I have 2 desktop computers. im connecting a router to run a wire to the second computer the modem. when the computers connect to the router though, neither will get online. theyre showing full connection, but wont bring up anything.
    Champion:
    Scholar:
  • 209 Answers
Probably, a problem with the IP addresses. A conflict between the two computers. Try to connect to the internet with only one computer turned on. Let the other one turned off. Find out the IP address with the command ipconfig. You may have to renew it (ipconfig /renew).
Then, go to the router config: See the manual of your router. You may have to reserve the 2 IP addresses in your router configuration.
Posted on May 24, 2008
I have one computer on the internet what do I do toset up a wireless router for second computer?
The wire that is connected to the first computer probably goes to your modem. Take the wire from the modem and put it into a wireless router that has wire output, put another wire from the modem back to your first computer. Then check the settings. You should then run the setup program for the new router so that you can set the wireless security and other settings.
Jun 05, 2014 | E-Machines Computers & Internet
Can I run 2 laptops off the same modem
There are several ways. Windows XP & Vista & 7 have 'ICS' ("Internet Connection Sharing") that allows you to connect the second computer to the first computer, and the first computer to the modem, so that the first computer is a "gateway" to the Internet for the second computer.
Or, buy a "router" -- connect the modem to the "uplink" port on the router,
and connect (wired or wirelessly) multiple computers to the "LAN" ports on the router.
The router acts as a "gateway" to the Internet for all the computers on the LAN.
May 25, 2011 | Computers & Internet
I need a ips address as my computer won't connect to the internext
Your modem/router should provide you with an ip address automatically. Otherwise(Im assuming that you are running Windows XP) go to Start>control pane>Network Connections and right click on your Local Area Connection. Click on properties and make sure your computer is set to receive configuration from modem/router automatically.
Jul 26, 2010 | eMachines W3623 PC Desktop
Only one computer is able to connect to the internet even though i have 2 connected to the router
Well the modem should be connected to the UPLINK port on the router(the port without a number) both computers should be connected to the numbered port. Ensure you do NOT have a problem with one of your cables.
Apr 17, 2009 | Computers & Internet
Wanting wireless hookup
1)Prepare your modem. Unplug the modem's power cord and place the wireless router unit next to the modem. If the router has antennas, make sure they are raised to their full upright position.
2)Reassign your networking cable. Unplug the cable currently connected from your computer to your modem and plug it into the port located in the wireless router. This port is usually colored blue.
3)Connect the router and the modem. Use the networking cable that came with your wireless router to connect the modem and router unit. The router port is typically colored in green.
4)Start up your modem. Plug in the modem's power cord and wait 1-2 minutes while it configures its settings and prepares to connect to the Internet.5
5)Start up the wireless router. Plug the wireless router's power cord into an outlet and wait 1-2 minutes to get it started. The router is ready when the 'wired computers' and 'modem' icons light up. These logos or icons vary by make and model of your router so consult the owner's manual if needed.6
6)Insert your installation CD. Use the wizard or assistant to check the configurations of your computer settings and launch your wirelessnetwork clip_image001.gif
Things You’ll Need:
  • Wireless Router unit
  • Networking cable (comes with router unit)
  • Installation CD
  • Modem
  • Modem power cord
Dec 02, 2008 | D-Link DI 713p (DI-713P) Wireless Router
Can Connect to internet via cable modem, but cannot connect from Cable Modem to LinkSys WRT54G router to PC to Internet ?
1. Make sure your cable modem is connected to the Internet port of the router.
2. Your computer should connected to one of the 4 ports at the back of the router.
3. Check the lights that are lit. Make sure the you have power(steady green), Internet, WLAN and Ethernet port light.
4. Press and hold the reset button on the router for 15 seconds.
5. After 15 seconds, release the reset on the router and turn it off.
6. Turn the cable modem off, too.
7. Wait for a minute. Turn the modem ON first. Wait for the lights on the modem to be ready.
8. Turn on the router. Make sure you have good lights on the router.
9. Check for Internet connectivity.
Nov 08, 2008 | Computers & Internet
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
Connectivity issues with linksys router
If it worked before it should work again. Turn the router off for 30 seconds and try again. Als make sure that the wired PC connects to port 2 or above.
Bob
Jul 28, 2008 | Linksys Wireless-G WRTP54G Router
Please help...internet won't connect
You may be running into a problem of your ISP only allowing one computer on the internet. while the internet is on can you access the internet from the desktop comcast originally setup?  If so that is more then likely your problem.
I have comcast myself and they told me they do not allow home networks. I fixed that problem by using the mac address cloning feature in my router.
The setup cd is also junk, all you should really need to do is:
1. unplug modem, router, and turn off computers
2. Plug modem into router
3. Plug computers into router (don't worry about wireless right now)
4. Turn on modem, wait 20 seconds or so for lights to set,
5. Turn on router. again wait for lights to set
6. Turn on ONE computer that is hard wired into the router
7 Try to surf the net.
8. If successfull try to connect wireless computers (Without using cd) and see if they surf.
If not call comcast and see if your computers are trying to obtain real-world ip's instead of LAN ip's like they should.
If so, you'll need to enable DHCP on the router.
Jul 18, 2008 | Belkin (F5D7230-4) Router (587009)
Adapters Compatible with the Westell E90-610014-06 Router?
run the modem to the router with Ethernet cable and then use one of the other Ethernet ports on the router and another Ethernet cable to connect desktop
Mar 04, 2008 | Westell Wirespeed LiteLine 6100...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
