Question about NetGear WG111T 108 Mbps 802.11g Wireless USB 2.0 Network Adapter (NETWNGWG111T)
I installed the netgear wg111t. I see at the bottom of the computer and the signal is excellent and says it is connected. But I try to sign on to aol or internet explorer and it says no connection was made
    Problem Solver:
  • 17 Answers
Try activating the network connection then restart the computer, if that does not work, your explorer may need to be re-installed.
Posted on Sep 28, 2010
Netgear wireless adapter wg111t will not work work
It's impossible that the wireless router cannot detect your wireless adapter wg111t.
You try to test another one if still have a problem connecting with your wireless router.
If that router can see another wireless network available then maybe your Netgear wireless adapter have a problem incomplete installation or the wireless device is defective.
I have encounter like this before so maybe it's the same with.
Hope my tip will help you a lot.
Please rate me.
Thank you.
Sep 14, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER stopped working
What are you trying to connect your USB wireless device to?
Is it to a wireless hot spot?
or to a Wireless Access Point/Router?
When you find a connection, what is the signal strength?
I assume you have configured your Access Point correctly as well as making it secure. You should connect a computer to the Access Point using a network 10BaseT cable to check the Access Point configuration, especially the wireless configuration.
If you are trying to connect to a wireless Access Point and you have a weak signal, move your computer closer to the Access Point or move the Access Point to a better and higher location to give you a better wireless coverage. Note, walls can affect the wireless signals between the Access Point and the wireless network card and wireless USB device, especially reinforced concrete walls.
Jun 01, 2008 | Computers & Internet
Netgear 108 Mbps wireless usb 2.0 adapter wg111t
i had the same problem. i tryed downloading the sofware from other computer and install it on the wireless computer. finally i just connected it directly to a lan line and update drivers with windows
Apr 08, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
WG111T config problems
http://kbserver.netgear.com/release_notes/d102803.asp
Download version 1.3
I was running into the same issue when I formatted my computer. It worked fine before that. I downloaded the version 1.3 though and it installed easily. There are step by step instructions how to install it as well. Hope this helps!
Jan 29, 2008 | NetGear WG111T 802.11g/b (E82321) Wireless...
Wg111t
Hi - Well, I do have one thing for you look for -
what type of network access are you trying to set up?
I'd just reinstall the software again (don't worry about the uninstall yet) and say okay if it asks if it can overwrite the files.
With the type of card you are mentioning, you are probably going to have to set it up to access as WEP (instead of WPA's). That was what was wrong when we installed one of these two weeks ago. I was trying to connect to the WPA-personal that I'd set up the router to and already had one computer set up for. I had to change the entire network setup (including router) to WEP to accommodate the new connection! (And WEP is slower than WPA's.)
I hope that is the only problem for you.
Dec 23, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
WG111T
The solution I have is quite simple. I use Vista premium x64 so someone else can test it on Xp but it should work for both. In Vista the 1.3 version doesnt work so Facid's solution doesnt work for me.
[LIST=1]
[*]Get the 2.1 setup for Vista and install it.
[*]Go to your NETGEAR folder wherever you installed it to (Program Files x86 for me) and copy the DRIVERS folder to your desktop.
[*]Uninstall the smartwizard and remove everything in the NETGEAR folder.
[*]Plug in your WG111T.
[*]Go to Device Manager and find your WG111T in the list, Right Click and Update Driver.
[*]Browse to the DRIVERS folder on your desktop when it asks where to look for the driver and the WG111T will install. It should popup with a little message when it is completed but you will not be online yet.
[B]I dont know what you would do in Xp x64 system but I believe it has its own wireless manager like Vista and should be quite simalar.[/B]
[*]IN VISTA go to the Connect To button in your Start menu, It should be under Computer and Network, it should show your router along with a 5 bar network strength graphic.
[*]For me all I had to do was double click on the network and put in my WEP hex key and it conected.
[/LIST]
Gamertag: NeoNMD
Nov 04, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
Configure router via ethernet cable in first instance. Then install adapter. May need to hange MTU for AOL as ISP.
Oct 08, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
Computers & Internet Logo
94 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
