Question about Back to Basics Smoothie Elite Work Top Blender
Blades It seems like the ice doesn't crush up like it used to.  Do you ever need to replace the blades?  I found all types of replacement parts but no blades.  Please help.  Thanks.
  • sunni01 Jan 11, 2009
    i have a smoothie elite blender and all i want to do is order the blade replacement for it and i can't find it help? robin4908@aol.com
  • 8,596 Answers
Replacement blades can be found here:
http://www.focuselectrics.com/finditem.cfm?itemid=4308
-Tha Mp3 Doctor
Posted on Mar 25, 2009
How do I replace the knife unit in a krups type 243 blender?
Take the blade assembly out of the jug, hold the blades with a towel and turn the driving clutch on the other end. Whichever way the motor turns those blades when operating, you need to turn the drive the opposite way to undo it. If the nut is seized up and wrecks the drive the parts list shows all parts as being available EXCEPT the white bearing housing AND the complete assembled blade and housing.
May 16, 2014 | Blenders
Broken blade assembly
Possibly the new wave action blades on cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-WAVE-ACTION-CUTTER-BLADES-REPLACEMENT-PART-/161615007502?pt=LH_DefaultDomain_0&hash=item25a1014f0e. For a more original replacement, try typing in your model number at the HB's parts site, located by clicking here . Check out the many www sites like abtecparts.com and goodmans.net. Besides matching description, I would match the pictures of what you are going for against what you've got as much as possible. Good luck!
Jan 05, 2014 | Hamilton Beach 54259 BlendMaster Ultra...
Can't seem to find proper gasket and blade assembly to fit Ham Beach Blender #50100 Type B-12. Any suggestions?
Possibly the gasket while it lasts on the cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-WAVE-ACTION-CUTTER-BLADES-REPLACEMENT-PART-/161615007502?pt=LH_DefaultDomain_0&hash=item25a1014f0e
Possibly the new wave action blade cutter while it lasts on cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-WAVE-ACTION-CUTTER-BLADES-REPLACEMENT-PART-/161615007502?pt=LH_DefaultDomain_0&hash=item25a1014f0e. For unused replacements, try typing in your model number at HB's parts site, located by clicking here . Abtecparts.com may also have traditional blades at http://www.abtecparts.com/commerce/search/products/?product_id=02AXHBha010&merchant_id=1933. Besides matching description, I would match the pictures of what you are going for against what you've got--unless you are trying something new--as much as possible. Good luck!
Jun 19, 2013 | Hamilton Beach 50100 BlendMaster Work Top...
Where can I get a part for my George Forman Model GFSB1
Replacement parts for the Geroge Foreman GFSB1 Blender may be order online here:
http://www.directpartsandproducts.com/blenders-gfsb1-c-61_171_1017_1018_1019.html
If you do not see the part you need listed, contact the supplier at 800-738-0245 or use their web inquiry form:
http://www.directpartsandproducts.com/contact_us.php
Dec 01, 2011 | George Foreman GFSB1 Blender
We have a Black & Decker BL9000 blender. On top of the base, there is a plastic disc that meshes with the bottom of the jar and drives the blades. I think one of the kids was making smoothies and...
Available replacement parts can be found here:
http://www.directpartsandproducts.com/blenders-bl9000-c-1_4_60.html
or here:
http://www.abtecparts.com/Black_&_Decker_blenders_BL5000BL6000.htm
I have not seen the drive gear made available. You could try making an inquiry with either of the above sites to see if they can locate a replacement. Alternatively contact a local small appliance repair shop; they may be able to scavenge the part from another blender.
May 16, 2011 | Black & Decker BL9000 Blender
My blendtec blender doesn't blend as well as it once did. The motor seems to be running fine, but I am not sure if the blades are spinning properly.
You have already found what is the problem the blades.
The blades after a lot of working hours with ice they have mainly three problems.
One the sharp adjes have created a lot of teeths and are not so sharp any more so the blending is not smooth anymore.
Second problem they have loose a title so they have move from corect place some milimeters and this change the wave motion and again the beleding is not so smooth as before.
Third the blades are secure on an axis which is located in two bearings which have een wearing out so the rotating motion of the blades again is not so smooth as before.
So if you are not able to fix the blades kit or to find someone in your area to do it profetionaly and cheap one good idea is to buy a new blades kid.
Good luck
Aug 17, 2010 | Blendtec ABC Work Top Blender
KSB5600BO kitchenAid blender blades broke and l am looking to replace them but I can't find the right parts. Do I need to just by the whole Jar assembly?
You don't need to replace the entire jar assembly. Have you tried to contact Kitchensid. They make high quality appliances and will probably send you new blades for $0.
Apr 19, 2010 | KitchenAid KSB560 5 Speed Blender
My blender seems to spin without the glass blender "jar" in place. Once the blender is put on top, the blade will not spin.
your blade assembly is corroded. take it off, and using a rag, grab the blades. using another rag, grab the other end (probably rubber) and turn CLOCKWISE - it's threaded reverse, so you have to turn to the right to loosen, not the left like usual. I had to clean out the rod that connects to the blades - it was all nasty and corroded. I cleaned it with my Dremel and regreased with a tube of grease I keep in the garage, cleaned all other parts with some Dawn, dried well, reassembled, and works almost like new. I'm guessing I ran it too long without pulsing the motor and the heat corroded the rod that's connected to the blades. OR you can buy a replacement blade unit for about $10 online on a blender parts site
Oct 10, 2009 | KitchenAid KSB5 Ultra Power Work Top...
Can't find Replacement Blades
call cilinary parts unlimited at 800 543 7549. after searching for a week i finally found a place that deals with them.
Jun 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Looking for Metal blade in Black and Decker -BL12475G
If it is 2 yrs old,Just call the customer service,they will give you the parts for blender for lesser price or else go for new one.
Apr 27, 2008 | Blenders
Back to Basics Smoothie Elite Work Top Blender Logo
772 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
