Question about Goldstar DH304 Dehumidifier
GoldStar dehumidifier coil freezes up within 12 hrs of operation. I have cleaned the filter
  • Goldstar Master
  • 43,501 Answers
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Sep 28, 2010
Hello , I have goldstar dehumidifier model #DH40 . It's freezing from back grill? Can you please give me some solution to it? Thanks for you're help
It sounds like not enough air flow. clean the filter. I would suggest unplugging it and let it set for a day to dry out then replace filter and clean the air path including coils.
Jan 10, 2014 | Frigidaire FAD704DUD Dehumidifier
I noticed today our Goldstar dehumidifier was running, but the back was all frosted up. What does that mean?
That's an indication, that the filter needs to be removed and cleaned.
Turn the unit OFF & unplug it before removing the filter. You can vacuum the filter or if it's really dirty, wash it in warm water and dish washing liquid. Rinse thoroughly and allow to completely dry, before reinstalling. Never operate the unit without the filter installed.
If the coils continue to frost, but not defrost, they also should be cleaned.
Jul 18, 2011 | Goldstar DH304 Dehumidifier
Back and coils freezing up
There are 4 basic, but solvable reason for what you described. Before undertaking any of them, Turn the Master ON/OFF Switch to OFF and unplug the unit. Allow the unit to thaw completely.
1. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
2. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
3. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
4. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications . Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the defrost sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to trouble shoot and solve the problem.
Jun 30, 2011 | Goldstar DH5010B Dehumidifier
I havea goldstar dehumidfierthe problem I clean the filter and now I will also clean the coil it turns on for a short time then shuts off can you help me????
snickers, you may have the humidity extraction level set to HIGH. Lower it to 32-35% or if you don't have an LED readout, turn it to Maximum. Be sure that you have 12" to 18" clear air space around the entire unit.
With what you have already completed as far cleaning is concerned (Filter & Coils), the above should solve your problem.
Jun 22, 2011 | Goldstar DH304 Dehumidifier
Coil frosts within 15 minutes in a warm room. After 1-2 hours they coils are covered with snow like frost 1 inch thick.
heatman101
Apr 30, 2011 | Goldstar DH304 Dehumidifier
Dehumidifier freezes up
heatman101
May 26, 2010 | Goldstar DH5010B Dehumidifier
Frost
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier2_bing.gif is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 17, 2010 | Goldstar DH304 Dehumidifier
Coils freezing up
The largest culprits for freeze up are dirty filter, dirty coil behind filter....and on certain occasions, low on freon.
May 12, 2010 | Goldstar DH2510A Dehumidifier
Goldstar ghd30
Make sure condenser is clean.
Apr 10, 2010 | Goldstar DH304 Dehumidifier
Dehumidifier runs loud
What is the temperature in the space where you are operating thsi dehumidifier? When you first start a refrigerating system some refrigerant may have condensed into the compressor oil. When the compressor starts the pressure in it drops rapidly. The oil boils and some passes through the compressor valves. After a few minutes of operation this condition normally corrects itself.
May 16, 2008 | Goldstar DH504EL Dehumidifier
Goldstar DH304 Dehumidifier Logo
471 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Jerry Greenberg
Jerry Greenberg
Dan Webster
Dan Webster
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
