Question about Samsung Heating & Cooling
Sensor in my Samsung Split Heat/AC indoor unit does not detect the remote control. Worked ok for 4 years. Tried a new remote and still didn't work. I can turn the unit on and off from the unit but need to use the remote for certain functions. Can't find anyone to service it. Thanks! Samsung AQ12ABMCF
  • 3 more comments
  • suwilson2 May 24, 2008
    Have tried new batteries and even a new remote. Didn't help. Guess I need to call someone to service the unit?
    Thanks. I have the service manual but it was of no help.
    Would try to fix it myself if it was an easy fix. Does the sensor in the unit run by battery or it is part of the electical system? If it is I would need to call for service.
    Thanks. I'll try the online form to find someone to service it. The online support didn't work. They don't recognize the model # for ac units. My guess is that they've dumped them. Just my luck!
    Thanks again.
  • Anonymous Mar 27, 2014
    remote control for Ambiance ac INDOOR UNIT AS12115V13H/I
  • Samsung Master
  • 13,433 Answers
The receaver is most likely broken?
Posted on May 24, 2008
What is the corrective action for error code 46?
Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor
Jun 23, 2015 | LG Art Cool LA240HSV 22,000 BTU SingZone...
I have samsung split ac 1.5 ton 2.5 years old when am switch on the ac the indoor unit is working when it tires to on the out door unit after 3 minute delay suddenly the ac is restarting but the out d
Make sure all of the pressure switches are closed on the low voltage control circuit on the outdoor unit. If any are stuck open, the compressor will not kick on. Or just push the compressor contactor in with an insulated screwdriver to ensure the compressor does actually work.
Dec 28, 2014 | Samsung Heating & Cooling
Samsung ARH1410 remote
Try contacting Samsung directly to obtain the manual.
Mar 10, 2014 | Samsung MH052FNCA Wall Mounted Mini Split...
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
Have an LG split system air conditioner. No way to turn it on or off on system. Remote only and it is not working. Did this a week ago and changed batteries, took a while before new batteries worked as...
Before buying new one, try with this step. Remove batteries from your remote and reset it after 5 minutes. And also remove DC wires plugged to indoor sensor display, and after 5 minutes re set it again. Now start your unit. Sometimes it will work out. Thanks.
Feb 02, 2011 | LG LSC121PMA Split System Air Conditioner
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
I hve purchased panasonic split a.c. b4 1 month only, mi remote senson is not working properly, i mean when i push mi remote button, its effect does not come in mi indoor unit sensor.
Ok, there are a few things to check.
1. Batteries on the remote.
2. Reset remote - switch sometimes in battery compartment and sometimes behind cover, need to press with sharp nib or pen.
3. Check on indoor unit that remote has been selected on the manual/auto switch, located under the cover on right hand side.
4. Remove indoor unit cover complete, (three screws behind the louvers and one on the electrical cover). Change the remote sensor board.
Mar 10, 2009 | Panasonic Heating & Cooling
Heating & Cooling Logo
377 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
Luminous Innovations...
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
