Question about Garden
Hi, Just bought a 2nd hand petrol lawnmower today on eBay and found that when adding fuel it leaks badly from the carburetter/primer area.. Whether primed or not. The mower is only 6 months old and in very good condition, the engine did start briefly with barely any fuel in tank and runs okay, but when I added more fuel it pours out and floods so obviously wont start. I'm thinking this is probably not a major problem to fix? Any ideas?
    Scholar:
  • 71 Answers
The likely problem is a cut or abraded fuel line.
You likely will need to remove the plastic or metal engine cover to gain access to the run of the fuel line. Dry the area thoroughly and add fuel slowly watching for any leaks. Most leaks occur at the carburetor or at the fuel tank where it meats the fuel hose. A clamp should be used at both ends.
If this is not the problem, look closely at the fuel petcock on the bottom of the fuel tank. If it attaches with a screw, it may have a gasket that is leaking.
If the engine is a Tecumseh, look closely at the bowl at the bottom of the carburetor (if so equipped). There is often a bowl drain that has an O-ring that can become dislodged.
Sounds like a pretty easy fix as long as you can isolate the issue.
Posted on Sep 28, 2010
Testimonial: "Thanks for that - I will check the fuel line first as you suggest, tho the mowers like new so it should not be worn.. "
In my toyota corolla 2003 of 50 litres petrol capacity in the fuel guage thre are totally 17 lines including 4 thick lines. There are no lines in between E and 1st thick line. Similarly there are no lines...
The fuel level sensor in the tank is not linear, meaning it doesn't have the same equally spaced indication between E and F . The shape of the tank has a lot to do with the reading also. The needle will move more rapidly when the tank is below 1/2 full. When the low fuel light comes on there should be almost 3 gallons left in the tank 2 1/2 which are usable.
Mar 09, 2017 | Toyota Corolla Cars & Trucks
The bike has had the autolube system capped off & change to petrol & oil mixing in the tank. it was starting but i think the air-fuel ratio may be wrong or the carburetter needles sticking & what rati
Hi Anonymous, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix/test or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day. DOWNLOAD 2008 Aprilia Rx 125
Dec 04, 2011 | 2008 Aprilia RX 125
Engine runs then quits
You may have a small air leak at the carb, sometimes found at the bulb primer. This allows the engine to stop picking up fuel due to sucking air into the fuel line. If you re-prime, it will run again for a short period?
Apr 15, 2010 | Garden
Primer Bulb cracked Need new one?
remove carburetter air filter cover,two 'torx' screws on top.primer bulb is retained in case by 2 plastic 'ears' push ear[s] in& bulb slides out of case.make note/label 2 fuel lines attached; one 'stem' on primer is longer than the other.replacements can be found @ lawnmower/small engine repair shops.
Oct 10, 2009 | Garden
Fix scott bonnar lawnmower Prisma 37 model
Start by replacing the fuel filter and connecting hose at the leak point. It is important to use "fuel hose" and fuel hose clips - which are different to standard hose clamps.
If you have problems with mice - use a steel braided fuel hose - as they can't chew through these ! -
http://www.vehicle-wiring-products.eu/VWP-onlinestore/hoses/hoses.php
May 14, 2009 | THQ The Lawnmower Man
Wont stay running without pushing primer
Hi... I have a Poulan PRO Quantum xnp 6.75. Garage kept, unused approximately 2 yrs. Added fuel, primed & mower started but then shut down immediately. Then fuel began leaking from the primer button. I'm a single mom & CANNOT afford to have anyone fix this. However I am attempting to repair myself. PLEASE.... If you have any suggestions &/or solutions I would LOVE to know.
Apr 12, 2009 | Garden
Lawn Mower leaks petrol
it might be for a missing hose to a primer bulb or return line to the tank. does it seem like either are missing?
Sep 22, 2008 | Garden
Petrol lawnmower cutting out.
try changing the spark plug. if that doesnt work check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal.
Aug 29, 2008 | Garden
Garden Logo
215 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
