Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Sony Grand Wega 60", TV shutting off
Having an issue with our tv, It turns off for no apparent reason,like most of the other complaints, But the power light stays green, no blinking of any kind, just a constant green light! Is that still the lamp, or something else?
    Problem Solver:
  • 7 Answers
Most likely the lamp is dirty and/or going bad. I had a similar issue and was able to take out the lamp, clean it and get another 3 months of use before it totally crapped out. I replaced the lamp this week and now it works like new.
My advice is order the cheaper Phillips made replacement lamp.
Posted on Jun 25, 2008
Well I'm not totally sure if it's fixed, but I used an air compressor to blow out the dust, and so far it's working fine!
Posted on May 26, 2008
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My kds-r60xbr1 sony wega projection tv is blinking green then red and wont go on how do i fix this problem .i also just replaced the bulb about 3 months ago.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Power keeps going on and off
Model number posted in question that is KDF-60SX955 shows it is Sony dlp tv, if tv shuts down and turns On itself then reason is weak lamp that is near to end of its working life and need to be replaced to fix this issue.
Lamp replacement procedure is written in user manual and its easy. Please buy Sony original lamp for good quality picture in tv.
Let me know if you have additional question.
Thanks.
Apr 18, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony 60 inch tv. Sound & picture goes out after turning on. What's wrong with it.
my tv powers up for about 1 minute and then shuts off what could be the problem,
Apr 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
The tv repeatedly turns on then off
First area to check out is the power supply of the set.
Jun 14, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a 60' sony wega r60xbr1 i just had a new light engine installed last night the tv was never turned on afterwards . I turned it on the screen come on shut off imediatly the red led flashes 4 times...
LOOK IF YOURS IS A SONY I had a sony grand wega 60 inch with the same problem as many tv turns on shuts off the red led FLASHED 4 TIMES. it is a heating issue if one of the three fans inside are not turning when the tv is on even on the first few seconds of turning it on the tv will send a fault code of four flashes . Then the tv shuts off so it wont burn its self up or damage the optical block. all with this same problem of 4 flashes take a flashlite and make sure your fans are turning if not that is your 4 flash problem. I hope this helps someone and if it does i have done my job .
Dec 29, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony grand wega kdf-60 won't power up
It's likely to be the lamp Sony p/n# A-1052-675-A which is a generic Xl2100 which you can purchase from companies like DLP Lamp Source. http://www.dlplampsource.com/
If you're not real sure about doing this have a tech come out and do it, it's an in-home repair.
Bill
Nov 21, 2007 | Sony Grand WEGA KF60WE610 60" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
192 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
