Question about Universal Office UNV-38016 Shredder
We have a Universal Shredder 38103 at our office. The "open door" indicator is on and won't turn off. We have turned it off, unplugged it, cleaned it, vacuumed it out, removed as much loose paper bits as possible and it still won't work. We can't seem to find the owner's manuel (if one in fact exsists) and I can't find a website for Universal either. Can anyone offer another solution? It appears, though we are uncertain, that a piece may be missing on the door, so no connection is being made.
    Welcome Back:
    Visited the website for 2 consecutive days.
On the upper right corner of the bin opening you will see a slot in the black plastic. I taped a part of a business card into the slot and it now works. Just make sure to unplug the machine when the door is open.
Posted on Jan 05, 2011
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
Shredder won't shred. can't hear motor in the forward setting only in reverse
Silverfox007:
There is a paper sensor at the throat of the machine that turns the machine on when it is activated by the paper when the paper is inserted. Something has happened to that sensor. Unplug the machine and remove the shredder head from the basket. Use a screwdriver to remove the screws at the bottom of the shredder head and open the shredder head. Look where the paper is fed into the machine and you will see the sensor. It may be unplugged/wire broken/sensor flag broken off... You'll know what to do when you identify the problem.
Sep 06, 2012 | Office Depot ATIVA DX120P Shredder
Shredder won't stop running
THERE MAY BE SOME PAPER SHREDS BLOCKING THE LASER LIGHT.
UNPLUG SHEDDER AND CLEAN CUTTER HEADS.
Sep 30, 2011 | Office Depot Ativa DQ60M Shredder
Shredder screen reads door open even if the door is closed and wont let me do any shredding
Unplug it and then open i t up. You are looking for a piece of shredded paper that is stuck or jammed. Can even be a accumulation of paper dust. The piece won't be that big but most of the time that is all that is wrong. The paper either jams the door sensor or blocks it and gives the error. It can also be a bad door sensor or switch. Not very common but can happen.
Apr 25, 2010 | Universal Office UNV-38016 Shredder
We bought a Universal Shredder Model 38103 a few weeks ago at an office supply auction. We had it plugged in at the office and when we came in this past Monday, the whole top of the shredder had melted. We...
Most likely a fault in the transformer on the mains voltage board (behind and to the right of the slot) causing a short circuit and the coils in that burning out. Another possibility would be that the paper feed sensor failed due to excessive debris/paper dust build up causing the motor to run continuously until the coils in that burned out (to the left and behind the slot. A third is the voltage regulator IC on the processor board (between the two slots) can run very hot, and in the extreme case this would also have the potential to cause an incident. The best idea is to look inside the shredder for burned components, or have your fire department do this for you.
Al Murray
Mar 11, 2010 | Universal Office Equipment & Supplies
Shredder will shred about 3/4 of a sheet of paper then shuts off. If you open the shredder door it resets the power switch and you can finnish shredding the remaining paper. is there easy access to the...
If your shredder has a feature where it won't run with the door open/shredder off the bin, you probably need to make sure that the safety is engaging properly. If the motor seems to sound very labored when it runs, unplug it, and check the blades to make sure there's not a lot of extra stuck in them. You may need to clean them and lubricate it with special shredder oil ONLY.
Nov 24, 2009 | Fellowes Office Equipment & Supplies
SHREDDER WILL NOT POWER UP. NO LIGHTS, NO POWER
you will need to open it and test the on/off switch, door switch, fuse all for continuity. turn the machine off and unplug it . unscrew it from the base. flip it over, unscrew the bottom. now test with a dm. if you are needing a tech i michigan please call 248-677-8112
Oct 23, 2009 | Royal 150MX Cross-Cut Shredder
Shredder will not turn on, I think it is blocked.
Unplug unit , open it up and clean it out , then lets see what its doing or not doing
Dec 05, 2008 | Office Depot Ativa DQ60M Shredder
Shredder will not cut paper makes but reverse works
more details?
does it turn on , start to cut but jam up ,,,
Unplug unit , open it up and clean out the cutting teeth with a pik or screwdriver vacum or blow it off with air . then try
Dec 02, 2008 | OfficeMax 0M96431 Shredder
Universal Shredder 38016
Sounds like the pcb is faulty.Get a new board or a new Shredder. Dave UK
Feb 22, 2007 | Universal Office UNV-38016 Shredder
336 people viewed this question
Top Universal Office Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Universal Office Office Equipment and Supply Expert? Answer questions, earn points and help others
