Question about Westinghouse Electric TX42F810G 42" LCD Monitor
Westinghouse TX-42F810G looking to replace power supply board. Where can I get Replacement parts? part# WS0938000BE 008X
  • 1,684 Answers
The part number you need is actually FSP201-3F01, You can get them online for around $80-85 plus shipping. Your board should be repairable. We should be able to rebuild the board for about $35-40 plus shipping. If you are interested in getting the board rebuilt just let go here and setup a service request: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Posted on Sep 28, 2010
  • jerwahlstrom Jan 25, 2012
    Where can I find other part numbers? I need the part #s for a screen on two models- tx- 42f810g and also VR-4085df. Thank you
Westinghouse tv turns on power light blue works for 3 minutes then turns orange
This is going to be associated with your inverter or your display board. Some cases they are the same board. You will have to take this apart, find the board and then find a replacement.
Apr 13, 2014 | Westinghouse TX-42F430S Television
Westinghouse model tx-42f430s won't power on
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Thanks for using fixya...
Sep 24, 2012 | Westinghouse TX-42F430S Television
I have a westinghouse sk32h240s. wont turn on and no amber light.
First try a new power cord for the TV. If that doesn't solve the problem, the power supply has failed. (Possibly one or more capacitors on the power supply board have failed. Alternatively, a fuse, zener diode or resistor that works as a fuse has failed) You will need to open the tv and inspect the power supply. Westinghouse TVs use a number of different boards. If you want to replace the entire power supply, you will need to note that exact part number on the label. ShopJimmy has refurbished and used power supplies for this model: http://www.shopjimmy.com/westinghouse-sk-32h240s . The used ones are from TVs that were damaged in shipping and thus have minimal use. http://www.partstore.com/Model/Westinghouse+Digital+Electroni/Westinghouse+Digital/SK32H240S/Other+Remotes.aspx also has replacement parts.
I hope this helps.
Oct 03, 2011 | Westinghouse SK-32H240S Television
Hello, I have westinghouse lcd tv model # TX-42F810G, The problem is, Monitor seems to power up but nothing showing on screen. do you know what's the fuse on the main board? location number?, any...
Yes there is a fuse, but it blows only when there is a major defect with the boards of the tv.
You need to do some troubleshooting to locate the fault. First look and listen to the tv while you are powering it up with the button on the case: if you don't see any change in the status light and don't hear any click then the power source has suffered a catastrophic failure and the tv will have to be dismantled and tested to find out why before replacing the power board.If the light blinks and you hear the clicks it means that the power board is working, tries to start but the failure of another board stops it and sends it in a emergency shut-down. The most likely board that would cause that is the mainboard but also a massive failure in another boards can cause it - more testing is required.
Finally if the tv appears to have started, (the light is green,you can hear sound but the image is missing) , you will need to get a flashlight and from up close point it at the screen: If you can see image in there it means that the ballast(backlight inverter) board has failed, if you don't it's the T-Con board, replace them.
You can get them from here
http://www.shopjimmy.com/westinghouse-tx-42f810g-tw-59601-c042h/
Jul 22, 2011 | Computers & Internet
Westinghouse TX-42F810G remote code
Hello, the remote codes depend on what remote you are using, for example, if you are using a universal remote you would use the Sony codes. For more information please send me a quick email to westytech@westinghousedigital.com.
Sep 26, 2010 | Westinghouse Electric TX42F810G 42" LCD...
Power light flashing tv won't turn on
Power supply board is dead.Replaced the power supply board,will get it stable and work again.The power supply board,that the board where the power a/c cord go into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 01, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse TX-47F430S 47 in. LCD TV TV won't turn on with the remote or manually and the other stuff we have plugged into the same outlet work fine.
Hello, it sounds like your power supply is gone, there are two things you can do to fix this problem. One is to attempt a component repair on your own, this just means you have to open the unit and look at the power supply. Normally the thing that will go out first on this unit are the capacitors. You might get lucky and find one that is puffy or fat, if you do you will need to get the value of the capacitor and simply put it on google so you can find a replacement. The number two thing you can do is simply send a quick email to parts@wde.com with the request for the power board and they will let you know the price and availability of the board, you will than have to do a simple swap of the boards and your TV will be back up and running in no time. Please rate my help on this site.
Apr 20, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
Sound with no picture for my westinghouse flat screen tv 42 ' model tx-42f810g
check your video section. the whole board section can be repalce it has on a ic that go bad all the time.i dont have the part number.goodluck
Feb 21, 2010 | Televison & Video
Westinghouse lcd tv parts
HAVE A WESTINGHOUSE LTV32-6HD. HAS SOUND, NO PICTURE. APPROXIMATELY 8 MONTHS OLD
Jan 20, 2008 | Westinghouse LTV-27w7 7 in. LCD HDTV
Westinghouse Electric TX42F810G 42" LCD Monitor Logo
354 people viewed this question
Top Westinghouse Electric Computers & Internet Experts
greg benton
vimal
vimal
Jerry Kramer
Jerry Kramer
Are you a Westinghouse Electric Computer and Internet Expert? Answer questions, earn points and help others
