Instruction manual for Bosch Washing machine Model WFG 2420
3 Suggested Answers
rickyrt441
  • 4399 Answers
SOURCE: I have a bosch WFG
Thanks for choosing FixYa and welcome to the site. Since the code is for the door, it makes sense that the washer will not work. Try adjusting the lock switch. It may be bad but sometimes you can adjust it and mess with it. Hopefully, the washer will then work. If not, you are going to need a new one. I still don't know why they have these. They cause more problems then they are worth. If you have a questions, feel free to ask and thanks for using FixYa.
Posted on Apr 09, 2011
  • 6277 Answers
SOURCE: Our bosch washing machine is
As you do not mention 'filter' I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 05, 2011
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Bosch Instruction Manual
Will any Bosch instruction manual serve, or do you have a specific model in mind?
May 06, 2013 | Bosch Washing Machines
Instruction manual for bosch maxx classic wae18060au please
http://www.bosch-home.co.uk/customer-service/download-product-manuals.htmlYou will need to enter the Enr number from the rating plate ( on the inner door trim) use the link, click on Click here to download product instruction manuals. This will open a new window where you can enter your machine model. IU is user info..II is installation info
Nov 27, 2011 | Bosch Washing Machines
Our bosch washing machine is about 9 years old and won't drain properly. The "end" light flashes as if the drain is blocked but it's not. If we manually drain the machine we can get onto...
John C
Jun 05, 2011 | Bosch Washing Machines
I have a bosch WFG 2420 washing machine. It tripped the electric switch and now it will not work. The machine switches on but it keeps on flashing on the ready light. Says in manual that the door is not...
Apr 09, 2011 | Washing Machines
No manual came with our new bosch avantixx 6 washing machine
Unfortunately you cant download manuals from their web site so heres their phone number. Hope this helps you.
BSH Home Appliances
5551 McFadden Ave.
Huntington Beach, CA 92649
Telephone :1-800-944-2904 Fax :714-901-5360
Jan 10, 2011 | Bosch Washing Machines
Hi. I have a Bosch precision wfg 2820 front load washing machine. The drum no longer spins round. The belt is still attached and seems to be ok. Any ideas where to look next? Thanks
You say seems to be ok.....can you hold the belt and turn the drum? Is there more that 3/4" slack in belt when you push it side ways? How old is this machine and have you ever had it serviced?
Jan 03, 2011 | Washing Machines
My bosch exxcel washing machine has the child lock on how do i take it off
Type in Bosch exxcel (and the model) Instruction manual... into the top right hand address bar on your pc and scroll down the list. You will find all the instruction manuals you need online.
sue
Aug 03, 2008 | Washing Machines
Bosch Maxx Instruction Manual
F:16 - Doors are not properly closed. Check the doors are closed with no obstacles.
F:17 - Water is not running. Check the tap, hose and filters. Also water pressure can be low.
F:18 - Too much water remaining. Stop the drying program and start Spin program. Otherwise something is bolcking the water exit from the machine.
Jan 22, 2008 | Washing Machines
Washing Machines Logo
1,175 people viewed this question
Top Washing Machines Experts
