Question about Garden
Have a onan gen set for rv model 4.0 ky-fa/26100H changed starter and solenoid. put back into rv and gen runs for approx 15 secs, then no fuel, put 12vdc to fuel pump and monitor control board vdc is 5.4. with 12vdc appiled to fuel pump, unit runs great. what else is there to look for, I have changed the control board thanks garrett
  • rely98 Sep 28, 2010
    all new fuel and filters. just a note. the new control board and old control board just delivers 5 or so vdc to the fuel pump, could there be something i;m missing
  • 3,740 Answers
Hi Garrett. The symptom your describing is due to a fault detection shutdown.
Faults:
Low Oil Pressure
Low Oil Level
High Temp
Low or High Generator voltage output.
Low or High frequency output Below 55Hz and above 64 HZ
Any one of those faults will terminate the run cycle by cutting off 12VDC to the fuel pump and Carb solenoid.
Check your oil level and make sure it is completely serviced to the full mark. I tend to think that during the removal and reinstallation process the oil level changed just a bit as it was fine before removal of the unit and had a problem after you re-installed it.
Also check the generator output voltage by having a meter connected to the output terminals of the generator as you do a start. If you have a voltage problem the fault circuit will be activated and the unit will shut down. Take a look at the starter solenoid to make sure you have all the wires connected properly. You could very well have the 2 smaller wires reversed on the solenoid.
Thanks for choosing FixYa.
Kelly
Posted on Sep 29, 2010
  • 10,865 Answers
Change the fuel filter and siphon out the old fuel and replace with brand new fuel. J.
Posted on Sep 28, 2010
Why does it run only in the start position?
Hello Martin, Your generator might have a low oil pressure shutdown switch. First check the oil level. If oil level is low, fill oil to proper level. If oil level is fine, I would install an auxiliary oil pressure gauge . If oil pressure is normal, I would change the oil sender unit. If oil pressure is low, I would change the oil pump.
Aug 03, 2015 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
When I push the start button, why does it just click?
Hi John:
Sounds like you may have a bad starter.
Can you bench test it?
Jul 10, 2015 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Troubleshooting generators
If this unit dies under load conditions, decrease your load and try it again.
If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
Jul 21, 2014 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Troubleshooting onan repair
Check for a bad fuel pump and a clogged fuel filter.
Jul 16, 2014 | Onan-Orderable Cummins Onan 2.8 KV-FA/...
Wont stay running
if it stops running after you let your finger off the start switch, check the rotor, rotor brushes slip rings for cleanliness. Check all wiring plugs back to the control board for tightness. The control requires a feedback from the stator, if it doesn't see it, it will shutdown. If all that checks, have someone ohm the stator windings. Then it;s your control board most likely
Sep 22, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
Check rotor slip rings for cleanliness, brushes, stator resistance, rotor resistance. Then replace control board if they check out.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
How to fix onan 4000 that will not stay running
Check the slips rings and brushes, check the stator and rotor windings for continuity and for shorts to ground. Check PCB plug connections. After that you need a new control board
Jan 07, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Garden Logo
265 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
