Question about Amana Dryers
Have a LEA30AW. Basement flooded and Dryer will not heat althogu it spins and blower is working. Breaker never blew, drter not run until after flood (12"0water in basement where dryer is). Is it worth trying to replave heat coil? Where is it, bottom compartment?
  • bgbecker149 Sep 29, 2010
    I have only a lower front access panel. Do not see a fose on the rear wiring block. Where is the fuse located on the block?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be the Thermal fuse that has gone bad, dont think it is the heating element. The thermal fuse is mounted to the exhaust duct inside the back cover panel. When this fuse goes bad it should be replaced as it cannot be repaired. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 28, 2010
  • Rylee Smith
    Rylee Smith Sep 29, 2010
    Please check this diagram part#6 is the Thermal fuse.
Amana LEA30AW makes loud racket
either a bad blower wheel or you need to change out the rollers and belt pulley
Nov 08, 2013 | Amana NDG6800AWW Gas Dryer
GE Gas Dryer DDG8280SAMWW runs, but does not heat. We had a minor basement flood (thank you, Hurricane Irene!) with about 4" or so around the dryer. We do not hear the "whoosh" that would...
Sorry to hear about the flooded basement ..here in Virginia i only had a couple trees down and power go off for 12 hrs but no flooded basement.
Their is no way to clean/clear the igniter persay..gotta check and see what shorted out due to the flood...this tip i wrote explains what to check on gas dryers when they dont heat. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
Good luck i hope this help you to figure out why your dryer isnt heating,
GENE
Aug 31, 2011 | GE Dryers
Basement flooded,Dryer runs but wont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 26, 2011 | Frigidaire GLGR341AS Gas Dryer
Hi. My mother had a flood in her basement recently and although her 5 year old ge Profile gas dryer was set up on blocks off of the floor the bottom section got wet and it had stopped working. The...
you need to inspect the ignitor/glow coil that ignites the gas in the burner tube as they are very fragile,then on the burner tube body check the radint sensor eye it can be dirty,clean it first or then replace it,the gas valve boost and secondary coils on the gas valve could have been damaged and they keep the gas valve open to supply gas to the burner,then also check the thermal fuse on the vent blower housing as water could have ruined this component,also check all wire connections for water corrosion too
Jul 07, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
My Roper dryer worked fine until my basement flooded about 6 inches of water on floor. Now my dryer just hums when I try to start the dryer. The heat does come on. When I spin the drum and hold in the door...
It sounds like the motor was damaged in the flood. You may be able to salvage it by spraying both ends of the motor shaft with penetrating oil several times moving it in between, but you may not be able to salvage it.
Dec 30, 2009 | Roper REX4634KQ Electric Dryer
Dryer is spinning and working fine, just no heat to dry the clothes?
Hello Could be sevral things the motor that sopins the dryer and the control are 110 volt the heal element is 220 volt if you blew half the breaker you can get spin and no heat. If it is not the breaker it could be a bad element or a senso which would require a repairman
Jun 23, 2009 | GE Dryers
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
My GE dryer will not heat up after flood damage
Hello chucky40,
There is a good chance that your gas valve has been damaged by the water. Can you tell if after you try starting it if the igniter comes on and/or you have gas flow to the burner? Those are the prime suspects ( albeit not the only ones) but you will need to verify these basic functions before others can be examined..
Keep me posted and I'll try to help you get thru this..
Regards,
Rick
Nov 23, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Dryers Logo
56 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
