Question about Kenwood KSC-WD250 Car Subwoofer
So i just got a Kenwood KSC-WD250 off one of my friends but it is strictly just the sub&box and the wired remote is gone. Is there a way I can hook it up to my amp?
4 Suggested Answers
  • 7 Answers
SOURCE: Wiring a Kenwood KSC-WD250 Subwoofer
7e83231.jpgi had the same problem Here is the diagram i used from someone else on fixya.  Thank you.
Posted on Jul 21, 2008
etirbynnor
  • 655 Answers
SOURCE: Installing self amplified sub to factory stereo
Hello Jax GS300,
Yes, you can use RCA cables. Just wire in a "low-level" converter.
Using RCA's is really the best way, allowing you to run shielded wiring to the sub, making it less likely that the wiring will pick up electrical interference. I'd install the converter on the rear speaker wires behind the dash.
If you do not want to convert the speaker output, you can drive the Kenwood directly from the speaker wires. The diagram in the install manual shows the connections coming off the rear speakers.
Here's a link to one output converter. This one will convert all 4 speakers.
http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html?search=level+converter
Hope this helps.
Posted on Apr 11, 2009
  • 32 Answers
SOURCE: how to disconnect Kenwood KSC-WD250 Powered
There should be RCA's power and ground connections. the rca's run behind the stero, the ground runs somewhere to the frame of the car and power runs to the positive post on the battery.
Posted on Jun 14, 2010
I have a kenwood ksc-wd250 subwoofer and the wire harness thats on the amp has 2 blk wires, 2 yellow, 1 blue w/white stripe, and 2 green and 2 purple wires. How do I wire this into my system. What color...
Sounds like thats for high end speakers.....should connect rca cable to the input and only other wires should be positive (b+) ground (negative) and remote (blue wire)
Mar 27, 2012 | Kenwood Car Audio & Video
How to disconnect Kenwood KSC-WD250 Powered Subwoofer from my car stereo
Jun 11, 2010 | Kenwood KSC-WD250 Car Subwoofer
How do you hook up a sub and amp to a stock radio with NO RCA outputs?
you can splice into the wires for your rear speakers and install some of your owns rca's and just use the low pass filter on your amplifier to eliminate the mids and highs from the frequency to your subs.
Jun 24, 2009 | Kenwood KSC-WD250 Car Subwoofer
I just got the Kenwood Sub KSC WA100 from my cousin with no electric wires or nothing so pretty much what all do i need and where can i find it i will be putting it in a 07 nissan sentra 2.0
Subs are subs, they come with no wiring. You need an amp and all necessary wiring to get it bumping. What type of deck do you have? Where will the sub be placed? In the trunk? Amp install is easy. Also suggest purchasing one of those amp kits for $20-$30, makes it a bit easier.
May 03, 2009 | Kenwood KSC-WA100 Car Subwoofer
Hello Jax GS300,
Hope this helps.
Apr 09, 2009 | Kenwood KSC-WD250 Car Subwoofer
Ksc-w800 installation
Any sub will need an external amp - a head unit amp doesn't have the suds to drive it. You can try it with the deck but you'll only get a whisper out of it.
Sep 01, 2008 | Kenwood KSC-W800 Car Speaker
Remote wire
If it is one sub with one amp, one remote needs to be hooked up. Not familar with your exact set up, but should stay constant for all. The remote signals the amp to turn on power when the deck is turned on thats it.
Aug 22, 2008 | Kenwood KSC-WA100 Car Subwoofer
Nov 27, 2007 | Kenwood KSC-WD250 Car Subwoofer
Kenwood receiver/sub problem
The amp's remote turn-on wire is probably connected to the blue wire coming from the back of the stereo - this is intended for a power antenna, which is why it only works when listening to the radio. Disconnect it from the blue wire and connect it to the blue/white wire coming from the back of the receiver and you should be good to go.
Sep 21, 2007 | Kenwood KSC-WD250 Car Subwoofer
Car Audio & Video Logo
46 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
