Question about Fujitsu 36CS Air Conditioner
One of my indoor air handlers makes a lot of condensation and it's not even on. I was told that it might be the metering device not closing to 80% or it's not wired properly. For now the customer is keeping the indoor fan on and it;s not leaking. I need some help. -Steve Long
    Habit-Forming:
  • 156 Answers
If it's not running, the pressures would equalize over a matter of a few minutes. While your still flashing liquid in the metering device, it would not have a continuous supply of refrigerant. Even if the TXV was closed 80%, you would freeze the top of your coil because as soon as it meters through the expantion valve, your refrigeration saturation would drop off the chart and you woulf freeze as soon as it's metered. You need to got to the unit and amp out the compressor. Isolate it. You want nothing else but the power to the compressor. You could have a welded conactor. I have installed Fujitsu units and the comressors run very quite. Any noise around will over ride the sound of the compressor. Let me know what you find out.
Posted on Sep 28, 2010
What is the problem with running a 10 SEER condenser with a 13 SEER air handler other than efficiency? I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The...
as most ac units are capillary tube control not tx valve having matched units is critical. as for cost the condensing unit is much more complex and expensive than the evaporator.
Feb 14, 2015 | Amana Goodman R-410A Heat Pump Condenser 2...
Th5320u101 thermostat is flashing cool on and the
1) If the OUTDOOR A/C Condensing Unit is running BUT the indoor AIR HANDLER is NOT running, the problem could be as easy as changing the RUN CAPACITOR which is usually located within very close proximity of your indoor air handler motor. Ensure the ELECTRICAL DISCONNECT SWITCH is "OFF" and change the oval run capacitor (usually a 5 microfarad capacitor). This SHOULD fix your problem.
2) If the OUTDOOR A/C Condensing Unit is NOT running BUT the indoor AIR HANDLER is running, the problem could be as easy as the outdoor unit is not receiving the required 220 Volts AC. Turn the circuit breaker for the A/C Unit OFF and then turn it back ON. Ensure the circuit breaker SNAPS when you turn it to the ON position.
3) If the previous two steps to not apply or do not work, go to the paperwork supplied with the Thermostat. Almost every manufacturer provided a TROUBLESHOOTING GUIDE within their literature. Follow those steps. If their TROUBLESHOOTING GUIDE does NOT fix your problem, they should have a TOLL-FREE TELEPHONE NUMBER provided to contact their TECHNICAL EXPERTS with your problem(s). Call them and ask them what could be causing the problem.
Aug 31, 2014 | Heating & Cooling
Air conditioner fan is blowing but not air coming
If you mean that your OUTDOOR AIR CONDITIONER FAN MOTOR is blowing AND no air is coming out of the vents within your house, it clearly indicates to me that 1 of 2 things are wrong.
Either (1) your INDOOR AIR HANDLER is NOT running or (2) the INDOOR AIR HANDLER is running but your PLENUM has come apart.
If your INDOOR AIR HANDLER UNIT is NOT running, it could simply be the circuit breaker is OFF/TRIPPED and simply needs to be turned OFF; then turned ON. If that does not FIX your problem, then it is most likely your 5 micro-farad run capacitor for your indoor fan motor needs to be replaced. It will prevent your indoor fan motor from energizing. Worst case scenario would be your INDOOR FAN MOTOR has windings burnt and needs to be replaced. If your indoor air handling unit is equipped with a CONDENSATE VALVE CUT-OFF SWITCH, check to see if your drain pan is filled, thus energizing the switch. If the CONDENSATE VALVE CUT-OFF SWITCH is ENERGIZED, it will prevent the AIR HANDLER FROM energizing. That is the design and the reason for this valve.
Good luck.
Aug 26, 2014 | Heating & Cooling
Hi, I have a Rheem RHSA HM4221JA air handler with
Sounds like a relay inside the air handler is stuck 'closed'...
Oct 17, 2013 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Condensing unit will not come on. Unit is receiving electrical
1. turn your fan-on-auto switch on your thermostat to on
2. If the indoor fan works, then you have control voltage
3. If the indoor fan doesn't work, then you don't have control voltage
4. control voltage loss is either a blown fuse or transformer in the air handler, providing there's power available (circuit breaker, disconnect switch)
5. your condensing unit may not be receiving a call for cooling,but manually close the contactor with a stick or something non conductive. If it comes on then you have narrowed it to low voltage problem.Use a multi-meter to check for 24-28 volts present at coil of the contactor. If you have 24-28v, shut off the breaker or disconnect and check for continuity across the contactor.there should be about 20 ohms or so.If everything is still good, then check your capacitor for the rated micro farad. Sometimes a visual check will indicate a bad capacitor. A leaking or bulge on the top is sometimes present. Capacitors, as simple as they are they are frequently the culprit on non working condensing units. If you still can't figure it, call an HVAC tech or company. Adhere extreme caution when working on high voltage equipment. They can and do kill.
Aug 22, 2013 | Heating & Cooling
Hello, my HVAC is constantly freezing, even after freon is added. I was told that I have a leak in the coils and need to chance the air handler - the outside unit is about 10 years old - air handler about...
No you can not use a R-410 air handler with a R-22 condenser unit...the exspansion devices are different as the properties of the refrigerants are enough different that they are not interchangable...
Really your only choice is to replace the whole unit as it sounds like the exspansion valve or the orfice is partially clogged and it makes you constantly freeze up....
There are some things you could do to make it work at reduced capacity but it is way beyond what I could tell you through a computer...
heatman101
Sep 08, 2010 | Goodman CKL42AR42 Air Conditioner
Where is the filter located?
Hi, if this is a central system that is split up with the condenser outdoors and the air handler indoors it can be in the indoor unit it self or also it may be in the ceiling or wall near the unit behind a grill for the return air to flow back. Walk around and look for this grill. It is either up high near the air handler close to it, or low on a wall near it. If not out in the home, you will find it in the indoor unit only, nothing outdoors. If you remove a panel you should find it. Please keep me posted and please don't forget to rate me as I no you will be kind. I will check in on you a little later to see if you have found it.
Shastalaker7
A/C, Heating Contractor
Aug 28, 2010 | Goodman Heating & Cooling
After installing an air handler for a heat pump system, the condensation started. the air handler sets in an outside, unconditioned space. it is well insulated,and all connections sealed with mastic. it is...
Hi, on the refrigerant lines that are now condensateing, all you can do with them that are exposed are to wrap them with the black insulation made for this and make sure you have your condensate line connected to the air handler at the evaporator coil with either pvc or hard copper. I have never had to put mastic on any joint in case I had to take it apart for some reason. It sounds as though you have all of the lines insulated and that. I am not sure what type of insulation you used on the pipe, but it takes the armour flex. It comes in 10' sections. That's about the only fix there is. It has to have a condensate line from the indoor coil to outside to let most of the water run off. You are not going to be able to get rid of all of the moisture, but if the heat-pump is set up correct as for the super heat and sub-cooling, it shouldn't condensate that much.If it gets bad, try the armour flex and the black pipe wrap. This should help you a lot. Keep me posted .
Sincerely,
Shastalaker7
A/C & Heating Contractor
Jul 02, 2010 | Heating & Cooling
Air Handler: I have two 24V supply lines one from the transformer the other, I think from the condenser fan. Both wires are connected to a relay which operates the indoor blower. When the 240V power supply...
you have 24 volts from the indoor thermo to the transformer in the air handler then 24volts from air handler to the contactor when this is energized it goes to 240 volts to run the compressor and outdoor fan. Sounds like the contactor is not enegizing check the voltage at the contactor. you should have a schematic to show you the voltage.
Jun 21, 2010 | Heating & Cooling
We have 2. LA125HV w/ 1 condensing 1. air handler
I could not find a "fault code" list for the LA125HV but for thier Multi Split Units LG lists code CH7 (C7) as "Indoor Unit is Set in Different Cool/Heat Operation Mode." So maybe your air-handler tihinks it's in Heat mode will the compressor is in Cool mode, or vice-versa....
Dec 07, 2009 | LG LA125HV Split System Air Conditioner
Fujitsu 36CS Air Conditioner Logo
73 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
