Question about Frigidaire FSC23F7D Side by Side Refrigerator
Both the freezer side and fridge side are not maintaining the correct temps.
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 28, 2010
Hii m habing problem with hotpoint ff200m Fridge is workng gfin but freezer not working. I have removed the panel to check. the fan and fan is working. Im still getting warning triangle light on
The freezer is the important side- if the unit can maintain fridge temps, but not freezer temps- you have a sealed system leak and are losing the refrigerant volume needed to create sufficient cooling. When you remove the freezer panel, there should be a fine layer of white frost across the entire length of evaporator tubing... GE Compressor WR87X20798
Jun 19, 2016 | Hotpoint Refrigerators
Kenmore 10654382300 side by side
Hi Vince,
Thanks for the posting in FIXYA.
Please repair the Freezer door as it is not sealing, due to which cooling is affected. If it is under warranty then contact to the manufacturer as soon as possible.
Regards
ELLIN
Sep 15, 2008 | Kenmore 25.1 cu. ft. Side-By-Side...
Jenairrefridgerator model jcd2292ktb, what is the temperature for freezer and refridgerator
If you want to set the temperature your Fridge/Freezer should maintain, you need to set the Freezer to between -19c and -23c, however if you will be keeping Ice-cream in this freezer then it's best to set the base temp @ -21c minimum, -23 preferable, or the ice cream may begin to break down (very slowly I might add). The Fridge needs to be set to a maximum Highest temp) of 5c, any higher and the food will not stay as fresh and bugs will be able to breed, preferable temp is approximately 3-4c.
Jun 20, 2012 | Refrigerators
What is freezer and refrigerator temperature suppose to be set on
Jun 20, 2012 | Jenn-Air JSD2789GES Side by Side...
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Gsh25vgpccc ge side by siderefrigerator
well if you keep that damper open im sure everything in your refrig- will freeze is the temp- in the freezer o.k. if you have an ice maker is it working properly because if your freezer does not maintain the right temp your ice maker wont work. if so you might have a bad temp control (thermostat)
Dec 23, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Bosch KGU32160 fridge freezer
The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
Oct 31, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Fridge part not cooling properly
Miss Sugarbaker, it almost sounds like a airflow issue, but check to see if the interior light is going out when the door is shut. This would cause the higher temps on the top shelves. The damper assy. is controlled by a thermistor that sends the temp info to a main board in the back. If this thermistor is bad, the damper will not funtion properly. Catriver..post back.
Sep 27, 2006 | Hotpoint HSS25GDMWW Side by Side...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
