Question about Garden
HORNET MACH 11 14 INCH ELECTRIC CHAIN SAW . lARGE gEAR IN TRANSMISSION NEEDS REPLACED. wHERE CAN I BUY ONE?
AlmostBob
  • 550 Answers
SOURCE: 14 inch electric chain saw throws chain off
If a new chain ::
make and model is important here, as are guide bar length
a particular chainsaw, may be available with 12,14,16,18,20,22,24,26 inch guide bar,
likewise different saws (even from different makers) use the same size of chain
a chain for this saw may be sold in a variety of lengths or
may be sold in the longest length only and require links removed to suit smaller bars.
back to the store, with the saw, for confirmation
If an old chain::
stretched way beyond safety, replace
Posted on Sep 28, 2008
reinstall chain
Posted on Jan 10, 2009
  • 10865 Answers
SOURCE: chain comess off bar ever7ytime u cut
put the chain on and adjust the chain tension so that it is a little snugger than it has been. that should solve your problem. if it doesn't it may be time to replace the chain bar.
Posted on Feb 12, 2009
steve_lima
  • 181 Answers
SOURCE: electric chain saw chain adjustment. How loose should it be?
the chain should not be sagging from bottom of bar.when you tighten the chain push the nose of saw up so that all of the slack is out of the chain.chain should snap back in the bar if you pull the chain up and let go.when i adjust a chain i push the saw forward to make the bar go up and stay there while i tighten the nuts.hope this helps, let me know
Posted on May 13, 2009
  • 188 Answers
SOURCE: I need an owner's manual for a remington electric chain saw
Here is the owner's manual for the M30016AW... http://12.153.20.74/manuals/113005-01G.PDF. Here is also the instructions on the installation for the chain that goes on the your saw ... http://12.153.20.74/manuals/113556-01A.pdf. If you are need of a part you can conatct Master Parts at 800-446-1446, they can also help you. I hope this helps!
Posted on May 27, 2009
What is the oil capacity for the Hornet 14" Mach 2
Usually about 3-4 ounces in the bar oiler tank. The fuel mixture you can find at McCullock.com.
May 03, 2014 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need replacement chain for remington 14inch, EL-1 and remington LNT Limb N' Trim 8. Could you provide me with current replacement chain information for both?
Hi jvaltha,
Here is a website that carries the chain for your EL-1 saw: http://shoppingcart.msservicecompany.com/default.aspx?ext=true&itemid=091374S&size=small The part number is a replacement for the original chain, which Remington must not offer any more.
That same site also carries a chain for your LNT 8 saw, but there are different subcategores, LNT1, LNT2, and 8A and B. I'll paste the address for the page where you have to choose your option: http://www.desaparts.com/remington-chainsaw.html
FYI, You don't need to buy a remington chain to fit your saws. Just buy a chain that is the right length and matches the rest of the specs on your chain, the pitch etc. .050,.025, and so many teeth per inch and so forth. Then you can buy locally.
Hope this helps. If it does, I'd appreciate a 4 thumbs up...keeps me working. Thanks,
Handie Andie
May 09, 2011 | Remington Electric Chain Saw
I have a 16 inch chain saw and want to buy a new chain saw blade does anyone know what other manufacturer's blade will fit
Oregon mfg. makes a full line of replacement chains and bars (blade). Check with home centers, hardware stores, and saw dealers. Bring full details of the saw with you, or the saw itself. Good luck!
Jun 03, 2010 | Desa International Remington 12 Electric...
Remington 14" Electric Chain Saw Assembled 1.5 Peak: I just wanted to know what type of oil to put in t...
I have been using regular chainsaw oil and I think it works ok. I inherited one of these and would like to find a spare chain and also a manual. Can you give me any info? Thanks
Tim
May 17, 2010 | Desa International Remington 14" Electric...
Ryobi ECW 1836 electric chain saw. No drive
Check to be sure your chain brake is in the OFF position Pulled back towards the operator
Apr 01, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Remington chain saw, electric: jammed and now the
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "M30016US" into the "Model #:" window, then clicked search.
  • Click the M30016US - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" think you want item 18, 113004-01, Internal Gear
  • Click the 113004-01 - USE REPLACEMENT PART # 122513-01 "View Part" link.
Results follow:
Part #: 122513-01 Price: $24.00
Description: KIT, INTERNAL GEAR (MOD) 747 B/O
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Nov 10, 2009 | Remington M30016US 16" 3.0 Peak Hp Modular...
Correct replacement chain
take the old chain with you when you go tobuy the new one is the best way
Aug 25, 2009 | Garden
Internal gear slipping ,seems like rart of gear
you may be able to fix your problem by tightening up the chain a bit more. other wise, you may have to have that gear replaced because as you indicate it may have had it's teeth worn down. i would begin by tightening the chain.
Aug 14, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
No drive gear
Price of fixing it buy a new saw..
Feb 26, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
370 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
