Question about Compaq Computers & Internet
HP Compaq Presario V6101US won't turn on - Compaq Computers & Internet
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 29, 2010
Starts up then shuts down
check for over heating,check the fan is running ok if not clean it out.
Aug 29, 2013 | Microsoft HP Compaq Presario V6101US...
Why won't my Compaq Presario SR5712F cut on?
I would not recomend to CUT OFF. You can damage WINDOWS FILE STRUCTURE. Shutdown using menu or press once on power button.
Oct 30, 2012 | HP Computers & Internet
Wireless do not work
You may have to update the drivers,
Click Start
Right click "Computer" then click Manage
Wait for screen to load up then click device manager and locate the wireless card. see if it is there if it has an exclamation mark then you will need to update or install the drivers.
Another problem could be that being HP it usually has some kind of software that monitors and manages the wireless connections. click the little up arrow on the bottom right hand side to see if there is any wireless connections manager running and open that up. Windows tries to handle the wireless side itself but also HP make their own software to handle it also
Oct 24, 2012 | Microsoft HP Compaq Presario V6101US...
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
My HP Compaq Presario CQ50-130US PC Notebook won't turn on. It just flashes on the front where the lightning bolt symbol is. It was running fine an hour ago.
Two probable problems the screen or the motherboard, if you have some technical skills you can open the laptop and figure out where the problem is using a multimeter. If you are not very good with computers the best thing you can do is to take it to the service center.
Aug 30, 2011 | HP Compaq Presario CQ50-130US Notebook
I'm considering buying a Compaq Presario v6101 and then maxing out the RAM (2GB), for my 2 young kids to use. They will only use it to play games, downloaded and internet games. They will not like a slow...
honestly no not good for gaming but it really depends on the games. originally for windows XP Basic. https://www.cnet.com/products/compaq-presario-media-center-v6101us-15-4-mobile-sempron-3400-plus-win-xp-mce-512-mb-ram-80-gb-hdd-series/specs/
Feb 09, 2018 | HP Compaq Presario CQ60Z Notebook
I use windows 7 for my pc which is of the model presario v6101us. I have problem getting the drivers for its coprocessor.
you will have to identify each hardware and go to that website and get drivers for the same, it will consume time and cannot be offered in a one line solution, what you can do is give details of the hardware in your pc and will try to locate the drivers and give you the links
Cheers till then !
Aug 11, 2010 | HP Compaq Presario V6101US PC Notebook
HP Compaq Presario V6101US Notebook PC' push the
There are several reasons why this could be happening. Below are a few diagnostic steps we can start off with to eliminate some possibilities. If there is anything you are not comfortable with doing yourself please consult a local repair technician.
  • Remove the battery from the system and try booting up the computer with only the power cord. The "1" in the diagram below is the battery, "2" is the battery release latch.
  • Try removing one of the memory modules (if there is more than one) from the system by following the below steps.
1. Flip the computer upside down. Remove power cord and battery and ensure the system is completely off.
2.Unscrew the compartment labeled "4" in the diagram below. This is where the battery is held, as well as the WiFi card and motherboard battery. DO NOT do anything to these other components as they are quite fragile.
3. If there is more than one memory module you should remove one. Replace the compartment cover and attempt to boot up with battery and power cord reattached. If nothing has changed try swapping out the memory with the one you just removed.
If still nothing happens, this is not the issue. Comment back and we will move further with your case.
Good Luck,
NOLA Tech
Jan 28, 2010 | Microsoft HP Compaq Presario V6101US...
How to connect my compaq presario V6000 to my dell monitor.
try hitting Function (FN key next to the control) and F7 at the same time on the laptop. Also, is the dell monitor's input set to VGA (some have multiple inputs like DVI, VGA, HDMI, etc)
Jul 08, 2008 | Computers & Internet
Computers & Internet Logo
76 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
