Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
My DI-624 wireless routers is currently without password protection, so how do I change it to a password protected sys if I do not know any of its current settings???
    Problem Solver:
  • 17 Answers
Log on to the router, check status for more options
Posted on Sep 28, 2010
  • Ken Mosely Sep 28, 2010
    Thanks for the suggestion, however when I attempt to log on to the router with the IP address it asks for the username and password all of which I do not have. HELP.......
  • ragemonkey18 Sep 29, 2010
    If you never put a password or user name into the fields it is blank
Password protect wireless access
You'll need to access the administrator web page for your router, and then set a security key (password) for wireless users.
For step-by-step instructions for setting up security on the D-Link DI-614 router, see:
http://technicallyeasy.net/2010/10/how-to-secure-d-link-di-614-wireless-router/
Sep 04, 2012 | D-Link 2.4GHz Wireless Router DI-614
Wifi protected setup
login to your router from a browser it may be 192.168.0.1 or 192.168.1.1
go to wireless then at the bottom security dropdown box select wpa2-auto and setup your password for your wireless.
Feb 23, 2012 | D-Link AirPlus Xtreme G DI-624 Wireless...
Does the d-link airplus xtreme g model DI-624 support WPS?
yes there is RESET or WPS button for RESET all settings to factory defaults. For that press RESET/WPS button for 1 seconds it is in the back side of router. Then all settings defaults . You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 03, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
We reset the d-link di-624 wireless router and now it will not let us sign back on without the username and password which we do not remember. how do i factory reset the router?
Hi, when you reset your router the password is reset to default, and that default is admin admin. And to reset it, at the rear is a small hole in the hole is a button, remove from the power, and depress the button for a few seconds, then connect the power and try to logon again with your browser using the default settings.
It is also all explained in your user manual link below...
http://www.retrevo.com/support/D-link-DI-624-Wireless-Routers-manual/id/420ci368/t/2/
Aug 18, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-624 always lost connection after use about 10mins. to 20 minutes
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 16, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Connection drops down
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have a DI 624 wireless router that I never set up a password. I do not want my neighbors to run off mine. How do I set this up now?
First connect your router to computer with ethernet cable.
Then you can access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to wi fi security set your WEP code it is your security key to connect wi fi network.
Change it and then save settings and restart router.
Let me know if you need more assistance.
Thanks
Oct 12, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
How can I reconfigure my access point on my DI-624 to 802.11a?
First press reset button for 10 seconds it is in back side of router.
Then connect router to computer with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
then you can see configuration page.
Enable DHCP if you want to get ip from router for your LAN.
Go to wireless enable it .
Then enable wi fi security wep security then enter WEP key it is your password to connect internet .
Then save settings and restart router.
Thanks.
Oct 01, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link AirPlus Xtreme G DI-624 - Setting Wireless Key
You don't need any software, no. All you need to do is login to the router (usually 192.168.2.1 or 192.168.1.1 for D-link) and configure the wireless security (including the key)).
May 25, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
149 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
