Question about Danby DDR2504 Dehumidifier
Compressor stops at proper humidity % but the fan keeps running.
    Habit-Forming:
  • 156 Answers
Dehumidifiers are built that way. They keep moving air so it is able to keep any change of conditions moving around the room. On a dehumidifier, it the fan stops, your unit will short cycle becasue water will naturally evaporate from the water tank and it would turn on, then off, then on then off. The way it runs now is fine. Running the fan 24 hours on your dehumidifier cost nickels a day. Just let run.
Posted on Sep 28, 2010
Idylis dehumidifier 0526011 will not shut off even when is reaches it humidity level. How can I get it to shut off. The compressor stops but the fan keeps running.
this is a newer feature that a lot of units do now this is called air circulation mode !! try running on low it's not so noisy then
Oct 03, 2014 | Dehumidifiers
Keeps running compressor
Hey randall, thank you for your post!
I see that you're stating the compressor continues to run on your Frigidaire dehumidifier. What you could be hearing is the fan running. The fan will run when the compressor cuts off so that air can pass over the sensor coils to check the humidity. Hopefully this is helpful. -Matt
Sep 12, 2014 | Frigidaire Dehumidifiers
Should the fan shut off when the humidity setting has been reached for model Frigidaire CAD504DWL 50-Pint Two Speed?
Thank you for your post, friend!
I see that your question is if the fan should shut off once it has reached the recommended setting. The fan will run even when the compressor cuts off so that air can pass over the sensor coils to check the humidity. This is a normal operation. I hope this is helpful. -Matt
Sep 12, 2014 | Dehumidifiers
Compressor Works for a while Only On Initial Plug-in
If your machine is equipped with a humidistat it could be faulty and not sensing the humidity level accurately.
Mar 05, 2017 | Danby Premiere DDR5009REE 50 Pint Capacity...
The fan never stops running. The dehum. works fine that is the only problem. Is it the way I have it set how can I change that?
Bob, some humidifier fans run a lot, because they are designed to keep the air moving and when the humidity level rises, the compressor turns ON to extract the humidity. If you're operating the unit in a continual mode, it's not unusual for the fan to run almost constantly.Especially, is the humidity extraction level is set at or above 50%. Lowering it to 35% will cause it to extract more humidity and will turn on an off less.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | Whirlpool AD50USL Dehumidifier
Why does the fan run non stop? the compressor runs and shuts off but the fan just runs on high and low. I have 3 other dehumidifiers that the fan runs only when the compressor runs...why doesnt the...
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Aug 14, 2011 | Friedrich D50C Dehumidifier
I have a DDR7009EE and the fan runs continuously even when the humidity in the room is below the setting on the machine. Shouldn't the fan stop when the desired humidity is reached?
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Jul 28, 2011 | Danby DDR5009EE Dehumidifier
I have a Danby Silhouette and the fan works but the dehumidifier doesnt.
Bryan, it may imply be a case of the humidity extraction level being set to high. Lower the level to 35% and see what happens. As far as the fan running is concerned. Most dehumidifiers are designed for the fan to run, even if the compressor doesn't turn ON. It's designed to keep the air circulating and if the humidity rises above the setting you have it on, the humidity sensor will pick up this change and turn the compressor ON.
Also, remove the air intake filter to see if it's clogged and needs cleaning. Maintain at least a minimum of 12" of free air space all around the dehumidifier. Poor air circulation will prevent the unit from working properly. As will, to low an ambient air tempeature. Most unit struggle to work at temperature between 40 & 60 degrees F.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 04, 2011 | Danby DDR451 Dehumidifier
LG LD65EL Dehumidifier doesn't work properly
What do you have the humidity level set at on your dehumidifier? The average is 65%. Make sure you do not have it set at 75% because if you do this could be causing it to keep the humidity so high.
Jul 02, 2008 | LG LD65EL Dehumidifier
LG LD65E humidity variance
Is the compressor running or is it just the fan? If its just the fan it is because it is cycling the air and it uses that air flow to check the humidity in the air. If the fan runs non-stop and the compressor does not turn on or the fan does not shut off there is a problem with this unit and you will need to replace it. Since it is brand new you should still be able to return it to the store.
Jun 27, 2008 | LG LD65EL Dehumidifier
Danby DDR2504 Dehumidifier Logo
261 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
