Question about Microsoft Windows XP Professional SP3 Full Version OEM for PC
I get an error message when trying to install internet explorer 8. the SHregGetValue entry point cannot be located
  • Shekhar Chowdhury Sep 28, 2010
    Which service pack is installed in your computer
    President:
  • 2,291 Answers
First clean ur windows, check for errors, run chkdisk, repair windows registry with reginout and then install ie 8
Posted on Oct 15, 2010
I am using windows 7 but I am unable to install internet explorer
Win 7 will only work with I.E. 8 or 9. You have to disable your virus checker before you can down load and install I.E. 8 or 9.See: http://support.microsoft.com/kb/917925
Jun 15, 2011 | Computers & Internet
Tip
Internet Explorer 8 takes longer than expected to start.
Symptom:
When launching Internet Explorer, you may notice that Internet Explorer takes longer than expected to start.
Cause:
This issue can be caused if there are damaged or incompatibilities with installed Internet Explorer add-ons. This behavior may be more visible in Internet Explorer 8 due to changes in the way that Internet Explorer 8 handles the internet zones list.
This issue can also be caused if using Spybot and the Spybot immunization feature is enabled.
Resolution:
To resolve this issue, troubleshoot the Add-ons to determine which Add-on may be causing the issue and then disable or uninstall the Add-on and then contact the manufacturer of the Add-on for support with that Add-on.
To do this, follow the steps listed below starting with Step 1.
Note: If you currently have Spybot installed with the immunization feature enabled, you will need to disable that feature until that issue is resolved. If you’re not sure how to disable the immunization feature, contact the vendor for more help.
Step 1: Run Internet Explorer 8 in "No Add-ons" mode to determine if the issue is Add-On related.
loadTOCNode(2, 'resolution'); Internet Explorer 8 add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer 8.
To determine whether the error is caused by an add-on, run Internet Explorer 8 in "No Add-ons" mode. To do this, follow these steps:
  1. Click Start, and then type Internet Explorer in the Start Search box.
  2. Click Internet Explorer (No Add-ons). Internet Explorer 8 opens without add-ons, toolbars, or plug-ins.
  3. Test Internet Explorer to verify that it works correctly. If issues still occur, try Step 3.
If no errors occur, the problem is caused by one of the add-ons that typically load together with Internet Explorer 8. In this case, continue to Step 2 to determine what Add-on is causing the issue.
Step 2: Use the Manage Add-ons tool to determine which add-on is causing the issue
loadTOCNode(2, 'resolution'); Use the Manage Add-ons tool in Internet Explorer 8 to individually disable each add-on to determine which add-on is causing errors. To do this, follow these steps:
  1. Open Internet Explorer 8.
  2. Click Tools, point to Manage Add-ons , and then click Enable or Disable Add-ons.
  3. In the Show box, select Add-ons that have been used by Internet Explorer to display all add-ons that are installed on the computer.
  4. For each item in this list, select the add-on, and then click Disable under Settings.
  5. When you have disabled all the items in this list, click OK.
  6. Exit and then restart Internet Explorer 8.
  7. If issues do not occur, repeat steps 1 through 3.
  8. Click Enable for a single add-on.
  9. Repeat steps 6 through 8 until you determine which add-on causes errors to occur.
After you have used this process to determine which add-on is causing errors, you can disable that add-on. Or, you can uninstall the software that installs the add-on. We also recommend that you contact the software vendor that provided the add-on for additional troubleshooting and support.
Step 3: Reset Internet Explorer 8 settings
loadTOCNode(2, 'resolution'); To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 8 to its default configuration. This step will also disable any add-ons, plug-ins, or toolbars that are installed. Although this solution is quick, it also means that, if you want to use any of those add-ons in the future, they must be reinstalled.
  2. Click Tools, and then click Internet Options.
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer Settings, click Reset.
The information in this article applies to:
  • Windows Internet Explorer 8
Keywords: MS Article ID 969938
on Mar 29, 2010 | Computers & Internet
Receiving error message: WlanMon.exe - Entry
Try a reinstall of the software sounds like that wlanapi.dll isn't being "Registered" If installing on Vista or Win 7 use Admin mode and try Compatabilty Mode for XP SP2.
Feb 03, 2010 | Blitzz Technology (BWA611) Router
Yahoo msg does not start and gives error message "entry point not found when trying to uninstall same error is shown
Clear the Yahoo! Messenger Cache in Windows
http://www.mediafire.com/?b7d3mjr15ic317b
Dec 31, 2009 | Yahoo Messenger
Ever since upgrading to Internet Explorer 8, I find that I cannot print emails, open up many attachments, and retrieve other information. For example, if I click on a link, I get the following message:...
Ther are known conflicts with Vista and IE8 - particularly with Vista 64-bit.
I would suggest uninstalling IE8 and reinstalling IE7 or using an alternative browser such as "slimbrowser" (excellent program) or similar.
IE8 can be uninstall by using Add or Remove Programs module in Windows XP, but in Windows Vista, Windows Internet Explorer 8 is not considered to be a ‘program’. Instead, IE8 is categorizing as an ‘update’. Thus, users will not be able to find Windows Internet Explorer 8 in “Programs and Features” of Windows Vista.
To uninstall Internet Explorer 8, go to Control Panel, and click on Uninstall Programs link or Programs and Features icon. Then on Tasks pane on the left, click on View installed updates link. Locate and select Windows Internet Explorer 8 in the list of installed updates, and then click on Uninstall button. Click on Yes when asked that are you sure want to uninstall the update.
If there is no option of IE8 been found on “Programs and Features” or “Add or Remove Programs” dialog box, or uninstallation of Internet Explorer 8 is unclean (causing error message such as setup cannot continue because a more recent version of Internet Explorer has been detected on this computer when trying to downgrade to IE7), try to manually run the spuninst.exe.
To do so, go to C:\WINDOWS\ie8\spuninst\ folder (your drive letter may be different), and run spuninst.exe.
Restart the computer after uninstallation completed.
Hope that helps :)
Nov 09, 2009 | Dell Studio XPS 435 PC Desktop
Internet explorer 8 version 20090308 will not
here is my advice : Just go to www.microsoft.com and download internet explorer again and install it , then reboot your system . I'm sure that this will solve the problem . any way , why don't you try other internet communication softwares like ( firefox or google chrome) those both are great also . I advice you to have more than one internet communication software . I already have three just in case if one of them is corrupted . I have ( Internet explorer and firefox and google chrome ) . just try the idea and you'll be satisfied with the result .
If that didn't help then try to check system for errors . such as registry errors .
good luck .
rate if useful please !
Sep 23, 2009 | Microsoft Internet Explorer 8
Error message when closing IE
Try Mozilla Firefox and see if the same thing happens. lol.. IE is a white elephant in general. You might need to go to add/remove programs and uninstall IE from the windows components section and reinstall it possibly, personally though I would not re-install IE after removing it though, lol. As urban dictionary defines Internet Explorer - a perfect program for downloading Mozilla Firefox, lol. Good Luck!
May 01, 2009 | Microsoft Internet Explorer 8
Problems trying to install Internet Explorer 8
Firstly Remove SP3 through
http://support.microsoft.com/kb/950249
Then Download SP2, it works fine. Either way u can also go for SP3
Then try again for IE* or Mozilla
Hope It Works Out ur Problem
Apr 12, 2009 | Microsoft Internet Explorer 8
Internet Explorer 7 beta version uninstalling problem
Go to ControlPanel > Add Remove programs scroll down and select the Internet Explorer 7 beta X, then click on chage remove. If you are not able to see the item see at the top of the window and "tick" show updates. It will display the IE installation. Tell me if it worked else you will have to manually uninstal it.
Nov 14, 2007 | Computers & Internet
Open Questions:
See all Microsoft Windows XP Professional SP3 Full Version Questions
Microsoft Windows XP Professional SP3 Full Version OEM for PC  Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
