Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Bosh aquasensor dishwasher - when I press the desired temperature button 2h comes up on display panel. It drains then nothing happens.
eagle338
  • 4889 Answers
SOURCE: Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
Posted on Dec 13, 2007
  • 7 Answers
SOURCE: Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Posted on Jul 29, 2009
  • 430 Answers
SOURCE: Cycle runs forever
Th Bosch units are prone to circuit board failure and this is the common symptom. If you are electronically inclined go the applianceaid.com and search Bosch for test codes to pinpoint the issue.There is an online picture of the faulty relay solder joint I repaired mine and a neighbors, Bosch will in some cases supply parts at no charge and they do not recommend repair, however IMHO it is a repairable cold solder joint very visible on the board. If you are good with needle tip soldering iron you are in luck
Posted on Sep 07, 2009
milten1
  • 1304 Answers
SOURCE: My Bosh dishwasher seems to be stuck in the drain
check your flaot valve,, it just may be stuck in the up position, this sometimes will happen from a peice of glass or a fork i even seen it just get stuck
but if its pumping that float valve must be in th up position
Posted on Nov 04, 2009
  • 457 Answers
SOURCE: My bosch dishwasher control panel displays 0H on
check to see if your unit has a recall on it because if it does you will get a free control module from bosch.
your problem is the control module. thermador .com is the site to lookup. gaggenau,bosch,thermador they are the same ccompany. let me know if this helps by sending a 4 thumbs up post
Posted on Feb 28, 2010
Bosch dishwasher has a buzzer on all the time .
I'm not sure if you mean it is buzzing because of a fault or if it buzzes to say the program has ended and you want to switch this off??? if it is the later the following should help
To activate any of the Dishwasher Options listed, follow these steps:
Open the dishwasher door far 1. enough to expose the control panel.
2. Press the On/Off button.
3. Press the MENU/OK button until the desired option appears in the display window.
4. Press the - or + button to step through the available option settings.
5. When the desired setting is shown in the display window, press the MENU/OK button to save the setting. The display will indicate "Value Stored" and return to the main
menu. If you did not change the setting, press the start button to return to the main
menu.
6. Select the desired wash cycle by pressing the - or + buttons.
7. Press the start button and close the dishwasher door to begin the cycle.
NOTE: In the Options Step Down Menu, you can return to the main menu at any time by
pressing the START button.
Feb 20, 2013 | Bosch SHX98M0 24 in. Built-in Dishwasher
When i press any cycle the display shows the est time but when i press stsrt i get two daches in display and nothing happens i have chrecked the door switch for continuety its is ok the flod seemsa to be...
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 18, 2011 | Kenmore 16932 Built-in Dishwasher
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Error code 2H
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
My bosch dish washer won't work. A number 1 is displayed on the electronic panel. what does this mean Paul
Helloduranjp,
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Huuum
Oct 02, 2008 | Bosch Dishwashers
Stuck on 2H
My wife got our Bosch diswasher "unstuck" from the 2H position by pressing buttons randomly. Sorry this sounds so serendipitous! Good luck!
Mar 05, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch aquasensor diswahing machine
To reset the board so as the times will go back to factory settings.
Turn appliance on press both buttons that have the two dots under, the display will then go back to zero. Shut the door and allow appliance to reset itself. This normally takes about a minute, whilst it's doing this the pump will be running.
Hope this helps
Deep Diver
Dec 31, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
