Question about Sanyo Video Cameras
My sanyo xacti has stopped recording sound. - Sanyo Video Cameras
  • 10 more comments
  • lorrainesega Sep 29, 2010
    could you tell me how I find the recording head? Also, I presume that previous video I have taken that didn't have sound won't be able to be fixed? I'd better go and buy some rubbing alcohol!
    Thanks. Found t option but didn't help. My model is a VPC-CA65EX and there wasn't a switch off sound option under the clock setting. I've just taken the battery out. Will report back. Thanks again.
    Thanks. Where would I find the recording head?
    It didn't work I'm afraid.
  • lorrainesega Oct 01, 2010
    How do I find the recording head?
    As I was about to download it, trend micro systems warned against doing so. Any other suggestions?
  • lorrainesega Oct 03, 2010
    Where would I find the recording head. The model of my camcorder is a VPC-CA65EX.
    Thanks
    Hi, I tried all the options you mentioned and it didn't seem to work unfortunately. The model if my camcorder is a VPC-CA65EX. Thanks though.
    Thanks for the suggested solution, I was about to download Final media Player but unfortunately my PC warned against doing so telling me that it has been known to be used for fradulent activity. If I would have downloaded it, would I have then had to connect the camcorder to get it to work. I'm not comfortable downloaded the software unfortunately as I had so many warning against doing so.
  • lorrainesega Oct 07, 2010
    My Sanyo Xacti vpc-ca65ex no longer records sounds. Having recorded huge amounts of footage we discovered that there was no sound on playback. We checked every setting and all sounds settings were fine. Before our holiday that sound worked and we had footage on the memory card with sounds but all the footage we took on holiday had no sound and we are no longer able to film with sound.
    http://sanyo.com/xacti/english/products/...
  • lorrainesega Oct 12, 2010
    It's a VPC-CA65EX. Thanks!
  • 15,935 Answers
What is the model # please?
Thanks!!
Posted on Oct 07, 2010
  • 3,083 Answers
You may have lost your sound codec, or it may have become corrupted. Go to this site, and download this program- it's free, and got my sound working again on my Sanyo:
http://www.finalmediaplayer.com/
Good luck, and hope this helps.
Posted on Sep 30, 2010
  • 4,924 Answers
Get into the menu and check if the sound is not muted..if you are not sure what the feature for the sound is ..just reset it all ...make a reset to the factory settings ..and if it is just a setting issue this should fix it ..Usually there is a reset to factory defaults or settings in the main menu ..if you do not find any ..try to remove the batteries and put them back after a while ...If it asks you for time and date settings it means it was reset ..if it not asking ..it means that has an internal battery and it has to have a reset feature in the menu ..
Posted on Sep 29, 2010
  • Catalin Turcu
    Catalin Turcu Sep 29, 2010
    by the way ..I checked and the sound (on and off ) will be in the menu just under the clock setting ..
  • mandolizer1 Mar 28, 2011
    My Sanyo VPC CA65 has just stopped recording sound also
    There is no sound record on/off feature - only playback volume adjustment
    There is a reset option - but it does not solve the issue
    there are no recording heads to clean - this model is digital, there are no moving parts ( you clean heads if you are recoding to tape) this model uses SD cards
    I see that the microphones are built into the back of the LCD screen where it says 'Xacti'
  • 10,865 Answers
Clean the recording head with a little rubbing alcohol on a cotton swab. J.
Posted on Sep 28, 2010
4 Suggested Answers
  • 21 Answers
SOURCE: Sanyo Xacti VPC-HD1- doesn't do anything in record mode
As I have been writing on other HD1/2 problems, sometimes it can be the card which is an issue. If the card is too slow or perhaps corrupted then the device can find it difficult to record.
This and other soft faults (that are reperable by turning the power on and off, changing or reinserting the card, removing the battery) are often indicated by a flashing red recording light.
Posted on Jan 06, 2009
  • 97 Answers
SOURCE: Sanyo Xacti CA6EX shows just steaky, blurry image
Sounds tasty! ;)
Just kidding. What kind of stReaky images is it recording? Is the problem that you are using it in bad light (eg indoors at night)? It could just be camera shake.
Make sure that your camera is in auto mode and try again - if it was in a slow shutter speed mode, then this could be more of a problem. Also try using flash, if you camera has one.
Posted on Oct 27, 2009
  • 3 Answers
SOURCE: Sanyo Xacti VPC-E1W dispay is black, no image
Is the camera on and does it have batteris fully or half way charged?
Posted on Apr 09, 2010
Hello I have got camera Sanyo Xacti vpc - ca9gx. Recently i lost mic but camera still was recording but after while stop working. On the top is red light flashing but it is not starting. I have open the...
Think you have it about thin sheets like fcc flatcontactcable that can about problems with sun heat build up inside there are special hotmelt repairs something like this kind of fcc without tools very difficult . hope you can something do with it knowing that Sanyo was become a part of PANASONIC in 2008
How to repair Flex cable Flexible PCB type flat copper ribbon cable Sanyo VPC CA9 Xacti Camcorder 720p Quick Manual
Apr 23, 2017 | Sanyo Xacti VPC-CA 9 Flash Media Camcorder
The sound is not recorded when filming, we have only had the camera just over a year....any ideas, or who can we call? Thank you. (Sanyo Xacti XA9)
Hi natalieaylet ,
Firstly i would recommend you to check if the microphone settings have been accidentally turned off , many times the sound is not recorded because of this issue.
Please don't let people experiment with your camera as they could do damage to your camera.
So where you felt there was a problem , you will have a big problem , as a result of experimentation.
If you feel that nothing works , even after changing the settings and restarting the camera, i would recommend you to dial the number provided on the user manual usually, which will help you with the nearest service center details so that you can get your problem fixed by an expert.
Hope this helps ...:)
May 11, 2011 | Sanyo Xacti VPC-CA9 Digital Camera
Well i have a Sanyo J1 Xacti Digital camera and i lost the CD with the software to download the pictures from camera to Computer. Is there any site where i can get download it? Thanks
Try Sanyo.com - look for support button.
Most newer computers with newer operating systems will detect a camera/camcorder when connected to USB. Have you tried it without the disk?
I have an older Xacti that records to SD card. You can use a flash card reader to transfer files without Sanyo software.
Jan 03, 2011 | Sanyo Xacti DSC-J1 / VPC-J1 Digital Camera
I have a Sanyo Xacti FPC-FH1 with a 32g SDHC card. I can only get 4g of recording time. The recordings after 4g have a big" ? " in the display when I list the recordings in playback mode, and while...
You could plug the card into your computer using a card reader and then right-click on it. Click on properties and it will give you the used and unused space.
Jun 27, 2010 | Sanyo Xacti VPC-S60 Digital Camera
Sounds tasty! ;)
Oct 27, 2009 | Video Cameras
SANYO XACTI 5M : SANYO CAMERA service center in MUMBAI
My Sanyo Xacti VPC 60 has problem in battery. After taking 2 -4 pics the camera is OFF.
Right from the day of purchase we are facing this problem since last 1 Year.
3 Years warranty is of no use & Sanyo service is horrible i.e still for the last one month its lying with them with no solution.
Purchased from Shreeji Enterprise - R Mall - Mulund
Jun 30, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Apr 25, 2008 | Sanyo Xacti VPC-HD1000 Flash Media...
How do I fade in and out with the xacti? Regards, Cargman
on Xacti HD2 "menu" button doesn't respond in Recording mode... any suggestions?
Jan 12, 2008 | Sanyo Xacti VCP-HD2 Camcorder
Sanyo Xacti (VPC C5E) digital movie camera NOT STARTING UP
This sounds like the same problem my daughter has with her camera (same model). Have sent it away to be repaired and have been told it needs a new MAIN PCB. The total cost is £232.65 !!! We are still looking around to see if we can get it done cheeper !
Nov 17, 2006 | Sanyo Xacti DMX-C5 Digital Camera
Video Cameras Logo
619 people viewed this question
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
