How to restore your windows 7 in command mode
  • 644 Answers
1. Restart your system
2. When the system first boots, type F8 to bring up the boot menu
3. Select the Safe Mode with Command Prompt option
4. Log-on as administrator if needed
5. At your command prompt type %systemroot%\system32\restore\rstrui.exe
6. Hit Enter
6. This will open the system restore wizard...
Posted on Sep 29, 2010
Hello, how do i do a factory reset with command prompt. the ususl method does not work as only optionsrepair and recovery ect are there. no reset option. dell latitudee7240 win 7. rstrui.exe. gets is
The instructions are:
  1. Turn on the computer.
  2. Press and hold the F8 key.
  3. At the Advanced Boot Options screen, choose Safe Mode with Command Prompt.
  4. Press Enter.
  5. Log in as Administrator.
  6. When Command Prompt appears, type this command: rstrui.exe.
  7. Press Enter.
  8. Follow the wizard instructions to continue with System Restore.
Restore To Factory Settings - Guide for Windows XP, Vista, 7, 8, 10..
before you try this go to this link and have a read up first.
factory reset with command prompt Google Search
Oct 29, 2017 | Command Computers & Internet
I want factory setting keys
To access System Restore via Safe Mode, follow these steps:
  1. Start the PC
  2. Press and hold the F8 key before the Windows Vista logo appears on your monitor
  3. At the Advanced Boot Options, select Safe mode with Command Promp
4. Press Enter
5. When Command Prompt is available, type the following command:
  1. rstrui.exe
6. Press Enter
7. Enter the password for the Administrator and press Enter, if prompted to do so.
8. Follow the wizard instructions to choose a restore point
Feb 07, 2016 | Computers & Internet
I need to restore my computer without disc, what should I write in command prompt?
To access the System Restore Gui from command prompt you will need to type in rstrui.exe
OR
%Windir%\System32\rstrui.exe
Other Thoughts
If you are experiencing Boot issues you will need to install a boot manager. If your system is missing a file or a file is broken, you may need to replace that file with a working version that's compatible with your OS Version.
Aug 07, 2015 | Dell OptiPlex GX270 PC Desktop
Dafina zeqiri supernova
What sort of a problem ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points.
Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Aug 24, 2013 | Computers & Internet
Windows won't start with safe mode (windows7 i meant)
Do you have the Restoration/Restore Disk?
If so pop it in the optical drive (CD/DVD drive), and when asked choose Repair.
(Non-Destructive Installation)
Post back in a Comment.
Regards,
joecoolvette
Apr 13, 2013 | Dell Latitude D520 Battery PC Notebook
How can i get rid of Dxerror 8876086C
Step 1:
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 22, 2013 | Logitech QuickCam Computers & Internet
My pc was restoring with tun up360,restareted,and now windows dose not work
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Jan 05, 2013 | Computers & Internet
After downloading updates my paptop will not configure windows
Try this:
Windows XP
To start System Restore using the Command prompt, follow these steps:
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
    Windows 7:
    1. Start your computer in safe mode with command prompt. For more information, see Start your computer in safe mode.
    2. At the command prompt, type rstrui.exe, and then press ENTER. 18abb370-ac1e-4b6b-b663-e028a75bf05b_41.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Aug 19, 2012 | Sylvania G-Netbook
My acer netbook (winxp) won't load after the mouse cursor appeared
Sounds like you need to run the check disk utiltity but since you don't have a CD Drive, you're up the creek without a paddle. try booting up into Safe Mode and if you get there successfully reboot and see if the normal mode works, if not you can uninstall Microsoft Security Essential in Safe mode. Or you can use System Restore to restore back to a point (date and time) when the system was working ok. Click Start/Programs/Accessories/System Tools/System Restore and select a restore point before you loaded Security Essentials. In Windows 7 just click Start then type System Restore in the search box above the start then look at the returned results and click System Restore.
System Restore does not lose any of your data, documents, music, pictures, videos or programs (unless the programs was installed after the date and time you selected).
To get into safe mode follow the steps below:
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
You can try to get to a dos command prompt or you can see if the system will allow you to boot in Safe Mode to get to the dos command prompt.
May 12, 2012 | Computers & Internet
Not compatable with windows 7
Hello
OK, please be more specific on the exact question or problem you are experiencing.
Kind regards
Andrea
Nov 26, 2010 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
