Question about Samsung SGH-D980 Cell Phone
I dropped my cell phone in the water and it got soaked wet. I dried it and turned it on it powered fine and after 30 seconds it restarted again and flashed a code on the startup screen the firdt time it was 1800004 and the second time 18000002 and the third time I turned time I started it it gave me the 18000004 again. The phone is Samsung SGH-D980 How can I fix the phone again, and if not then how can I salvage the information stored on the phone memory?
    Sergeant:
  • 270 Answers
Water and electronics are not compatible. that said, engineers are trying to find ways to insulate electronic from accidental water exposure.
The phone may appear dry on the outside, but i guarantee you there is still water on the inside. There may also be residue from the water making odd electronic connections and shorts never intended.
I urge you to dry your phone thoroughly
Use a hair dryer on low setting and let it dry and heat up the interior of the phone to evaporate the water.
Of course turning your phone on so soon after the incident may have doomed it, but most batteries are at 3.2 volts and components can withstand up to 7.5 volts before damage.
So dry it out, and good luck. If you have a warranty on the phone, let the geeks worry about it.
good luck and don't forget to vote!!!
Posted on Sep 28, 2010
  • Kirk Augustin
    Kirk Augustin Sep 29, 2010
    Most phone makers suggest sealing the wet cell phone in a jar of rice. The rice will **** the moisture out in a day. Heat will do more harm than good.
  • solovia_slvi Feb 11, 2011
    i tried doing so and it worked only the call and back and cam and volume bottun do not work ecxept that everything is working properly what do i do next ?
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
I got my lumia soaking wet in a storm how do I get it going again?
Er. idk. BUT i once dropped my phone in a bucket of water,
and my gf fixed it somehow.
... idk, what she did but it is POSSIBLE to fix it..
GL
Aug 21, 2014 | Nokia Lumia 920
Lg phone got wet and wont work
you got it went it wont work ever again to much water damage if you would of soaked it in rice after you dropped or whatever happened it would be fine
Jan 06, 2013 | LG Optimus 3D
My n900 nokia drop into water
Wet Cell Phone
Immediately remove the phone from the water, turn off the cell phone, remove the battery and SIM card. To dry out the cell phone put it in a large plastic bag with silica gel drying crystals then put it in a warm sunny place for several days or in front of a warm fan heater for several hours. Reassemble the phone and hope it will work properly again, but if does not work then it is faulty and you need a new cell phone.
Dec 12, 2012 | Nokia N900 Smartphone
Mobile in water not working now
Remove The Phone From The Water
The first step is to remove the phone from the water as soon as possible. The less time the phone spends submerged, the greater chance it has of being saved. The plastic covers that come with cell phones do provide some protection, but it takes a mere twenty seconds or less for water to get through these barriers and start causing damage to your phone.
Once you pull the phone from the water, remove the battery immediately. Cutting power is a crucial step when attempting to save a wet cell phone. There are many circuits inside cell phones that can survive getting wet, but only if they are not attached to a power source.
If your cell phone comes with a SIM card, remove it promptly. Do not heat the card, simply pat it dry with a soft towel, and put it aside until the rest of your phone is dry and back to working order. The good news is that SIM cards recover well from water damage. If for some reason, your phone doesn't survive the accident but the SIM card does, there are plenty of places that sell unlocked cell phones. Simply place your SIM chip into the new phone and go.
Salt Water Accident
Please take note; if your phone was submerged in salt water, you must rinse it in fresh water before the drying process begins. Even after the phone is dry, crystals can form and continue to cause damage and erosion.
Let Your Phone Dry
The next step you must take to save a wet cell phone is to allow the phone to dry. A great method in providing an optimum drying environment is to set the phone on the vent found on the back of a television set or cable box. The low heat emitted will gently dry your cell phone. Another trick to help speed drying is to place the phone in a bowl of dry rice. This will help draw out the moisture. You can also try placing the phone in a plastic baggie with a few silica packs that come in purchases such as shoes and electronics. Silica, like rice, absorbs moisture.
The important part of the drying process is to place the phone uncovered, in a warm, dry place and allow the moisture to evaporate completely. Another alternative is to place the phone on an air conditioner. The cold air will not damage the phone and the air from an air conditioner is very dry allowing the water to evaporate quickly.
Drying should take approximately three days at which time you can check to make sure the phone is clean and dry. It is at this time that you can re attach the battery and check if the phone works. If it doesn't, wait a few more days and try again. If the phone still doesn't work, take it to your local dealer, they may be able to repair it. Be prepared; getting a cell phone wet will void your warranty and most cell phones are equipped with a water damage indicator so the dealer will know the phone has been H2O compromised.
Alternative Drying Methods
There is an alternative way to save a wet cell phone that includes an alcohol soak. Alcohol is hygroscopic which means that it attracts water. Soaking your phone in denatured alcohol, or a 95% alcohol solution (regular rubbing alcohol is about 75%), soaks up all the water in the phone. When the liquid is dumped out, only alcohol, which will evaporate, remains. Make sure that the alcohol you use is denatured with only methanol as the chemicals found in other types can be damaging. This kind of alcohol can be purchased at your local hardware store. The alcohol soak may work best for phones that have been damaged by salt water or other liquids such as coffee.
Battery Caution
When attempting to save a wet cell phone, make sure you do not heat the battery as it could leak or even explode. Lithium-ion batteries are especially sensitive. In addition, many cell phones have plastic parts that can melt. Above all, do not try to save a wet cell phone by placing it in a microwave. You will destroy the electronic components and possibly the microwave in the process.
The above steps will help to save a wet cell phone, but be prepared. Often the phone will survive but the battery will not and the purchase of a new one may be in order. Good Luck!
Dec 05, 2010 | Nokia 2690 Cell Phone
Propel Dropped in water. Now the screen's blue and green
I put mine in a seal bag of uncooked rice for a day (to absorb the moisture) and then tried this solution and it worked!! Good luck
noavatar_s.gif N1XGamerGod
Rank: Guide
Rating: 78%, 14 votes
Okay heres what you do guys!!! Just happened to me today and I fixed it. Mine was at the bottom of a hottub for 2 days XD.
The power in the phone needs to run out
then, plug the phone up
wait about 30 seconds(download screen should be up and it is charging xD.)
Then Take the battery out and unplug the charge from the phone
Stick the battery back in
Wait about 30 more seconds
Hold down the Red Phone untill it turns on.
FIXED! YAYYYYY!
Aug 14, 2009 | Samsung Propel A767 Cell Phone
Mobile phone TM 506 Sony Ericsson get wet
You have to leave it to dry in a warm - not hot - environment with everything taken out so the electronics have a chance to dry properly.
You leave it for around 24-48 hours then see if it works, if it doesn't then you need a new phone
Jul 22, 2009 | Sony Ericsson W200i Cellular Phone
Dropped phone in water
SIM is probably bad or a little wet. but wait and let everything dry out and see if it works. Mine was soaked and the next morning worked fine. at least you probably won't have to buy a new phone.
Apr 28, 2009 | Samsung SGH-t229 Cellular Phone
WET CELL PHONE
Due to the complex inner working of cell phones once they are dropped in water they are considered useless.
Mar 07, 2008 | Motorola Mobility RAZR V3
Samsung SGH-D980 Cell Phone Logo
232 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
