Computer won't boot up. Error code 0146 and error code 2000-0146
    Scholar:
  • 181 Answers
Good day.
Error code 0146 basically refers to a hard drive. This means your computer is not detecting properly your hard drive or your hard drive itself is defective.
Let's first isolate the problem. Go to your BIOS setup (Pressing F2 upon power on) and check if your hard drive is properly setup in your BIOS. Make some necessary adjustments and save setting.
Turn-off your pc and try to check the data cable and the power cable is properly connected to your hard drive. You may also try re-seating the data and power cables - remove first and then connecting it again to the hard drive. Loose cables may cause problems. Power on the pc.
If you still receive the same error, then you need to replace the hard drive with another one.
Good luck.
Tedmac
Posted on Sep 29, 2010
1000-0143 Dell error
This error code is related to " Drive Smart read command failed."
POSSIBLE LINK to fix: -
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=dhs&docid=266787#HDD
Remove and reinstall the Hard Drive for the error codes:
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
Please see the Service manual for instructions on how to remove and replace the Hard Drive. Be sure to remove and reinstall the cables for the hard drive if you are on a Desktop Computer.
After reinstalling the hard drive re-run the diagnostics if you receive the same error code Contact Us.
Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
  • 1000-0146
  • 2000-0146
Mar 04, 2012 | Dell Latitude D810 PC Notebook
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
2000-0146 error and oxc0000ed
Hard drive failure. If the system is under warranty, contact Dell for a replacement drive. If not under warranty, you can get a new drive here:
www.newegg.com
Jul 28, 2010 | Dell Inspiron 1501 Notebook
Does anyone know what code 0146 means?
This error code is related with the hard drive problem. There is a possibility of hard drive failure.
Mar 12, 2010 | Dell Inspiron 13 Notebook
Erorr code 2000-0146 ntldr missing ???
i could give you a long technical solution but the best is to re-install windows and select repair installation ,, it should fix the error ;)
Mar 10, 2010 | Dell Inspiron 1525 Notebook
Getting error code 2000-0146 on my computer inspiron 1318
i have a error code 2000-0146. is there a solution to this besides replacing the hard drive. can data files be safed??
Feb 19, 2010 | Dell Inspiron 1318 Laptop Computer PC...
I get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Dec 11, 2009 | Dell Computers & Internet
Dell Inspiron 1521 Error Code 2000-0146
It means "DST Log contains previous error(s)."
Dell Support says “If the diagnostic test reports one of the above errors, refer to Dell Troubleshooting Wizard: "Hard Drive Fails the Diagnostics" Wizard ID: 324398”
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=79E54961218510CBE040AE0AB5E158B6&treeid=324398
Dec 05, 2009 | Dell Inspiron 1521 Notebook
Error code 2000-0146
I had the same problem and came across the following solution that worked for me as well:
Re: windows Vista will not start 18 Aug 2009 07:28PM I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
Aug 03, 2009 | Dell XPS M1530 Laptop
2000-0146 is indicating a hard drive failure which is why it won't boot.
Jun 20, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
1,305 people viewed this question
David Payne
David Payne
