Question about Bernina 1008
Hi, My wife's Bernina Minimatic keeps on running when it is plugged it in. My electronics knowledge is not too bad but I'm not an expert; I already tried to disconnect the capacitor (with the 4 wires) located at the motor, but it is still doing the same. So I think the problem is maybe within the pedal. It is continiously running at the low speed and when you push the pedal it runs faster. When you release the pedal it is returning to the low speed again. But it keeps on running. In the pedal there is a only a few electronical components and the circuit seems quite simple. Does anyone know where the problem might be? And if what component it would most likely be, so that I can exchange it? Thanks!!!
SOURCE: I am looking for an instruction manual
Can any please tell me where I can purchase a manual for a Bernina Artista 200 Manual as I accidently threw my away.
Regards Cathy
Posted on Feb 15, 2009
SOURCE: Bernina 430 aurora will not sew, beeps when pedal is pushed...
Ok, I feel like a fool but I figured out the problem. I didn't have my presser foot down! duh!
Posted on Mar 12, 2009
  • 980 Answers
SOURCE: Old model Bernina 830, running ok, then kept
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
Posted on Jun 27, 2009
  • 980 Answers
SOURCE: what is the difference between a bernina and a
Nothing at all apart from a few patterns and the size of the machine.
Posted on Oct 30, 2009
  • 233 Answers
SOURCE: I need a new or reconditioned motor for a Bernina
Try www.Sewingstyle.com. They carry a lot of parts for new and old machines. If they don't show it on their sight, drop them an email or call them. They may surprise you.
Posted on May 12, 2011
I have a Bernina Minimatic 807 which has stood idle for some time. It will run for a couple of minutes and then lock solid. I have oiled it, cleaned the shuttle and bobbin areas but it is no better.
........Start by removing the bobbin and bobbin case.
........The old grease is most likely hard.
.........Open the upper and lower areas and clean up all of the grease. Real hard debrees can be removed with carburetor cleaner.
........While turning the hand wheel you can spray this on parts to loosen the grease. Use qtips to remove the debrees.
........Use qtips that have been sprayed with carburetor cleaner to clean the plastic where the dried grease and filth is at. Try not to use carburetor cleaner on the plastic as much as possible.
........When the cleaning is finished use sewing machine oil on all parts that are steel against steel movement. (Not plastic or rubber).
........ For plastic against plastic use lithium or 100 % synthetic oil. These can be used in place of the grease because they don't become hardened due to wear and time.
Jul 05, 2017 | Bernina Sewing Machines
My bernina 707 minimatic..isn't working!! My needle keeps getting seized an won't move up an down...Then when i try to sew it sews blanks....
Replace the needle.
Make sure the needle is inserted the right way. If the needle is installed the wrong direction the machine will get stuck.
Check and correct tension of the bobbin. (Guide attached)
Start the top tension at four and adjust as needed.
When threading do it with the pressure foot up so any snags can be felt. If there are snags they must be corrected. While threading, little tugs of the thread along the way will help. The snags can be felt this way.
Aug 25, 2015 | Bernina Sewing Machines
My Bernina machine is 40 years old - a 707 minimatic but it is in perfect condition, regularly de-fluffed and oiled and had a new motor 4 years ago. A recent problem is with the tension. If I get the top...
You could try puchasing a replacement bobbin case, its possible that the tension spring on it has worn/stretched a bit. Try this website if you are in the USA - http://www.sewingpartsonline.com/bernina-707-sewing-machine-parts.aspx or just go to the bernina website and choose your country to find the head office in your country. They should be able to sell you the part or direct you to a local dealer closer to you.
Also clean out the top tension device if you haven't already. Turn to zero and floss between the discs. I use a clean selvage edge of a waste piece of cotton fabric or you could use dental floss or ribbon too, just something to get in there and remove any buildup. Thread, especailly darker colours, will shed dye particles and fibres and over time this can build up in the tension discs impairing their function.
Otherwise, sounds like you've had a really great run with your Bernina - if you don't already do this, then consider taking it for a service every two years too as the internals benefit from a lube on the older mechanical machines. It may be that the top tension device needs replacing to resolve your issue.
Jul 12, 2011 | Sewing Machines
I need a new or reconditioned motor for a Bernina minimatic 807 where do I look? Thanks
May 11, 2011 | Bernina Sewing Machines
What is the difference between a bernina and a bernina minimatic?
Oct 30, 2009 | Bernina Virtuosa 160
1967 Bernina 707 Minimatic is not running freely
Have you been oiling the bearings per the guide? Try to isolate the upper mechanism versus the lower by rocking the handwheel and observing which causes the bind (take the bobbin and needle thread off to prevent jamming). You may have to remove some of the covers to see most of it. As long as no gearing becomes shifted or uncoupled, you should not cause trouble. Try taking the motor belt off to see if the motor itself may be binding. Good to see people keeping old, but still working machines running
Oct 24, 2009 | Sewing Machines
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
I am looking for an instruction manual for a Bernina minimatic 807 sewing machine. Can you help please
Regards Cathy
Feb 14, 2009 | Bernina Sewing Machines
Sewing Machines Logo
97 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
