Agitator does not move around to much, can it be removed to see if anything is stuck underneath?
    Top Expert:
  • Washing Mach... Master
  • 77,169 Answers
Yes the agitator is held on by a nut under the plastic top cap on most washers, remove this nut to remove agitator, be warned that the agitator will most likely be rusted to the drive splines from the washer transmission and u may be unable to remove without professional help, bottom line it is not easy to get off if washer is more than a few years old.
Posted on Sep 28, 2010
How do I remove tights stuck underneath agitator on a GE GTWP1800DWW washing machine?
Do a google search for manuals. Or go to YouTube.com or appliancepartspros.com or repair clinic.com for repair videos. Put in ur make/model and search agitator. Good luck and good for u for doing the right thing.
Mar 26, 2015 | GE Refrigerators
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
I have a GE top load Model GTWN 4950L, there's a belt (cloth) that's stuck around the bottom of agitator. How do I remove it?
On the top of the agitator is a cap. Take it off, then there is a nut and a lock washer and you remove those and lift out the agitator. Then you can take the belt out.
Feb 28, 2013 | Washing Machines
Machine not spinning dry
Top-loading washing machine has an outer tub that fills with water and sits stationary as well as an inner tub with holes in it. The inner tub has an agitator that attaches to the drive shaft. A drive belt turns the drive shaft, causing the agitator to move back and forth. Broken seals at the bottom of the agitator, or a broken belt, may cause the agitator to perform inefficiently and leave your clothes dirty
In order to properly wash clothes and prepare them for drying, a washer must agitate or spin the load. This helps wring excess water out of the clothing. If your washer has suddenly stopped spinning properly, you will notice that your clothes will be sopping wet when the washer is done. Typically, there is a simple reason for this problem that you can fix without calling in a professiona
1 Check the lid switch. You will notice on the lip of the lid there is a small stem that hangs down. This fits into a hole on the top of the washer housing and tells the washer the lid is closed and it is safe to spin the load. If the switch is faulty or has been blocked, the washer will not agitate or spin.
2 Clean out the switch receptacle. Use a multipurpose cleaner and a sponge (not a paper towel, it can shred and get caught in the switch receptacle.) Thoroughly clean the area around the switch and the receptacle.
3 Test the washer. Close the lid, allow the washer to fill with an inch of water, and move the selector to the spin cycle. Pull out on the selector. If it does not spin, stop the cycle (push the selector in) and turn the washing machine off. This means there could be three problems with the washer: the switch might be broken, something might be caught in the agitator, or the motor for the agitator may be burned out.
4 Check underneath the agitator. Small items such as underwear, panty hose or bra straps can become caught underneath the agitator and keep it from moving. Run your hand underneath this area and see if you feel anything. If you do, unwrap the item and test the washer again. If it still does not work, move to Step 5.
5 Contact a repair person. If the washer still will not agitate or spin, it will need to either have the switch replaced or the motor replaced. Contact a certified appliance repair person to have the machine inspected. If it is still under warranty, the repair person's visit should be covered.
However if its only the agitator arm, then
Instructions to Remove/replace the Agitator
1 Unplug the washer.
2 Slide a putty knife under each side of the washing machine top to release the springs holding the top in place. Lift up the top on its hinges.
3 Pull the tub clips from the inner tub using a pair of pliers.
4 Pull up on the agitator top to expose the nut holding it in place. Remove the nut using a socket wrench. Lift up on the agitator to remove it from the machine.
5 Turn the agitator upside down and remove the seals from the bottom. Replace them with a new set of seals. If the agitator is cracked, replace it.
6 Reassemble the washer.
Removing the Belt
7 Unplug the washer from the wall outlet.
8 Pull out on the bottom panel on the front of the machine. Look underneath to locate the drive belt.
9 Pull on the drive belt at the washer tub to remove it. Push down on the idler pulley near the motor to remove the belt from the machine. Route the new belt around the pulleys in the same way as before.
10 Reassemble the machine, plug it in and test.
Apr 20, 2012 | Whirlpool Washing Machines
Diplomat ADP 8322 - 11 Flashes. Will not go beyond the Rinse cycle.
There's never a good time for the washer to stop working correctly. If a washing machine's agitator isn't working properly, your clothes won't come clean.
The back-and-forth movement of the agitator is a main function in the cleaning process of your laundry.
If your agitator isn't working, it could be the agitator itself or broken splines in the assembly beneath the agitator. Either one is a relatively easy and inexpensive repair that you should be able to do yourself.
Instructions and material needed :Socket wrench,Rope,Broom,Replacement parts
  1. Inspect the agitator for breaks. If the agitator is broken or cracked, you'll need to replace it. A broken agitator won't operate correctly, if at all. If the agitator looks fine but isn't moving, you'll need to inspect the plastic splines in the agitator assembly located underneath the agitator.
  2. Remove the agitator from the washing machine by first removing the fabric softener dispenser cap on top of it. This cap should either pull or screw off. It it's difficult to remove, you might have to pry it off.
  3. Unscrew the bolt beneath the softener cap with a socket wrench. Once you've removed the screw, try lifting the agitator out of the washer. If it doesn't easily lift out, loop a rope underneath one side of the agitator and over a broom handle. Continue looping the rope under the other side of the agitator and back over the broom. Using caution not to hit yourself in the head, pull up on the broom until the agitator comes loose.
  4. Replace the broken agitator with a new one. Snap the new one in place and secure the bolt underneath the fabric softener cap. Place the cap back on the agitator and you're ready to start washing.
    Check the plastic splines in the assembly directly underneath the agitator, if the agitator itself isn't broken. If the plastic splines are broken or worn down, this will keep the agitator from properly moving. In fact, it might not move at all. Replace the spline assembly with a new one and reassemble the agitator by reversing your steps to remove it.
Good luck and thanks for using fixya.
Dec 24, 2010 | Dishwashers
I have whirlpool model LSR7233EQO and one belt of cotton stuck under the propeller
If you are referring to something being caught under the agitator, you can remove the agitator easily, by following these steps:
1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up.
With the agitator removed, you can easily retrieve anything caught underneath. When reinstalling the agitator DO NOT overtigthen the center post nut. Tighten until snug.
If this is not what you are referring to, please post back and let me know, so I can provide you with better assistance. I hope this is helpful to you.
Feb 28, 2010 | Washing Machines
Material chord lodged around agitator of kleenmaid KAW393 washer
sorry to saybut you would probley need to stripp down most of the unit...to remove chord.
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do I take out the agitator?
I'm not sure if this is the same as your machine but here is a link to a possible solution:
http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
I hope that this solves your problem.
Apr 15, 2009 | Washing Machines
Kenmore washer agitator
Remove the agitator cap and the bolt in the middle that holds the agitator. Reach underneath the sides of the agitator and pull up. Try gently rocking it around as you pull, I'm sure it's going to be stuck pretty tight.
Mar 12, 2009 | Kenmore Washing Machines
Washing Machines Logo
Top Washing Machines Experts
