Question about Cisco 7940 IP Phone
Why can't I connect my corporate Cisco IP Phone 7941 to a switch? I can connect a switch to Cisco phone switch and connect multiple devices. But the phone will only work when connected directly to the wall jack.
  • 2 more comments
  • Kevin Pawsey Oct 16, 2010
    Does it work when you plug it in to the wall? Is the switch PoE (Power over Ethernet), or are you using a powercube?
  • morey264 Oct 17, 2010
    Sure, when I connect the IP Phone to the wall jack it works just fine. However I want to connect multiple devices to the wall jack. When I connect a switch to the wall jack and the IP Phone to the switch it will not work. This leaves my only option to connect the switch to the PC connection on the IP Phone (which is a fast ethernet switch itself) but this reduces the gigabit ethernet at the jack to 100mps. I'd like to hook a gigabit switch to the wall jack and then connect the phone and PCs to it.
  • Kevin Pawsey Oct 17, 2010
    If the phone is a 7941, and not a 7941G, it is only ever going to be 100Mb/s anyway.
    When you say that the phone does not work, are you getting a display at all, or are you just not able to make calls on the phone?
    No display at all.
    Problem Solver:
  • 17 Answers
Connecting a hub or switch to the "PC" port on the back of the phone is not a recommended best practice by Cisco as the IP phone does not support spanning tree protocol.
Posted on Jan 11, 2011
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Oct 28, 2010 | Cisco 7910 IP Phone
I have cisco ip phones 7941 with the correct MAC and Number in the call manager , but the phone will not register
Make sure you have the phone configured as the correct device type in callmanager. Also, try and turn on auto registration in Callmanager as this will allow everything to register. Then go back and put the correct configuration the phone.
Jun 16, 2010 | Cisco 7940 IP Phone
When I plug the 7941 cisco phone up to our network on a POE switch, it responds with the message "Ethernet Disconnected", but when we plug another Cisco 7941 phone to the same line it works perfectly... We...
I would check your duplex settings. Often, if you hard code the duplex settings or have a mis-match; one end may not talk properly. Also, have you tested the wiring? Do you know the ethernet is okay for sure? TechRx, Inc. - techrxgb.com
May 12, 2010 | Cisco 7941G-GE IP Phone
CISCO IP PHONE 7941 -add background images (user preferences,
See Cisco's user guide regarding template modification and customization at http://www.ciscosystems.am/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960usrS.pdf
Jan 07, 2010 | Cisco 7941G IP Phone
Cisco IP phone 7941-- No power on the phone just a blank screen after I installed a headset, I did unplug the headset but is not coming back on.I also tried a new Ethernet cable but no luck. What can I do...
Is the phone connected to a POW (Power Over Ethernet)Cisco Switch? Check the model number of the switch with the Cisco web site www.cisco.com
Have you check whether there is power available on the switch?
enter "show power inline" at the command prompt.
Does the phone work without the head set?
Does the same thing happen when you plug in the head set on another phone?
Jun 18, 2009 | Cisco 7940 IP Phone
Doesn't answer calls or answers with speaker only
This is happening because your "Self-Cleaning" hookswitch is going bad. Since it's a carbon contact design, this will happen more and more frequently. I recommend sending your Cisco IP phones to IdacomUSA for repair and refurbishment. If you are the DIY type of person, we are also selling the pad and assembly for the Cisco hookswitch at $15 each (w/minimum order)
Jun 04, 2009 | Cisco 7940 IP Phone
CISCO 7941 IP PHONE disconnect you out after certain time
Unfortunately this is a very common problem with Cisco's IP Phones. It can be caused by either a faulty hookswitch or a damaged jack. Both of these problems can be remedied by contacting IdacomUSA.
Apr 06, 2009 | Cisco 7941G-GE IP Phone
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
449 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
