Question about BEL 980 Radar Detector
My Bel 980 beeps and flashes ?PLL LCK Can you help ?? Cheers Chris
4 Suggested Answers
SOURCE: how to open Bel 980 case
they are two on back thke the bottem then the top will come off the problem is there are two hinges in the front part on each side u have to compress each side with a very tiny flat head screwdriver. note be very careful this unit is not make to take apart easy but it can be done i have the same problem i am going to radio shack to see if the have the part for the voltage but first i am going to re sader the contection first. hope this works mark
Posted on Apr 24, 2008
SOURCE: Bel 980 problem
Mine has the same problem, but it seems to be caused mainly by excessive heat, mainly from being in the window of a hot car in the summer sun. Mine rarely does it in the winter. I suspect the CAL part has to do with a calibration fault when it self-tests itself when it's first turned on.
What I usually do is to pull the detector out of the mount and hold it in front of the air conditioning vent so that the cool air can go in though the holes in the case. It may take several minutes of cooling in this manner before it can power up without the LO CAL 1 message.
Posted on Aug 02, 2008
SOURCE: does the bel 980 need to be upgraded ??
BEL no longer offer upgrade or repair for the BEL 980 detector
Posted on Aug 26, 2008
Is nvidia quadro4 980 xgl has pixel shader
Yes, the 980 XGL card has the nFiniteFX II engine which has both pixel and vertex shaders.
See this link for details:
http://www.nvidia.com/object/feature_nfinitefxii.html
and
http://www.nvidia.com/page/quadro4xgl.html
Hope this helps, please rate my answer.
Chris
Mar 02, 2011 | Compaq NVIDIA Quadro4 980 XGL (128 MB)...
Broken Cord plug
you can buy new ones on ebay
Apr 01, 2009 | BEL 980 Radar Detector
No audio
Hi everyone,
Bel/Escort now uses a special and proprietary "high temp" speaker which resolves issues of speakers blowing due to high ambient temperatures or heat which builds up within the speaker when it is alerting for extended periods of time. If your RX65 is in warranty and you can make a photocopy of your sales receipt, then great! All you have to pay is shipping to Bel. Bell will replace the speaker with the new version, flash your RX65 with whatever the latest firmware is, and calibrate and test your RX65 too. So, all of this is peachy if your RX65 is under warranty.
If your RX65 is out-of-warranty or if it doesn't have a serial number or was bought from a non-authorized dealer, then the service charge as I recall is $80. Thats not bad since your RD will come back working like brand new.
A note about the speakers: They are made by PUI, but the speakers are proprietary to Bel/Escort. Thus you can not buy them from any source -- not even direct from PUI.
Dec 15, 2008 | Pro RX65 Radar Detector
Does the bel 980 need to be upgraded ??
May 27, 2008 | BEL 980 Radar Detector
My bel 980 speaker quit working
On mine you can barely hear it on the 9 setting. I put in a different speaker but no difference. I did look up the number on the IC chip near where the speaker connects (34119) and it came back to a 500 mW audio amplifier, so you could probably replace that and fix it. I think it's what you call a flat-pack style chip. Not as bad as surface mount but will still require a tiny soldering iron. I think the actual part number ended up being MC34119D and should cost a dollar or less.
Apr 24, 2008 | BEL 980 Radar Detector
Operating Voltage
It is 12 volt (or at least mine is). You should be able to connect directly to a fused supply, but I would advise checking output with a meter.
Feb 17, 2008 | BEL 980 Radar Detector
How to open Bel 980 case
Feb 16, 2008 | BEL 980 Radar Detector
Bel 980 problem
I have the same thing wrong with mine ! I put it in my other car and it works fine. Found out it was my alternater was not working right! Hope this works for you
Nov 08, 2007 | BEL 980 Radar Detector
BEL 980 Radar Detector Logo
143 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Steve
Jerry Greenberg
Jerry Greenberg
David Payne
David Payne
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
