I have a one barrel haley card, had a hexagon piece feel out and do not know where it came from woul u please tell me where it goes
  • GE Whittle
    GE Whittle Sep 30, 2010
    how about a model number or a pic?
If 5 hexagons are put end to end what is the formulas for the perimeter?
Well, if you know the side 'a' of each hexagon it is just a*(30 - 4) = 26a
If you know the diameter of the circle enclosing the hexagon then
a = D/2 as radius = a
Sep 23, 2014 | Computers & Internet
Schlage deadbolt
Check your installation instructions. The lock is "handed" incorrectly. If on a left-hand door, it's set up for right-hand.
Jul 13, 2014 | Locks & Locksmithing
How would I drain the fuel from my RunX?
you can by a piece off transparent tube.put the car hight off the ground,take a barrel.stick the tube in filling hole.off the car .suck on it till you see it ,almost on your mouth.then put the tube in the barrel it chould flow on its own.
May 05, 2014 | 2005 Toyota RunX 160i
I have a 97 Grand Marquis, and tried to start it. The electronics came on, but the car didn't turn over. I turned the key to "off" and removed it, but the electronics stayed on. I can even remove the...
the lock isnt turning the back part which is the contact switch,use a screwdriver to turn it off or disconnect the battery. I think the problem lies in the barrel is got a piece broken that goes from the barrel to the contact switch .Without seeing it myself i couldnt tell you whats wrong or why the barrel has come out but their is a small hole in the case where you can push in to remove the barrel but in all honesty ask a local mechanic to have a look for you as this mat be beyond the average hme mechanic to sort out also their is a security reader that reads the chipped key callled a transponder so a local mechanic who knows what hes doing is your best best .Sorry if this appears a negative answer but as stated i would need vehicle in front of me to diagnose the correct repair.
May 01, 2017 | 1997 Mercury Grand Marquis
I'm Aijaz Talpur from pakistan. I have two Benjamen Franklin 342 air guns. In both I found their barrel are slightly bent upward, so they always shoot above the target. I checked the barrel with a steel...
Dear Aijaz Talpur,
I am Salman. Nice to see your question about bending barrels of Benjamin Franklin 342s airguns. I suggest you take the barrels to some Lathe Machine Expert (Kharadia). He will easily straighten them. I live in Nawabshah Sindh and have used a huge number of Diana, BSA, Crosman Benjamin and some pakistani airguns.
Please feel free to contact on 03018564852 for further help.
Regards
SALMAN
Jan 28, 2011 | Dmm Benjamin Air Rifle
I dont know how to adjust the gap beetween the frame and thebottom and top of the shaft of the fork that goes thru the frame is it just the hexagon screw by the handle bars? cause that doesnt seem to be...
The hexagon screw is the lug bolt for the fork, it also has an expander on the bottom of it. If, I were you I would take to a professional, and see if you need some bearings or something before you strip something and get hurt on it.
Oct 04, 2010 | Cycling
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Jun 15, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
The part that goes into the cigarette lighter broke on my Garin Nuvi. When I pulled it out, the small metal pieces, and a little glass tube fell out. How do I put it back together?
The glass tube is the fuse. There should be a spring and threaded metal barrel with a metal tip that slides through it. Look for these (4) parts.
The spring goes in first, followed by the glass fuse and then the metal tip should pass through the metal barrel. Screw the metal barrel with the tip on the end over the fuse. When you press on the tip, it should push in a little and spring back out. If you lost the pieces, you'll need to purchase another charger.
- Jim
SHARCNET-USA
Dec 16, 2008 | Garmin nuvi 255W GPS Receiver
Computers & Internet Logo
David Payne
David Payne
