Question about Mitsubishi HS-U447 VHS VCR
TAPE KEEP SKIPING. CANNOT CONTROL TRACKING - Mitsubishi HS-U447 VHS VCR
  • Mitsubishi Master
  • 5,390 Answers
Try cleaning the heads with Servisol Video 40. It's best to take the top cover off and give it a good clean. Use cotton buds, spray and wipe anywhere the tape comes into contact with. If that doesn't cure it you might have a worn video head.
Posted on Sep 28, 2010
How do i adjust the tracking using a remote
the TRACKING IN VIDEO VCR , you can adjust from your remote control, you must identify by reading your instruc, manual download for free. go to www.fitness.manualsonline.com or www.retrevo.com
God bless you
Jul 13, 2012 | GoVideo Go Video DVD/VCR Combo
Where is the tracking on this VCR toshiba w403?
On this unit there is no manual tracking button - it's done automatically by a special circuit that uses the special signal from the tracks themselves. If the tracking is bad then the heads are dirty and they don't pick that special signal.
Clean them with a special cleaning tape. If you can't source one the unit will have to be dismantled and the 4 heads will have to be manually cleaned with a q-tip moist with alcohol.
Jul 26, 2011 | Toshiba W403 VHS VCR
I am having problems with the tracking at the top of the screen. This was given to me so I have no remote. Is there anything I can do without the remote?
First make certain the video heads are clean. If OK then most VCR use the up down TV channel selector to adjust the VCR tracking when in play. To test put in a good tape and play it, then keep your finger on either up or down button. If it works it should stop tracking properly (pressing the other control will bring it back).
Jan 09, 2011 | Emerson EWV404 VCR
My jvc has developed a tracking problem when viewing tapes recorded on other recorders. I cant seem to correct the problem. It shows old tapes without a problem
VCR tracking has to be set up right, but even then many machines have problems with tracking other vcr's tapes. Generally a good quality commercial tape should track well. If it doesn't then either there's a fault with the tracking on your machine or the tracking is not set up right. Most tracking problems are caused by dirt, or wear on the heads or surfaces. Give your VCR a good clean up, every surface the tape comes into contact with, using Servisol Video 40. If that doesn't solve it you might have to look into the cost of replacing heads, maybe the control/audio head first. Or you should look at having the tracking set up by a proffessional (at a JVC service center). However if the tracking was off, after resetting any tapes the machine has done, may now have problems tracking, whilst other machines tapes and commercial will track normal.
Jun 28, 2010 | JVC HR-S6970 S-VHS VCR
Memorex MVD4544
Low FM from the video heads is a common cause of this lack of tracking.
Jul 13, 2017 | Memorex MVD4543A
Skiping
Skipping can be the loss of tracking information or a bad motor. Try cleaning the lens using a cotton swab and alcohol. Also, look at the rails that the optics ride on. clean those using a dry cotton swab. There should be small gears close by that move the optics along the rails. Make sure that the teeth are clear.
Keep us posted on your results.
Dan
Jun 10, 2008 | TDK DA-3826 2-Disc CD Recorder
Tracking
Does this happen on ALL tapes?
Depending on WHICH model VCR you have (old or new) SOME have a switch which will allow you to adjust tracking MANUALLY. When the switch is in the manual position, it won't track automatically. If some played with that switch, that could cause your problem.
ALSO, do you have a cleaning tape? If the control track head is dirty, it won't see the "control track" (which gives you VCR information to control the tracking.
Another possibility is one of the video heads (there's 2 or 4) is dirty, and without ENOUGH video signal coming off the heads, it's not possible to track properly.
Try running a cleaning tape through. If you've never done it, it might be time. Unless yu know about equipment I'd wouldn't suggest you open the machine and clean it yourself. Let me know how you make out.
Mar 16, 2008 | Sylvania 6260VF VCR
Tracking won't zero in
try cleaning the heads with a head cleaner or even a high grade blank tape letting it play for 20 mins.
hope it helps
wg
Feb 02, 2008 | Sylvania DVC840F
Old Betamax Sony SL2300 Possible Tracking problems
A common problem with this model and others is the tracking pot itself fails. Wiper in pot breaks loose. Test if the tracking control has any effect?? If not, pot is bad.
Other causes are dirty heads and tape path but, the tracking control should always have some effect on PB pic. Bad video head, tape guides loose( tape not tracking on video head correctly), guide pin problem on loading ring, slack brake problem, etc.
Nov 05, 2007 | Sony Playstation 3 (PS3) Console
Vcr tape problem
It sounds like the tracking information is being lost for brief periods of time. Tracking is recorded at the lower edge of the tape, and if the tape is wrinkled or otherwise damaged in this area, playback will go out to lunch. A visual check of the tape would be in order. Have the heads been cleaned in these machines? This would be another area to check.... Also, there could be small differences in the tape path alignments, perhaps the control/audio head alignment is slightly different between the 2 machines.
Apr 28, 2007 | Panasonic AG-1980 S-VHS VCR
Mitsubishi HS-U447 VHS VCR Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
