Question about Vizio VX32LHDTV10A 32 in. LCD HDTV
The tv was working ok then colorful stripes filled the screen. i was nunable to power it off with the remote. I unplugged it then plugged it in again but it wont power on. The Vizio symbol lights up when plugged in but the TV will not come on.
  • 11,361 Answers
It can be the power supply module, main board, T-CON board, and worst case will be the LCD panel itself.
You need to open it up and do the troubleshooting.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Sep 29, 2010
Soniq E23213a au 12v and 240v works for 20mins then screen goes green stripes and stops
Unplug your TV hold the power button down on the TV itself for one minutes release the power button plug it back in and turn it on yeah power build up and not yet overpowering of the power supplies you probably have it on power bar not plugged directly into the wall post TV to be plugged directly into the wall the wise Yup Yup mismatched power
Jan 07, 2018 | Car Audio & Video
Sharp TV lc-60le640u
Unplug set, press and hold (on set) volume-down and channel-down and hold them while plugging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state'
Dec 05, 2017 | Sharp Televison & Video
Sharp TV model lc-60le640u
Unplug set, press and hold (on set) volume-down and channel-down and hold them while pluging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state'
Image disappear, loud, high pitch noise
It is likely that your Sansui TV has a power supply problem.
Jan 17, 2014 | Sansui 22"" HD LCD/DVD Combo TV
KP61S75 has 45* angled stripes.
1? you must test the power supply, the absence of this cause a LOT of problem, test a= fuse, filter, c.breaker rectifier.
2) test the tuner, i-f, video detector, AGC, section
3) if the tv has external POT adjustment for vertical, horizon, do it carefully.
4) tight any wires connector loose, or bad contacts.
God bless you
see the diagram
Jul 18, 2012 | Sony KP-61S75 TV
Clor stripes on screen. Can not turn off tv unless i unplug it
The color stripes can usually be fixed by opening your monitor and re-seating your lcd screen. The alignment tabs often slip on these generic models, pinching off the liquid lcd before it can reach the screen. Your other problem is caused by an inferior infrared receiver led. These can be replaced with a generic infrared receiver from radio shack. There are only 2 to 4 pins that need to be de-soldered to fix this. Many ppl think that the remote has drifted off frequency and needs to be dialed back in, and this simply isn't the case. Replace that led and your remote will work perfectly again.
Sep 14, 2010 | Astar LTV-19BG TV
Samsung lnt4065fx/xaa with 100's of colored lines
Sound like one of two things: A test screen, or a broken TV. More likely than not, your television is broken. Try hitting TV/Video on your remote, and if that doesn't work, power the TV off, unplug it, and plug it back in. If none of the works, it's time to call a repair man.
Oct 29, 2009 | Televison & Video
Multi color vertical lines on sony wega LCD tv/42 inch
sir do a power reseet ,turn off the tv then unplug it from the electrical source then wait for 1 minute then plug it in and turn it on if it doesn't work call sony customer serveice at 1800 222 7669
Aug 11, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Emerson tv model no. ewf2704
Hi: When you say small horizontal screen, ¿Do you mean picture does not fill the screen completely from top to button? ¿Do images display normally though they are smaller in size? ¿Is color and definition of signal OK? Please answer so I can have a better picture of the problem.
Sep 19, 2007 | Emerson EWF2704 TV
Vizio VX32LHDTV10A 32 in. LCD HDTV Logo
173 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
