Question about Baxter OV300E Stainless Steel Electric Oven
When #9 program for Bagels is running , the temp drops 130 degrees before cycle is complete. also having to reset breaker several times
  • 43 Answers
It's normal for the oven to drop temperature during the first 4 minutes of a bagel cycle, although the temperature should recover to 525 before the end of the bake. If your breaker keeps tripping you could have a blown heating element and should call your local authorized service provider, I wouldn't recommend attempting to repair this one on your own.
Posted on Dec 30, 2011
Smeg sca130p. Interlock wont release after running through pyrolytic cycle. Tried running through cycle again but still wont open hours after cycle completed.
Cut the power to it completely, so if its on a breaker, press the test button on that breaker. Wait 3 minutes and put power back on. Has it cleared the problem?
Dec 21, 2013 | Ovens
I have just installed a Maytag built-in double oven to replace my old one (still working.) I shut off circuit breaker and reconnected wiring. The Control Panel and indicators on the digital readout all...
How many active terminals are there at the main terminal block in the new oven. Is this a single or 2 phase supply. Have you connected the active supply to all active terminals. If only half of the oven is working it sounds like it could be a problem at the terminal block. If so, you need to put a loop or bridge wire to the 2nd active terminal.
If all this was done correctly when connected the only other thing it could be is the electronic clock needs to be set to manual mode for the oven to work correctly.
Feb 26, 2011 | Maytag CWE5800A Electric Double Oven
Fan works, but Oven stays at 100 degrees. Tried
I had the same problem in December - I had to replace the circuit breaker and that solved the problem. My oven wouldn't go above 100 degrees in convection, bake and roast modes. Each of these modes are on a separate circuit so when one is bad, the others should work.
Jan 25, 2010 | Thermador C301U Electric Single Oven
Whirlpool double oven Model#: RDB305PDB12 Ran self cleaning oven and it completed the cycle and unlocked. Lost power - checked breakers and they are ok. The oven now has no power to it. Any ideas? Thanks,...
there is a tco (thermal cut off) part under the control pannel.
the local electronics store had them but not the right temp. choices for me where 1 degree cooler or 7 degrees hotter. the part was under $4. online for the right temp they wanted $15.75 s/h. In my oven it was inline with a black wire. both ends had the knife quick connects and is covered in a thick clear plastic. Be carefull. I dont know how but the ribbon cable for the control pannel broke while i was working on it. :( this $4 part did bring the power back on but because of the cable issue no keys worked.
Oct 07, 2009 | Whirlpool Ovens
F3 and flashing on Kenmore oven
HI. this is a basic temp sensor issue. the oven control is programmed to cease operations if it dose not receive any resistance signals for the temp sensor during high heat situations.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 18, 2009 | Kenmore Ovens
Light goes off and on by itself
I have the same problem with a DACOR ECS 130 and also set the breaker panel switch to OFF to prevent the light from turning on-off or staying on. It might help to unplug the touchpad connector behind the control panel or it may be a problem relay on a circuit board. I've had the problem for several years but will start work on it tomorrow because we do not bake often at my house.
Bill (bsquared37@yahoo.com)
P.S. I'm not an appliance tech but have had problems with the DACOR DM024 microwave( made by SHARP) and the DACOR raised vent. I think DACOR products are junk. The raised vent problem required replacing the entire circuit board!
Aug 30, 2009 | Dacor ECS130 Epicure Electric Single Oven
Oven will not achieve setpoint temperature.
You may not need anything. Most people test their oven with a dial type oven thermometer. They are slow to react and often not very accurate. When I test an oven or install a new thermostat, I use a digital thermometer with a remote temperature probe, hanging from the center of the oven, which shows the temp in tenths of a degree. I let the oven cycle on and off at least three times, then take the high and lower readings on the next cycle and average that out to see what the actual oven temp is. Most of the time, if there is a dial type thermometer in the oven it is very slow to react. After 3 to 5 cycles, they often show close to what the actual oven temp is, but the only way to know for sure is to use the more accurate digital thermometer. Most ranges with digital displays can be adjusted + or - about 35 degrees. Check your users manual for this info, but don't mess with it until you have checked the oven with a digital thermometer! Please don't bother rating this solution, as anything but a Fix-Ya drops my score. Thanks.
Jan 08, 2009 | Amana Ovens
How can i quit cleaning oven?
During the self clean cycle, oven temp will exceed 900 degrees F. At these temps, if you opened the door, the food inside would immediately catch on fire when the supply of oxygen hit it. When you turn your self clean cycle off, the oven door will remain locked until the internal temp drop below aprox. 550 degrees F for your safety. Once the oven cool below this temp, you will be able to start using the bake or broil again. This should be a Fix-Ya for your oven.
Dec 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Temperature gauge won't elevate past 350 and timer is messed up
somehow you have entered into the oven calibration mode at least that is what it sounds like. Normally if your press the clear button or reset it should come out of that mode you also could try to turn your breaker off for 15-30 min and then turn it back on. I dont think I would recommend cleaning cycle if the oven control is acting up.
Nov 05, 2008 | Whirlpool GBD307PDS Electric Double Oven
F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Mar 04, 2007 | GE JTP15 Electric Single Oven
Baxter OV300E Stainless Steel Electric Oven Logo
148 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
