Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE5500AYW Dryer
I need to know how to take the back. There is a loud thumping noise in the drum when running.
  • Cbrown034 May 26, 2008
    Thanks so much. Took the front off and raised the top. When I turned the drum, there was a screw about to fall out. So there was my noise!! Put it back all back together and it's working great!
  • 525 Answers
ALL service is perfromed from the FRONT. Shock Hazard Warning! Open the dryer door aand remove the screws that hold the door hinges, remove the door, and on the opposite side that have just 2 screws where the door would attach if it was converted to the oppsite opening direction, and remove the front panel. Remove the front bulkhead,(the internal drum opening panel), by removing the 4-5/16" screws that hold it to the outer side panels. Reach back to the rear of the motor and release the tension on the idler and drum belt. Remove the belt and lift drum slightly upward and remove from the unit. You should then observe 2 rollers about 3" in diameter positioned at about 5 and 7 o'clock. The roller at the 5 o'clock position is most likely bound up or not free-rolling. TRU-ARC spring clips,(you may need to purchase), retain the rollers on the shaft and need to be carefully removed and saved for reaasembly. Inspect roller at 7 o'clock for free operation. Purchase what you need and reassemble.
Hope this helps!
Posted on May 26, 2008
One of the internal baffles on the dryer is very loose. It appears that fasteners may be coming off. It looks like the top of the dryer has hinges and should rotate up, but how do you get the top to come up so that I can look at the baffle. The baffle is currently at the top of the dryer in it's rotation and if I can just figure out out to get the top up I should be able to see what is coming loose.
Mike
Posted on Jan 05, 2009
Maytag neptune dryer making banging noise on each rotation on the left side facing the front. its almost like a thumping noise what do i need to do please?
The drum baffle screw has unscrewed itself and the head is thumping against the inside top panel. Pull door, lift lid, rotate drum to find screw sticking out and tighten.
Aug 03, 2010 | Maytag MDE5500AYW Electric Dryer
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDE5500AYW 220V Electric Dryer. Makes a
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
Mar 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Loud thumping noise
a roller under the drum has a flat spot
Dec 10, 2009 | Maytag PYE2300AY Electric Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Dryer has thumping noise.
Yes that is what most likely is the problem to begin with. The drum usually never goes out of round . Replace bearing best choice
Aug 28, 2009 | Dryers
Dryer makes loud noise, long time to dry.
This is joyce
Go to maytag.com and put in your model# and dowload your manuel. get some info on your type machine and the scamatics on it. I dont know the age but it sounds like its in the drum. may want to calll a technichian out to look at it. if I can help please let me know
thanks
joyce
Feb 13, 2009 | Maytag LSE7806A Top Load Stacked...
Loud thumping noise
IT COULD BE THE DRUM BUT I WOULD INSPECT THE DRUM ROLLERS TO SEE IF ONE HAS A FLAT SPOT IN IT. IT MIGHT NOT HURT TO CHECK THE DRUM BAFFLES/PADDLES TO MAKE SURE THEY ARE TIGHT.
Jan 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Lumpy drum noise
Did you remove the shipping bolts from the back of the machine
Mar 26, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune MDE5500AY Electric Dryer Logo
595 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
