT WILL RUN FOR 20 SEcONDS AND SHUT OFF
What would cause 1995 Chevy blazer to run for 20 minutes ...
answers.angieslist.com > Auto > Auto Repair & Service
Mar 30, 2014 - For example, can you start the car cold, it will warm for 20 minutes, and shut ... While not a car, my Motorcycle (also fuel injected) would run for a little bit and shut off. The issue ... Answered 1 year ago by WoWHomeSolutions.
Car starts and it shuts off/loses power - CarGurus
www.cargurus.com > Questions > Audi > A4
CarGurusJun 20, 2013 - Car starts and it shuts off/loses power - I have a 2003 Audi A4 Turbo.93K on it. ... \n check out these few options 1. loose or faulty electrical connections at, .... After drying it for a few minutes and cleaning with a dry cotton cloth, I have ... you can't fill your car while its running the gas tank is a vacum while its ...
Car starts then dies in a few seconds - CarGurus
www.cargurus.com > Questions > Ford > Crown Victoria
CarGurusFeb 3, 2014 - Car was running fine, and then engine stops. ... 1 out of 1 people think this is helpful. ... my car will start run for a second an shut off . ... under load, dies,starts 15 minutes later, runs fine then stumbles and dies again 3 answers.
Chevrolet Silverado 1500 Questions - Engine Shutting off ...
www.cargurus.com > Questions > Chevrolet > Silverado 1500
CarGurusMay 20, 2015 - Engine Shutting off after about 10-20 seconds on 2004 Silverado ...When the engine is hot, two things occur: (1) thermal effect on .... my 2000 chevy silverado just randomly die then it will start back up idle .... It will run fine for 15minutes. ... run down behind or beside the powersteering pump, that the car will ...
Jan 06, 2016 | Cars & Trucks
My vehicles shuts off after 3 three minutes of use or when its idling after first initial start but starts perfect when the engine is heated up. Can you help me with this problem?
CarGurusFeb 3, 2014 - Engine turns over fine and starts, but stops in a second or 2. ... Good fuel pressure, starts, runs for about 7 seconds, dies after a sudden drop in fuel pressure. ...starts 15 minutes later, runs fine then stumbles and dies again 3 answers ... I drove carhome shut off and next morning would not start, but will turn ...
94 camry le 4cylinder starts when cold, shuts off .
Nov 23, 2015 | Cars & Trucks
Hi there . I'm having problems with my 1997 Opel corsa utility . It starts and idle smooth but after about 20 seconds it splutters and die , if I press the petrol it starts to splutter and die . Usually it...
I'd guess: not enough fuel flow. could be a fuel filter, fuel pump, fuel pump relay, fuel pressure regulator. No check engine codes? I would think there should be some that would help diagnose.
Mar 04, 2015 | Opel Corsa Cars & Trucks
Engin wont stay running after it starts
How long does it run? A few seconds or minutes? Sounds fuel related. Generally rebuilding or replacing the carburetor will fix it if it starts and dies after a few seconds. If it runs for a few minutes then we need to look at something else for the issue
Jan 15, 2014 | Tecumseh 5hp Engine Snow King Mtd Blowers...
2003 Jetta starts for a second and dies after turning off car after drivena few miles
have your alternator checked,it may not be working and is not charging your battery,thats why it dies so fast and won't start again.
Dec 18, 2013 | 2003 Volkswagen Jetta - Sedan, 1.8T -...
93 toyota pickup 4x4 it will stay running after I turn it on to start it up, it starts up then after a few seconds it kills
if I'm reading this right...
... the engine starts and dies within a few seconds.
... you jumpered the fuel pump test connector and it will keep running.
... you smell fuel after trying to re-start when it dies.
Disconnect the plug to the cold start injector. Even if you have an issue with the engine running then dying after a few seconds after doing this, if you don't smell fuel after disconnecting the cold start injector and try to restart it, the cold start time injector time switch may be failing.
Buy a can of starting fluid and have someone start the engine then spray short bursts of the fluid around all the intake fittings. If spraying the fluid in any particular area keeps the engine running, I'd start looking for leaks around that area.
It does sound like an AFM or COR issue considering it dies after a few seconds, but the fuel smell when trying to restart the engine may be a separate issue that needs corrected / isolated first.it will keep running.
Mar 30, 2013 | Cars & Trucks
Starts but takes a few seconds to start
Hey there jonablac,
well if it starts and then takes a minute to start up all the way from trying to die or cut out the you need to turn up you engines idle speed or if it starts then dies and won't start again wait a couple of minutes and then try to start it back up beacuase it could mean your engine has gotten a little flooded or you don't have you vehicle's engine idiling speed adjusted fast enough.
I hope this helps,
Shadowy Ace
Aug 20, 2010 | 1999 Chevrolet Silverado 1500
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
430 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
